Review of the TMB Mono Review(s)
#1
Posted 15 September 2004 - 11:48 AM
#2
Posted 15 September 2004 - 12:25 PM
What it also says is that until every eyepiece is individually tested, caveat emptor (let the buyer beware).
#3
Posted 15 September 2004 - 01:46 PM
#4
Posted 15 September 2004 - 02:30 PM
And it points out the perils of being an early adopter. I, too, have no doubts that quality checks will be more stringent on future batches.
#5
Posted 15 September 2004 - 03:15 PM
Clear skies,
J.D.
#6
Guest_**DONOTDELETE**_*
Posted 15 September 2004 - 06:24 PM
Hoping to be reasonably fair about all this, I did talk directly with Gary and we also exchanged email. Although he disagreed with a number of things in the next-to-last draft that he saw (and I'm sure he would continue to disagree with many things in this final draft), I appreciate his input. I believe that he was helpful and constructive, particularly in tempering my speculation regarding his test procedures. That does NOT mean that he agrees with, endorses, or looks favorably on my conclusions, nor that he is responsible for any errors, which are completely my own.
Al Bellg
#7
Posted 15 September 2004 - 08:31 PM
Daniel Mounsey
#8
Posted 16 September 2004 - 06:53 AM
Regarding caveat emptor, the emptor need not be completely driven by his or her caveats. If a manufacturing problem is identified in a TMB Super Mono at any time (even when purchased used, as I understand it), it will be replaced by TMB/APM.
Al Bellg
#9
Posted 16 September 2004 - 11:04 AM
An interesting side note: I have had occasion (though not often) to actually use 3 of the same eyepiece at the same time in the same scope. One time, I compared 3-22mm Panoptics. Another time 3-8.8mm Meade Ultra Wide Angles. It's a long story as to why/how I got to do this.Don,
Al Bellg
Several other times, I have had occasion to compare my eyepiece with an identical eyepiece borrowed from a friend.
My conclusion: there are subtle differences between eyepieces of identical focal length/model/brand!. Of course, I kept the sharpest ones, but I was literally flabbergasted to see differences among identical units.
The differences were very subtle, and identified by sharpness of star images on center, at the edge, and (believe it or not) on the edges of deepsky objects.
These subtle differences were probably related to the quality of polish, optical alignment, and coatings between the eyepieces. At no time did I feel the worst of the bunch was a bad eyepiece, but I did feel that the best of the bunch was noticeably better than the other two in each instance.
Other comparisons I've made have been less conclusive (i.e. I wasn't certain which was better because of viewing conditions).
What does this mean? It means to me that there is a slight production variation in all eyepieces (because they are individually made and because there are so many steps in their constructions that will make slight differences in the final products), and that some of the very subtle differences noticed could be due to those differences.
Of course reviewer A's use of an f/5 scope, and reviewer B's use of an f/8 scope will have profound impact on their findings. It is when the same eyepieces are compared in the same scope on the same night on the same objects that the true differences can emerge.
Does that mean I'm going to always buy 3 of every eyepiece and return the two lesser ones? No. But it does mean that 2 units of anything produced by Man cannot be absolutely identical due to the normal variations in production.
I used to review high-end amplifiers, and, after listening critically, send them to a test lab to get all the figures. Occasionally, a mfr would take issue with a review and send us a second sample. Surprise! The second sample, though it had all the same components as the first, did not measure the same. The inevitable long chain of components, each with a slight variation from perfect, never added up to the same end result--on any two units.
Now, most people, under most circumstances, would never have heard the difference. Likewise, most people, under most circumstances, would never see the differences between identical eyepieces from the same company.
But when you add up polish, figuring, glass, coating, and assembly variations (especially with more air-glass interface surfaces), it's obvious there will be production variations.
And the good manufacturers will take steps to weed out the ones that vary outside the performance parameters (TeleVue does this, for example) so we don't get a bad one.
Nonetheless, there are subtle, slight, differences.
And I suspect these reviewers may have run into them.
#10
Posted 16 September 2004 - 01:05 PM
An excellent point. As a former researcher, I was often needing to take into account "within group" differences when studying "between group" effects. However, it also was not uncommon to find "outliers" in the data that were so randomly atypical of the norm that research designed to make statements about the norm needed to eliminate them from the data set.
In Gary's review of the Super Monos, he clearly saw something in the edge of field performance that I didn't. It was severe, and it resulted in him giving off-axis performance a two-star rating, "performance compromised during normal use." Thomas Back subsequently identified what Gary saw as an atypical flaw in the eyepieces he tested that would not represent what the typical purchaser would see. So in my view, Gary's review is about an "outlier" data point, and what is of greatest interest and importance to most of us is the more typical performance we're likely to obtain from these eyepieces.
Will there be differences between "normal" Super Monos? Certainly. I have binoviewer pairs at 5, 6, and 8mm, and there are very slight differences that I can detect between the eyepieces in each pair. But these differences are barely noticable and not nearly of the magnitude found by Gary.
Al Bellg
#11
Posted 18 September 2004 - 02:52 PM
At first glance, it looks great. I can see a lot of contrast improvement when I watch the moon at 200x(I got UO Orthos. HD 9, 12, 18 and I can detect more low-contrast detail as well as better light throughput through the Super Mono eyepiece.
However, I noticed a very faint yellowish ring along the edge of the field of view...I tried to see if the edge of field performance was afected by this slight yellowish ring but it wasn't so. Anyway I, as a recent member of the Yahoo's TMB group, posted a message in which I asked whether or not this "issue" was normal or I had to send it back to change it. There,I was told that if such a ring was as faint as I mentioned, it was normal. I was also told that defective Super Monos had a strong yellow ring and so not good off-axis performance (for 10 mm and less)
To conclude, Although I have still not watched any giant gas planet but Uranus, all I can say is that I am very happy with my Super Mono 10 mm. performance (in spite of its small fov. I can see the difference...)
As you can tell, I was rewarded with a randomly chosen (Astronomics)great eyepiece...
David
#12
Posted 20 September 2004 - 09:40 AM
First let me say that I appreciate the level of thought and analysis that you have put into all this.
One thing I do not understand, though, is why the issue of field curvature is so often neglected in discussing edge-of-field performance. Here is a property that introduces dramatic differences in edge-of-field sharpness based on particular pairings of telescopes and eyepieces, accommodation abilities of eyeballs, and focusing habits. Perhaps I see more of this because I insist on focusing the center of field at infinity, with the eyeball relaxed, rather than allowing the center to be moved inside focus to find an "average" focus position.
Anyway, my testing of TMB SuperMonos in two 10" f/5 Newt showed a significant amount of field curvature (I would say "severe" compared to that seen in an Abbe ortho in the same scope), and in approximately the same amount in the 5mm TMB SuperMono that I got from Markus as in an entire set of reference samples tested by Thomas. I do not believe for a second that this was a defect, as correspondingly, I noted in examining both sides of focus that the edge of field showed astonishingly good control of astigmatism at f/5. If it was a defect, then it was a miracle that astigmatism was accidentally controlled so well, as these two edge-of-field aberrations tend to be complementary in simple eyepiece designs. However, even in an 7" f/6.7 Newt the curvature was much less noticeable (despite the OTA having nearly the same inherent curvature as the 10" f/5), so it is small wonder that not everyone gets the same edge-of-field results, even when the samples are not defective. Furthermore, because different telescope designs have different curvatures themselves, one should not even expect the same results in, say, an f/5 apo as in an f/5 Newt. I don't pretend to know which end is up here, but it seems to me that whenever an eyepiece designer decides to leave in a certain amount of field curvature in order to avoid introducing astigmatism in faster scopes, we SHOULD see some differences of opinion on edge-of-field performance.
Personally, I tend to shrug at the edge-of-field properties of these eyepieces. Anybody who is willing to suffer a 30 degree field is probably going to have a drive and keep the object under scrutiny nailed at, or very near, the center of the view.
#13
Posted 21 September 2004 - 09:13 AM
Come to think of it, I haven't seen many eyepiece reviews discuss field curvature, either. It's my understanding that a curved field could be a deliberate design element (as in Panoptics) or a design flaw, as can be seen in the comparison photos on the Siebert Optics website http://www.siebertop...omparisons.html That certainly makes it worth talking about.
You also note that the eyepiece/telescope combination makes a big difference in edge performance. Gary found that, too, indicating that Super Mono edge performance improved "markedly" at f6 and f9 compared with the "soft and blurry" edge-of-field image at saw at f4.5 (with a Paracorr) using the flawed eyepieces he reviewed.
I'm taking your thoughts to heart and including a field curvature analysis in my future reviews.
Al Bellg
#14
Posted 24 October 2004 - 06:16 PM
#15
Posted 03 December 2006 - 04:24 PM
