Long Exposure Camcorder
10 replies to this topic
#1 ccs_hello
ccs_hello
Posted 13 January 2008 - 10:20 PM
In another thread, I need to get the answer so I dug out my old (DV25 compression Digital8) camcorders. They are NightShot capable models. Here are some observations:
1) older model (type-1/4" SuperHAD CCD '089AK PAL* resolution 724*582 sensor). (Set the NightShoot LED illuminator off.) Nightshoot mode took out the UV/IR-cut filter, gain-up (minor sensitivity gain). NightShoot 1" mode, 1 second Long Exposure, quite nice sensitivity gain. NightShoot 2" mode, 2 seconds Long Exposure, very nice sensitivity gain, noise control is not too bad.
*PAL mode due to steadyshoot
2) slightly newer model (type-1/6" SuperHAD CCD icx096/097AK (any one know their spec?? wanted may be 752*582 "PAL mode"). (Set the NightShoot LED illuminator off.) Nightshoot mode took out the UV/IR-cut filter, a bit more gain-up (minor sensitivity gain but noisy). Super-NightShoot mode, I think it's slightly less than 1 second Long Exposure, some sensitivity gain.
Looks like the older one is better (type-1/4" and 2" Long Exposure). May be I'll yank out it's optical lens assembly and use it as prime focus imager :).
P.S. 2" Long Exposure is about the same as some dedicated special VideoCam models. Sure can't compete with 56 second LE, TEC active cooling, Amp-off, and type-1/2" CCD sensor. But I got my (1) camcorder cheap :) :).
Clear Skies!
ccs_hello
#2 b1gred
b1gred
    Enginerd
Posted 13 January 2008 - 10:44 PM
Hmmm, how to adapt my Sony "NightShot" camera to my scope...???
#3 ccs_hello
ccs_hello
Posted 13 January 2008 - 11:46 PM
Randy,
I found both of my camcorders' DV out (to PC) and analog video out (to a video monitor) are "live" during shooting.
RE: CCD coupling to OTA
I have not yet worked out a design. I think just leave everything in the camcorder still attached (thus not upset the CPU) but take the optical system out of the light path.
Then I have to glue a 1.25" barrel to the CCD chamber.
Just imagine that poor camcorder just had a front collision :rainbow: ...
Clear Skies!
ccs_hello
#4 b1gred
b1gred
    Enginerd
Posted 13 January 2008 - 11:52 PM
Ya, same on mine w/r/t the DV and Analog out.
I hadn't thought of removing the lens system from the CamCorder, however that might be the best option. I wonder if there is a way to 'temporarily' remove the optics from my Sony cam... It's also the camera I use for ATV (Amateur TeleVision), so I don't want to "trash" it for that purpose...
#5 ccs_hello
ccs_hello
Posted 14 January 2008 - 01:43 AM
Randy,
Looks like two options:
1) Use a 16-conductor flex cable extender to extract the CCD board out of the camcorder body
or
2) Unscrew the lens module (a 24-conductor flex cable attached to the main board; do not detach or will make CPU unhappy) and make it out of the way (light path)
P.S. lens module has zoom, focus, and iris (motors + position sensors) and nightshot IR filter removal mechanism
Either way quite destructive :( :p.
Clear Skies!
ccs_hello
#6 b1gred
b1gred
    Enginerd
Posted 14 January 2008 - 11:05 AM
Grrr, rats!
I suppose Eyepiece projection is a bit too lossy...? (Not to mention the weight of the holder for the camera.
#7 Alicatt
Alicatt
Posted 14 January 2008 - 12:28 PM
My Sony has a 37mm threaded ring on the lens, there are eyepiece adaptors to fit that.
Used the Sony to record my CCTV cam last night so hope it came out ok
#8 b1gred
b1gred
    Enginerd
Posted 14 January 2008 - 12:34 PM
Hmmmm....
#9 rshassell
rshassell
Posted 14 January 2008 - 12:49 PM
I have a Sony TRV50 MiniDV and a DCS-SR300 HDD camcorder. I never tried long exposures, but I have attempted to image the ISS with them. They both have 37mm filter threads, and I used an adapter ring to attach them to a 40mm EP. The images weren't as clear as I'd hoped, and there was some vignetting, but it did basically work. I got much better results with my Mallincam, as is evident from my avatar.
#10 ccs_hello
ccs_hello
Posted 15 January 2008 - 12:42 AM
These camcorders are designed for general consumers so I wouldn't put too high hope on lenses quality (I know some elements are molded plastic).
I think prime focus imaging is the way.
Clear Skies!
ccs_hello
#11 ccs_hello
ccs_hello
Posted 15 January 2008 - 12:57 AM
Update:
Use the 2" Nightshot (or Super NightShot mode) to shoot a LED in the dark in the back-n-forth as in a pendulum swing manner, I observe:
The LED light looks like a continuous (i.e., not jumpy) trail, almost like a slinky shifting position from one end point to the other. The continuous flow gives a pleasant viewing experience.
This indicates that the photon integration is done in both methods:
(1) on-CCD chip photon integration (i.e., the tradition long exposure) method upto a rate, e.g., 1/4 second per frame.
- This provide the apparent smooth optical flow, i.e., not too jumpy
- This method is (probably) needed since completely depend on method 2 would mean a large* size of memory is needed
*NTSC is about 30 frames/sec.
(2) off-CCD chip digital memory integration with sliding window method. E.g., for 1/4 second per frame feed, a 2" long sliding window will require a 9-frame** buffer.
** Two-second has eight 1/4 frames, but one extra frame is needed to fulfill sliding window integration calculation
Please comment on my reasoning. :grin:
BTW, what's SCII or MCHC's long exposure visual exprience/behavior?
Clear Skies!
ccs_hello
