List of Paracorr settings for all brands of EP's
264 replies to this topic
#76 Astrolabe
Astrolabe
  • Loc: sydney Australia
Posted 28 June 2008 - 12:13 AM
Thanks to everyone for the work done in the relation to the Paracorr settings. I recently bought a paracorr but I have no problems with the settings as all my eyepieces are made by Televue.
An observing mate wants to try the Paracorr with his Meade 5000 32mm - 2" Plossl and his 21mm Orion Stratus. I haven't any more information on these eyepieces so I cannot use the spreadsheet. I will be gratefull if someone could tell me the paracorr settings for these two eyepieces.
Thanks in advance and regards
George (astrolabe)
Sydney Australia
#77 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 28 June 2008 - 12:38 AM
An observing mate wants to try the Paracorr with his Meade 5000 32mm - 2" Plossl and his 21mm Orion Stratus. I haven't any more information on these eyepieces so I cannot use the spreadsheet. I will be grateful if someone could tell me the paracorr settings for these two eyepieces.
George (astrolabe)
Sydney Australia
It's easy, mate.
Set the Paracorr for one of your TeleVue eyepieces and focus.
Remove your eyepiece and install his. Refocus using the tunable top and look at the setting. That's the setting for that eyepiece. Write it down. REmove the eyepiece and install the other one. Focus using the tunable top. Note the setting. You can do this for a whole box of unknowns.
#78 Astrolabe
Astrolabe
Posted 28 June 2008 - 10:19 AM
Don
Your opinion and advice is always valued and appreciated, thank you for the prompt reply.
Best regards
George (astrolabe)
#79 cyberhedz
cyberhedz
  • Loc: Peyton, CO
Posted 05 August 2008 - 06:47 PM
since we have a bunch of paracorr users here, it seems rather fitting to ask, even if only an opinion, I'm getting a 12" dob f/4.9 and was wondering how necessary paracorr was. i do plan to get an antares 1.6 barlow and some hyperions EPs with it and plan to save up for a 2x powermate and an ethos.
#80 Starman1
Starman1
  • Loc: Los Angeles
Posted 05 August 2008 - 09:54 PM
Varies. I found coma severe enough at f/5 to require a Paracorr. Other observers don't use one at f/4.5.
Here's a question: Do you want the stars at the edge to be as tight as the center? You'll need a Paracorr.
Don't care about the edge? Probably won't need one.
Don't know the answer?
Look first, buy later. There's no shortage of Paracorrs.
#81 Starman1
Starman1
  • Loc: Los Angeles
Posted 06 August 2008 - 03:45 PM
See the following posts for why this post has a mistake in logic...Don
Ethos Paracorr Settings:
TeleVue's recommended settings are incorrect, according to both my eye and the two excellent calculators on this thread.
Here's what I found:
Used as 2" eyepieces in the Paracorr:
13mm Ethos--Setting 1, with the eyepiece pulled out of the Paracorr 1.5mm
8mm Ethos--Setting 1, with the eyepiece pulled out of the Paracorr 12.5mm (not practical unless a 2" skirt is added to the eyepiece)
Used as 1.25" eyepieces in the Paracorr:
13mm Ethos--Setting 4
8mm Ethos--Setting 1 with the eyepiece pulled 2.5mm further out.
It seems TeleVue's recommended settings may have been calculated using pre-production design specs. TeleVue says that the 1.25" settings for the Ethos are 5(13) and 4(8) respectively, and that isn't even close on the 8mm.
I used the empirical method of actually looking at the edge-of-field star images, and the settings I derived agreed with the 2 calculators on this thread.
The focal plane of the 8mm is 0.7" (17.78mm) below the 2" shoulder, or 0.43" (10.9mm) lower in the barrel than the 13.
If the 13 uses setting 1 in the Paracorr in 2" mode, the 8mm is going to need to be at least 10.9mm farther out than setting 1. If used with a Paracorr, there's no way around a lot of infocusing on the eyepiece/Paracorr combination. I caution any potential buyers to look at their focuser position for the 13 before you buy an 8mm--you will need around a half inch of additional in-focus.
My recommendations:
Use the 13 Ethos as a 2" and use setting 1.
Use the 8 Ethos as a 1.25" and use setting 1 and pull the eyepiece out about 2mm. This will require a LOT of infocusing.
#82 John Rhodes
John Rhodes
    Vendor (Televue Rep)
  • Loc: Torrance, CA.
Posted 06 August 2008 - 06:00 PM
<snip>
My recommendations:
Wow thats quite a statement...
Let's see : The TV website recommends the #1 setting for the 13 Ethos also,
so how are we incorrect there ?
As for the 8 mm: Your's & our settings are 12 mm apart, which 1.25 adapter are you using on the 8 mm Ethos ?
We recommend the "lower" adapter that comes with the Paracorr.
#83 Starman1
Starman1
  • Loc: Los Angeles
Posted 07 August 2008 - 12:27 AM
John,
Yes, the 13Ethos works great at setting 1 (2").
I'm using the standard 1.25" adapter that comes with the Paracorr.
Here's the math:
The focal plane is 0.70" below the shoulder, per TV's chart.
The 1.25" adapter is 0.379" tall (calipers measurement).
That combination results in a focal plane to optimum Paracorr lens distance of 2.76mm too low for the 8mm Ethos when the Paracorr is set to setting 1, that is the 8mm eyepiece needs to go up another 2.76mm to achieve the optimum 55mm distance from focal plane to lens.
Have I missed something?
I could be wrong, but the calculator shows setting 4 would be 12.28mm too low, and that setting 1 is 2.76mm too low.
I'm forgetting something--see below
#84 Starman1
Starman1
  • Loc: Los Angeles
Posted 07 August 2008 - 12:51 AM
John, et al.,
My wife just pointed out how much of a bonehead I was. It took her to show me the error in my logic. :foreheadslap:
Now I eat crow....
The focal plane of the 8mm Ethos is 0.7" below the 2" shoulder.
When I put the eyepiece in the adapter, it automatically raises the eyepiece by the length of the 2" skirt (1.04"). Hence, the focal plane of the eyepiece is now 1.04-0.7 ABOVE the adapter (or 0.34"). So long as I also take into account the thickness of the adapter, the calculator should work fine.
According to the TeleVue website, that means the focal plane is above the reference surface (the bottom of the 2" skirt the eyepiece is resting on).
That means I should be able to plug the 0.34" figure into the calculator and get the proper setting for the Paracorr.
OK. I get setting 3.
It gets setting 4 for the Type 6 Naglers (agreeing with TeleVue), and setting 5 for the 22T4 (again agreeing with TeleVue), and setting 3 for the 17 T4 (same as TeleVue).
But I get setting 3 for the 8 Ethos (no agreement there--TV says 4) and setting 3 for the 16T5 (where TV says 4), but the difference is now 1 setting (0.125" or 3mm).
That says the 8mm Ethos is best used as a 1.25" eyepiece in the Paracorr.
So, John, is my math now better? Or have I overlooked something else?
#85 Starman1
Starman1
  • Loc: Los Angeles
Posted 07 August 2008 - 01:06 PM
Plugging the focal plane positions from TeleVue's website into Walt's calculator (and compensating for the skirts on the 12mm T4 and Ethos eyepieces), I get the following optimum(55mm spacing) settings for the Nagler eyepieces(1.25 eyepieces use adapter):
31T5--6 (there is no 6, so use setting 5)
26T5--3.3
22T4--5.2
20T5--1.7
17T4--3.2
16T5--3.7
13T6--4.0
12T4--3.9 (with 1.25" adapter)
11T6--4.0
9T6--4.0
7T6--4.0
5T6--4.0
3.5T6--4.0
2.5T6--4.0
13 Ethos--.8 (as 2")
8 Ethos--4.2 (as 1.25")
Rounded off to the nearest whole number, the settings seem to agree with TeleVue's chart.
It should be noted that TeleVue says +/- 4mm is an acceptable margin for error on the setting. Since the settings on the Paracorr are 3.2mm apart, that means there is quite a bit of leeway in the setting of the Paracorr (i.e. that if optimum is setting 4, good correction can be anywhere from setting 3 to setting 5).
#86 Zoomit
Zoomit
  • Loc: SoCal
Posted 07 August 2008 - 10:02 PM
Don, if you would...can you confirm this is still accurate?
#87 Starman1
Starman1
  • Loc: Los Angeles
Posted 07 August 2008 - 10:34 PM
WEll, not quite.
I'm sorry if it wasn't clear.
Close, but not exact.
I was slightly mistaken in how to measure the eyepieces with a skirt.
The Ethos 13, if used as a 2", requires setting 1 (all the way out). That is close to the optimum setting. If used in the 1.25" mode, setting 5.
The Ethos 8mm, if used as a 1.25" eyepiece with the standard Paracorr adapter, requires setting 4. It is not usable in a 2" mode unless a barrel extension is added to the eyepiece, in which case the eyepiece would be pulled out 12.4mm from the Paracorr, with the PC in setting 1. In other words, this eyepiece requires the use of the 1.25" adapter in setting 4. I wouldn't bother to try to use it as a 2" eyepiece in the Paracorr. Just remember that this requires some in-focus movement of the focuser.
#88 Fireball
Fireball
Posted 03 September 2008 - 03:35 PM
Can somebody help me with the Meade 5000 UWA ?
I have 6.7 - 18 - 31mm.
What about Hyperion, e.g 13mm ? Or QX26mm ?
TIA
#89 Starman1
Starman1
  • Loc: Los Angeles
Posted 03 September 2008 - 07:20 PM
It might be helpful to review how to pick a proper setting for the Paracorr:
1) If you have a TeleVue eyepiece, set the Paracorr for that eyepiece (from the TV website) and focus. Remove the eyepiece and insert another. Focus using the tunable top on the Paracorr, not the normal focuser knobs. Note the setting, write it down, because that's the setting for that eyepiece.
2) If you don't have a TeleVue eyepiece, start in setting 1 (tunable top all the way turned out), and put the eyepiece in. Focus. Evaluate star images at edge of field. Still flared in a radial direction slightly? Move Paracorr to setting 2. Refocus. Star images at the edge better or worse? Worse? Setting 1 is your choice. Better? Move Paracorr to setting 3 and focus again. Evaluate stars at the edge. Worse? Go back to setting 2. Better? Continue to setting 4. Etc.
You will find one setting that is the best for that eyepiece. Write it down. Return Paracorr to that setting.
Remove that eyepiece, insert other eyepieces one at a time, and focus using the Paracorr tunable top instead of the focuser. Note the setting for each eyepiece where it is in focus--that's the Paracorr setting for that eyepiece. In this way, you can do a whole collection of eyepieces with experimentation only on the very first eyepiece.
#90 Robert Provin
Robert Provin
  • Loc: Northridge, CA
Posted 03 October 2008 - 11:19 AM
Don, your posts here have been very helpful, thank you! :bow: :bow: :bow:
BTW, it was nice meeting you up at Mt. Pinos last weekend.
Robert
#91 peter k
peter k
  • Loc: Big Island, Hawaii
Posted 18 November 2008 - 05:48 PM
This is a very useful post--thanks, Don. However, there seems to be something I'm missing. The above quote suggests (to me) that for a given scope there is a single, fixed point of best focus for the Paracorr, and once this is established, focus is obtained for different eyepieces by use of the tunable top, leaving the focuser untouched, regardless of eyepiece. This does not seem consistent with earlier posts, including Don's just a couple up, which states that additional in-focus is needed for the Ethoses. Can someone (Don?) clarify?
Thanks much.
#92 Starman1
Starman1
  • Loc: Los Angeles
Posted 18 November 2008 - 11:57 PM
Sure.
There is one distance from the paracorr lens to the eyepiece's focal plane that results in the best coma correction.
But how do you find it?
Answer: correct the coma completely for one eyepiece. You have found that eyepiece's lens-to-focal plane distance.
Insert another eyepiece and focus using the Paracorr top. Note that while doing so, you are effectively moving the eyepiece in and out to adjust the eyepiece position relative to the focal plane of the telescope plus Paracorr. This is really no different than you would do adjusting the focus of the eyepiece in the focuser without the Paracorr, only instead of moving the focuser, you're moving the Paracorr's top.
What it implies, and it would be true, that there is only one position for the focal plane of the telescope, whether the Paracorr is used or not. The Paracorr moves the focal plane position slightly, but the idea is the same as having no Paracorr--you are moving the focal plane of the eyepiece to the focal plane of the scope in order to focus.
The Paracorr does not focus, per se, so you are not focusing the Paracorr, merely putting it into the system to modify the focal plane slightly.
Now, if your eyepiece's focal plane is low in the eyepiece, you will have to move the eyepiece back relative to the Paracorr's lens in order to maintain the correct distance to the lens for best correction. But that means the focal plane of the system is now higher than before. In order to bring the focal plane of the paracorr plus eyepiece to be coincident with the focal plane of the telescope, you will have to move the Paracorr plus eyepiece in to make the focal planes coincident.
So, eyepieces with low focal planes require more out travel with the Paracorr and more inward movement of the focuser.
In a sense, that's no different than an extension tube. Add an extension tube to the focuser, and you will have to move the focuser in to get to focus: eyepiece goes out, focuser goes in.
Hope that makes it clearer.
#93 interalia
interalia
  • Loc: Space Coast, Florida
Posted 15 January 2009 - 01:14 AM
A formula I have found useful for finding paracorr settings (in the newer paracorr) when the distance to the focal plane from the eyepiece seat is known is:
8(13/40 - f) or, what is equivalent, 8(0.325 - f)
The attached chart illustrates where the eyepieces in the TeleVue table lie along the range of motion available and the settings best for them. It is from the two constraints that the range of motion is known to be half an inch and that all the eyepieces TeleVue gives settings for must find those settings correctly that the above formula is derived.
Hopefully it may be of some use, and the chart be helpful.
#94 llanitedave
llanitedave
    Humble Megalomaniac
  • Loc: Amargosa Valley, NV, USA
Posted 17 January 2009 - 02:29 AM
I just got a chance to play with the Paracorr settings for my 8mm and 17mm Hyperions. For both, the best setting seems to be 1.
I was looking not so much for coma correction, which seems to be pretty good at all the settings, but the you can definitely tell a difference in the on-axis star images as you adjust.
I also tried different setings for the Hyperion 31mm Aspheric, and it seems to be giving me the tightest images at setting 5. However, it's not very sensitive to the Paracorr setting, and I might have to try it a few more times to be sure.
#95 phanfave
phanfave
  • Loc: Pioneer Valley
Posted 22 April 2009 - 08:09 AM
Reread this thread again. First of all thanks to everyone! It's a must read for using a Paracorr and a fast scope. I've got a few Ethos and the shorter ones I have the 2" barrel extension skirt. Is this going to give me too much distance away from the top lens? Can I use these in setting 1 and get good correction? I'd really like to use them as 2" eyepieces with the skirt if possible. Thanks for your input.
Sean
#96 Starman1
Starman1
  • Loc: Los Angeles
Posted 22 April 2009 - 08:37 AM
Sean
The 13 and 10 Ethos use setting 1 as a 2" eyepiece, but the 8 and 6mm Ethos use the 1.25" adapter and setting 4. You unfortunately cannot use these two as 2" eyepieces in the Paracorr because the correct position for them would be with the eyepieces pulled 1/2" out of the Paracorr and using setting 1. It's actually more secure to use them as 1.25" eyepieces with the Paracorr.
#97 phanfave
phanfave
Posted 22 April 2009 - 09:29 AM
Thanks Don. That makes sense. But it also makes me wonder if the 2" extension skirt would work too since the eyepieces will be further out from the Paracorr compared to using in the 2" mode (or even 1.25" mode with the adapter or the high hat). I picked up the 2" extension this past weekend at NEAF (and they have been slightly redesigned...black anodized now) and have them on the 13,10,8, and 6. I'll get to try them all out tomorrow with the skirt and the Paracorr and will report back here. I'm hoping they work well enough to keep them on.
Here's a pic with the extension on and off:
#98 Starman1
Starman1
  • Loc: Los Angeles
Posted 22 April 2009 - 09:37 AM
Yes, with a 2" extender, you should be able to use the 8 and 6 Ethos as 2" eyepieces in the Paracorr. As I read the calculator, use the paracorr in setting 1, then pull the eyepiece out until the "shoulder" of the upper eyepiece sits 1/2" above the top of the Paracorr(leaving 1/2" of the silver 2" skirt showing).
The 13 and 10 don't need the extender because the length of the extender will prevent them from fully seating in the Paracorr. You would use them without an extender, in 2" mode, at setting 1.
If you are thinking about using the 2" extender to use 2" filters, don't worry--2" filters thread directly to the bottom of the Paracorr. And since the Paracorr doesn't have a "safety undercut", it's easily removable from the focuser to attach a filter to its bottom.
#99 phanfave
phanfave
Posted 22 April 2009 - 09:59 AM
Thanks again! It would have been nice for simplicity sake to use the 13 and 10 with the 2" extension but as you pointed out it's neither necessary nor possible.
Sean
#100 jonstarrysky
jonstarrysky
  • Loc: England, U.K.
Posted 08 May 2009 - 05:39 PM
try using one of these stops to precisely position the Ethos if using the extension barrel:
http://www.cloudynig...8 007 small.jpg
http://www.agenaastr...bp-hyp-stop.htm
My thinking is as above. E13=#1 (2" mode). E8=#4 (with 2-1.25" adapter). I may leave the paracorr 2-1.25" adapter on my E8 permanently. Simlifies swapping between eg E8, E13, 26T5. Or to use the barrel extension as indiccated.
2" filters at the bottom of the paracorr ? Yes, but youre taking off/ on a mighty train of glass, you dont wanna drop it.
