New homebuilt mount
7 replies to this topic
#1 btschumy
btschumy
    Vendor - Our Galaxy
Posted 10 August 2004 - 05:56 PM
Sevaral weeks ago someone posted the URL of a new mount based upon the Giro.
http://www.teleskop-...oramamontierung
Since I had a Giro sitting around, I thought I'd see if I could copy the mount. My woodworking skills are pretty abysmal but here is what I came up with:
#2 Rusty
Rusty
  • In Memoriam
Posted 10 August 2004 - 09:07 PM
It looks great to me (and I've done woodworking for fine art museums).
But what binocs are those?
#3 btschumy
btschumy
    Vendor - Our Galaxy
Posted 10 August 2004 - 09:19 PM
They are Oberwerk 20x90s.
Thanks for the compliment. It's not one of my best efforts, but it is far from the worst .
#4 Bill Weir
Bill Weir
Posted 10 August 2004 - 10:24 PM
That's a very cool looking mount. Looks good and solid for those big binos. Still must be a little tough for the zenith but for everything else it must be great. The woodworking looks nice by the way.
#5 Craig Simmons
Craig Simmons
Posted 11 August 2004 - 06:18 AM
Looks very compact, easy to control and move around. Good job.
#6 Guest_**DONOTDELETE**_*
Posted 11 August 2004 - 07:34 AM
Nice setup! It amazes me what people can do mechanically.
#7 btschumy
btschumy
    Vendor - Our Galaxy
Posted 11 August 2004 - 08:45 AM
Thanks for all the nice comments.
I got a chance to try it out last night. It is tough at the zenith, as are most mounts where the binoculars are mounted above the tripod's center axis. I'm not sure this will replace my UA parallelogram mount for most uses, but it is probably more portable. I could pack this in a suitcast for an airline flight.
I did find that in some positions, the center post crank hit the lower arm of the mount. This was only an issue when the center post was all the way down while looking close to the horizon. Not sure if there is an easy way to solve this. I guess I could shorten the arms and then put more weight on them to counter the shortening.
Motions were very smooth and the balance was great. It was a pleasure to use in elevations between 10 and 60 degrees. If the binoculars were not straight-through, that would extend the usefulness of it.
#8 Rammysherriff
Rammysherriff
Posted 11 August 2004 - 09:40 AM
I suppose its sturdiness helped in splitting those tight doubles?
The next logical step are binos with 45 deg eyepieces I presume? ;-)
