Optical window or just use the MFR-3?
7 replies to this topic
#1 smokin oakum
smokin oakum
Posted 10 January 2008 - 07:11 AM
My question is two fold. Why would one need an optical window to seal out dust and dew if you use the MFR-3 most of the time. The only time I figure I won't use it is when I need more mag, and even then, couldn't I use the zoom feature.
My second question is, do you guys know what f ratio for my f/4.9 becomes with the MFR-3, then with the MFR-3 and the 5mm extension ring, then with the MFR-3 and the 5mm, and the 10mm extension rings? I've never been able to figure this stuff out, and this is actually the first time I've used a focal reducer on my DOB. Thanks for your help.
Still no sucker holes for my first light.
Stay tuned
Neil
#2 Jack Huerkamp
Jack Huerkamp
    Vendor - Waning Moon
Posted 10 January 2008 - 07:19 AM
Neil,
On my 8' f/4 Newtonian, I don't need or use an MFR-3. I do use the Optical Window to help isolate the cooled CCD sensor from the moisture in the air.
If you are using the MFR-3, you don't need the Optical Window.
Jack
#3 smokin oakum
smokin oakum
Posted 10 January 2008 - 07:26 AM
Thanks Jack. Can you belive my CSC! I've had blue in there for weeks, up until I recieved my camera. If you live near me, I'm sorry! The curse holds true I guess.
Any Idea, of how to find out what my f ratio would be with the rings? Is there a chart or something?
Neil
#4 ccs_hello
ccs_hello
Posted 10 January 2008 - 07:30 AM
Neil,
If you can measure the MFR-3 lens' focal length (or find it in the actual spec.), then it's easy to calculate the net result. Focal Reducer calculator http://timosastro.1g...calreducer.html
Clear Skies!
ccs_hello
#5 Jack Huerkamp
Jack Huerkamp
Posted 10 January 2008 - 07:32 AM
Neil,
Look at the graph I posted in the MallinCam Group Files section:
http://tinyurl.com/2ryhwk
It shows the effects of adding the MFR-3 and spacers to the camera. Based upon Greg Stones measurements on images he took, I developed the graph.
Your f/4.9 scope changes to f/3.8 with just the MFR-3.
It becomes f/3.5 with the addition of the 5mm ring.
It becomes f/3.2 with a 10mm ring.
With 15mm of extension it becomes f/3.
Again this is all based on measurement data Greg obtained by taking images with different camera-focal reducer-ring combinations and then measuring the separation of certain stars on prints.
Jack
#6 smokin oakum
smokin oakum
Posted 10 January 2008 - 07:36 AM
I found the Focal Reducer Calculator but I don't have the specs for the MFR-3. Do you have them Jack? I looked on the Mallincam web site without any luck.
Neil
#7 smokin oakum
smokin oakum
Posted 10 January 2008 - 07:37 AM
Sorry Jack! You're quicker than I can type.
#8 rolandskythree
rolandskythree
Posted 10 January 2008 - 01:14 PM
Jack, where do you get the optical window. I want one. Roland
