hello and help
4 replies to this topic
#1 Guest_**DONOTDELETE**_*
Posted 12 August 2004 - 04:33 PM
I just purchased oberwerk 22x100 bogen 3011nb/3130 tripod/head comb and astonomics t-mount light.I can not figure were the t-mount hooks up.I am new and my daughter just got me into astronomy.I am guessing I need to order some type of piece to hook the tmount light to the stand any help would be much appreciated.............thks
#2 btschumy
btschumy
    Vendor - Our Galaxy
Posted 12 August 2004 - 04:53 PM
Kevin,
I believe you should unscrew the tripod head from the tripod itself. This will expose a 3/8" bolt coming vertically out of the top of the tripod. The UA mount should screw onto this bolt.
#3 Guest_**DONOTDELETE**_*
Posted 12 August 2004 - 05:42 PM
the tmount i cant figure out theres only a big open hole
#4 Guest_**DONOTDELETE**_*
Posted 12 August 2004 - 08:13 PM
There needs to be a vertical post of the right size to match the T-mount light like the one Bill mentioned on your tripod. I am not familiar with that particular tripod so I am not sure what it has, but below is a link to the Oberwerk website showing the mounted T-mount light. I hope it helps.
http://www.bigbinocu....com/tmount.htm
#5 sftonkin
sftonkin
Posted 13 August 2004 - 12:39 AM
I have the T-mount. As NW said, you need to screw the mounting post directly onto the tripod. Larry (UA) does different mounting posts, internally drilled and tapped for different tripods. Photographic tripods usually have a 1/4" or 3/8" thread (I think all the Bogens have 3/8"); surveyors usually have a 5/8".
You might find the UA Yahoo group to be useful:
http://groups.yahoo....salastronomics/
