EQ5 clones
#1
Posted 13 June 2008 - 09:35 AM
#2
Posted 13 June 2008 - 05:43 PM
Are there any real differences between the Sky-Watcher EQ5, Orion SkyView Pro and iOptron EQ5? I could find no information about the iOptron and between the Sky-Watcher and the Orion the second appears to be a better choice. Any advice?
The Orions are, like the Celestron CG5, variants of the original Synta EQ4 and all are made by Synta. All are frankly clones of the Vixen Great Polaris. I don't know doodlum-squat about the Ioptron you mention. The main differences come between the Celestron and the others: Celestron uses their NexStar computer system rather than the SynScan system. NexStar is quite a bit more full featured than SynScan, though that is changing.
The Orions and the Sky-Watchers are pretty much identical.
#3
Posted 13 June 2008 - 11:41 PM
http://www.ioptron.c...TO MOUNTS&id=19
I hope this helps.
CS
Steve
#4
Posted 14 June 2008 - 10:14 AM
The mount from iOptron is know as the SMartStar-PM. Here is a link to the information page:
I hope this helps.
CS
Steve
From the look of it it is definitely Synta, with the Ioptron drive system added.
#5
Posted 29 June 2008 - 09:17 AM
#6
Posted 29 June 2008 - 09:31 AM
The drives that you mentioned SHOULD work. It is possible that you may need to make some modifications, though. If so, they will most likely be rather small and easy.
CS
Steve
#7
Posted 29 June 2008 - 09:48 AM
These variations of the CG-5 actually come from seven different manufacturers that are scattered throughout China. Synta is only one of them.
Well...the Orion is definitely Synta. I'm pert-near shore the Ioptron is too.
#8
Posted 29 June 2008 - 03:10 PM
My interest is in using it for photography.
Posted 29 June 2008 - 06:47 PM
CS
Steve
#10
Posted 30 June 2008 - 08:46 AM
The one from iOptron is coming from their own factory according to one of the executives with whom I have spoken. I have asked this several times and I get the same answer from several staff members.
CS
Steve
The Orion mount, like almost all their other products, comes from Synta.
Yes, the older CG5s needed tweaking, and some folks just like to tweak, but the CG5s that have been sold over the last several years are good to go out of the box. I would, in fact DISCOURAGE tinkering. Unless something is badly wrong, take out of box, hook up guide camera, and go. That being said, you must still be aware of the mount's limitations. It's real good with a C8 at 800 - 1000mm of focal length, go beyond that weight or focal length wise and you may find it not so good (though I have done some right nice shots at 1300mm or so). With a reasonable focal length, I can guide for as long as I want with the ST2000, though I rarely go longer than 15 minutes.
As for QA differences, my experience is that Synta/Orion/Celestron are purty much the same.
#11
Posted 30 June 2008 - 09:56 AM
Doug
