Orion, Round Table, Mallincam, Moonlite, Speco....
143 replies to this topic
#126 Jack Huerkamp
Jack Huerkamp
    Vendor - Waning Moon
Posted 17 February 2008 - 10:55 AM
What you are seeing is the counterweight for the MallinCam when it is installed on the Hyperstar transfer lens. Here is the setup on the CPC1100:
The weight is needed to balance the dewshield, camera and transfer lens assembly.
Jack
#127 jgraham
jgraham
Posted 17 February 2008 - 11:01 AM
Cool setup!
#128 richs
richs
Posted 17 February 2008 - 11:50 AM
Bill
I believe your Meade has hardware stops that keep it from winding things up, it can only go so far before it hits the stop.
Rich
#129 calibos
calibos
Posted 27 February 2008 - 11:31 AM
Hi Neil,
While a mallincam is still far off in my future I feel the need for an upgraded focusser. Issues with focusser slop with collimation tells me I need compression rings. Issues with vibration when focussing tells me I need to brace my XT12i base and go the motorfocus route. Issues with a desire for a mallincam in the future :D tell me I need a low profile focusser. Why not combine all these needs by jumping the gun even before I get a mallincam byt getting a moonlight like yourself.
What combination of options would you recommend. Low profile obviously but what other options do I spec. Oh and will a low profile affect my EP's in visual use. I am using a full set of Baader Hyperions atm which can be used as 1.25" with the supplied orion adapter or can also be used straight in a 2" drawtube though obviously sitting lower without the thickness of an 1.25" adapter. Will a low profile moonlight give me issues visually?
On a side issue. Have you thought about using your old Orion focusser with your speco. Didn't I see some guys genius idea for starparty and home use, where he mounted the little LCD inside a little flocked box with an old focusser mounted in the lid with an old eyepiece with all lenses removed bar the objective.
#130 smokin oakum
smokin oakum
Posted 27 February 2008 - 11:47 AM
Hi Neil,
I used all the "standard options" like the 2" draw tube. If I were you I would call Ron at Moonlite, and he will run you through what you need. I didn't place my order online, he took it over the phone, and put my mind at ease with every choice. You will need the install kit, and I used the 1/2" riser and everything I own including stacked barlows, and my MallinCam all come to focus with room to spare.
I think that was Gregs idea, if I remember corectly, and it does sound interesting!
Neil
#131 Alicatt
Alicatt
Posted 27 February 2008 - 12:33 PM
Jack
Now we have to get rid of those cables, a small wireless video transmitter and a fuel cell to power everything.
I was reading aboutcomplaints of people using the Hyperstar and cameras giving diffraction spikes.
#132 Brian Reed
Brian Reed
Posted 27 February 2008 - 01:22 PM
Heres a small 12V wireless unit just I picked up on E-bay. It comes with dual 12V plugs and a pigtail on the sender so powering it to the camera is simple.
#133 HendyPhoto
HendyPhoto
    Sith Lord
Posted 27 February 2008 - 01:29 PM
That's awesome Brian!! Nice find!
Jack your setup is fantastic!! What does the hyperstar make your focal length? What would it make a C14? :waytogo:
#134 Alicatt
Alicatt
Posted 27 February 2008 - 01:30 PM
Thats the kind of thing I was thinking of, can it take the Y/C output of the camera?
#135 mclewis1
mclewis1
    Thread Killer
Posted 27 February 2008 - 01:45 PM
Brian, Interesting little product. Can you post the model number and any other identifying info? I'd like to get the specs on the product.
#136 Brian Reed
Brian Reed
Posted 27 February 2008 - 01:58 PM
The sender is BNC only and the output on the reciever uses a common composite RCA-type video connector.
#137 Brian Reed
Brian Reed
Posted 27 February 2008 - 02:02 PM
It's called "Wireless Ultra-small Camera Kit" model GP-707
EDIT: I scanned the spec sheet.
#138 Astro Sky
Astro Sky
Posted 27 February 2008 - 02:35 PM
Thanks !
bought one today,will be here by this Friday.
Astro Sky Co.
#139 Sky Captain
Sky Captain
    Metal Whisperer
Posted 27 February 2008 - 11:21 PM
Do you have a link?...I did an advanced search and came up empty. Is there a company name or something else to go on?
Thanks.
#140 Astro Sky
Astro Sky
Posted 28 February 2008 - 12:33 AM
Sky Caption,
http://cgi.ebay.com/...em=310026617828
or email me PM
Astro Sky Co.
#141 smokin oakum
smokin oakum
Posted 28 February 2008 - 06:43 AM
Sky Caption,
or email me PM
Astro Sky Co.
That one is sold so he should try THIS ONE!
Clear skies somewhere.
Neil
#142 Alicatt
Alicatt
Posted 28 February 2008 - 06:55 AM
In my late brothers effects there is a box of 2.4GHz TV transmitter/rieceivers,from what I remember they are just boards and not boxed. 12V operation with a video and audio input and 4 channel transmit. He had got them for a project for putting up cctv cameras around our farm but he never finished it.
#143 Sky Captain
Sky Captain
    Metal Whisperer
Posted 29 February 2008 - 12:34 AM
Sky Caption,
or email me PM
Astro Sky Co.
Edited by Astro Sky (02/27/08 10:35 PM)
Neil
Thanks guy's...looks like I missed both. :(
#144 John Wunderlin
John Wunderlin
Posted 28 May 2008 - 03:04 PM
I need to figure out what type of non-slip surface to put on it, so my scope doesn't fall off
Chiming in late- I was just searching on roundtable and intelliscope.
I use a round piece of carpet backing foam purchased at a flooring dealership. Works great and nothing permanently attached to the pretty Roundtable.
Wish I had seen this thread earlier- I recently tested a 'disovery' from the Skyquest group about using the Intelliscope by finding an object with the platform shut off and in the starting position as you posted- this really works well!
