Affect of Eye Pupil on Binocular Aperture
35 replies to this topic
#26 EdZ
EdZ
    Professor EdZ
Posted 12 August 2004 - 05:55 PM
Tough crowd here, eh Mike. Amicable though. thanks Kenny. Reads better now, although I knew what you meant Mike.
Mike, I like the thought or implication of the larger exit pupil causing greater constriction in brighter light. has merit.
Typically, scope design enthusiasts will tell us that a smaller acromat can get away with a shorter focal ratio to overcome the affects of CA. The larger the objective the longer it needs to be. the BT100s are f6.2
edz
#27 Henry Link
Henry Link
Posted 12 August 2004 - 06:02 PM
Mike,
I find myself agreeing with both of you. I think Ed is correct that CA increases with magnification in otherwise identical optical systems ( like the Fujinon 10X70 and 16X70) simply because the same color fringe is being magnified more, but only if the entire area of both objectives is actually being used. In a lighting situation where the eye is only open to say 3.5mm the 10X70 would effectively be a 35mm F:8 (assuming an F:4 objective) but the 16X70 would effectively be about a 56mm F:5 and so would show more CA than would be predicted by just the difference in magnification. I think there is a confusion in your post between increasing focal ratio with reduced effective aperture and actual focal length, which doesn't change.
Henry
#28 lighttrap
lighttrap
Posted 12 August 2004 - 06:49 PM
<laughing> Speaking of "tough crowds", should the title be "Affect" or "Effect"...? :lol:
#29 Guest_**DONOTDELETE**_*
Posted 12 August 2004 - 07:59 PM
As a side note....
"By the way in the BT100, as magnification increases, CA is nearly absent."
I agree with that statement. In an examination of CA as a function of magnitude I have found this to be true...which is opposite of what I was expecting.
#30 Henry Link
Henry Link
Posted 12 August 2004 - 09:30 PM
Mike,
Sorry, I just noticed you fixed the focal ratio/ focal length bits in your post.
Henry
#31 sftonkin
sftonkin
Posted 13 August 2004 - 12:29 AM
ighttrap wrote:
>Can we agree that when it comes to achromats, that focal length
>determines amount of CA?
Yes. The "rule of thumb" for a "normal" (i.e. crown/flint) achromatic doublet
is that the focal ratio should be 3A, where A is the aperture in inches.
Another way of stating this is that the focal length should be 3*A^2. And
we wonder why we see colour in a 4" f/5 ! :)
In this talk about CA, it is also useful to distinguish between axial CA and
lateral CA. Obviously, the latter becomes more apparent with wider FoV;
for this reason higher magnifications with lower FoV, especially if it is lower
AFoV, can show less CA. Axial CA will appear greater with higher
magnifications.
#32 EdZ
EdZ
    Professor EdZ
Posted 13 August 2004 - 04:41 AM
Affect = Influence
Effect = Result
use accordingly
I edited a few of my uses.
edz
#33 Guest_**DONOTDELETE**_*
Posted 13 August 2004 - 06:35 AM
Axial CA? I have never heard of this. Can you give an example of how aberration comes about and/or a personal experience of this?
#34 sftonkin
sftonkin
Posted 13 August 2004 - 08:19 AM
Axial CA occurs when different colours from an on-axis object are focused at different distances along the axis. Typically we tend to gravitate to a best focus for yellow-green, where the eye is most sensitive, so we get a "plum" fringe from the out-of-focus red and violet ends of the spectrum.
Lateral CA results from a chromatic difference of magnification for off-axis objects. It is responsible for the off-axis colour fringing in most wide field binocs. Eyepieces in particular tend to have a lot of inherent lateral colour. It is darned difficult (aka expensive) to correct!
HTH
#35 Guest_**DONOTDELETE**_*
Posted 13 August 2004 - 08:54 AM
Then axial CA is the CA most users typically experience and talk about. I was not aware of its appropriate and specific name of "axial CA".
Lateral CA, in other words, is the change in a lens's magnification for different wavelengths, resulting in fringing CA. Correct? But doesn't light need to be incident obliquely to the objectives for this type of CA to be noticable? Yes, it does seems hard to mitigate.
#36 sftonkin
sftonkin
Posted 13 August 2004 - 10:52 AM
I used to think so, but I'm not convinced -- anything off-axis (like almost
everything we observe most of the time) is going to involve lateral CA.
Also commonly known as "longitudinal CA" -- the two terms are
interchangeable.
