Burgess 1026 refractor and new Eyepieces
1 reply to this topic
#1 Guest_**DONOTDELETE**_*
Posted 18 September 2003 - 03:37 PM
Bill Burgess sent a 1026 for me to test. This is a 102mm f/6 refractor.
He also included 3 new eyepieces to appraise.
The 1026 is an attractive scope with all metal dewcap and collimatable lens cell. The dewcap has dozens of grooves machined inside with a very flat black paint. This is very effective against stray light. The collimatable cell is reminiscent of Takahashi.
I found 3 internal baffles. It uses a 2" rack&pinion focuser with an 1 1/4" adapter. Ar first I found a great deal of play in the focuser. By adjusting 2 set screws, the play was eliminated.
This telescope comes standard with a 2" diagonal and an 8X50 finder.
The telescope is rather beefy and heavier than most telescopes of this size.
The Objective has full multi-coating. Earlier spectrometer tests showed that these objectives have a throughput of better than 98%.
Rings and dovetail and 2 eyepieces are included with the OTA and priced at $299.
The new eyepieces are seperate from the above.
They are a 20mm, 12mm, and 8mm. The 8mm and 12mm have FOVs similar to my 19mm Panoptic. The 20mm has a much wider FOV, probably at 75 degrees. The eyerelief is good on the 20mm and 12mm, but the 8mm may be too tight for eyeglass wearers.
I will be testing the telescope and eyepieces as soon as it clears. I will also do some imaging, though I've come to feel that imaging tends to hide telescope faults rather than accentuate them, unless the aberrations are extreme.
Al M
#2 Guest_**DONOTDELETE**_*
Posted 18 September 2003 - 07:58 PM
Here is an image of the telescope.
Al M
