Prism Diagonal = Better Color Correction?
32 replies to this topic
#1 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 02 July 2008 - 07:45 AM
The subject line is a question that comes up every now and then when considering apo refractor performance. I first heard about it in relation to the Zeiss APQ series back in the '90s.
To achieve the very best correction, those scopes require the use of a prism-type star diagonal.
Some apochromatic refractors work best with a mirror diagonal. Others benefit from the refractive properties of a prism. Rarely does the vendor indicate which works best with what.
I've often used a prism with my apo doublet refractors. The dearly departed Tak FS78 was always coupled to a Tak prism 1.25" diagonal and displayed flawless images.
More recently, I tried my Sky-Watcher ED120 with both mirror and prism diagonals and observed that the mirror-type showed slightly more chromatic aberration in the image. Thus, a '70s vintage Celestron 1.25" glass diagonal (original equipment with C8's of the day) has been used with that scope since the testing was done.
This past weekend, I was trying out a used TeleVue 2.5x Barlow with my Megrez 110ED, to see how it compared with a 2.5x Powermate. The Powermate wasn't showing it's best with the Megrez's f/5.95 focal ratio and FPL-51 doublet optics. Sure enough, the old TV 2.5x Barlow (actually 2.8x as measured) worked better than the Powermate. No stopping down to 101mm (f/6.5) was required to sharpen up
the diffraction image.
Just before deciding to bring the scope in for the night, a thought popped into my head :idea:... why not try the
old Celestron 1.25" diagonal with the Megrez, in place of the William Optics 2" dielectric unit? It would be much lighter than the WO diagonal, but how would using a prism work in such a fast ED refractor??
I suspected it wouldn't be pretty. :noway:
The Megrez was aimed at Delta Cygni. Using a 12.5mm Ortho and the TV 2.5x Barlow (147x) showed the companion fairly plainly even in the so-so seeing. Not bad. But, SURPRISE-- switching to the Celestron diagonal revealed Delta's faint companion with slightly less difficulty and it looked like there was reduced red defocus in the primary's image. Markedly less! :jawdrop:
The view was so promising, it tempted me to up the power to 183x and swing over to Epsilon Bootes (Izar) to compare the two diagonals once again.
With the dielectric, the main star's yellowy color showed it's typical ruddy excess at best visual focus. Swapping
to the Celestron diagonal reduced the unfocused red quite a bit. There was a real improvement. :ubetcha:
It was like the FPL51 doublet had been upgraded to FPL52. How best to quantify this?
I'd say the 110ED at f/5.95 using the prism diagonal, showed better correction than the same scope stopped
down to 101mm (f/6.5) using the WO dielectric diagonal. In fact, the Megrez stopped down further to 94mm f/7
displayed about as much c.a. as at full 110mm aperture with the prism. Very surprising. :yay:
The upshot of this improvement is the WO 2" dielectric is now packed away in it's box. :sleepy:
It’s stylish shape and carbon fiber trim sure is impressive looking on the back of the Megrez and delivers a wonderfully bright image. A great piece of kit.
BUT, the smaller, lighter Celestron unit results in significantly reduced spurious color at best focus.
All I can suggest from this observation, is that if you currently own a relatively fast ED doublet refractor, it's
high magnification performance (ie. above 150x) could benefit from switching to a prism-type star diagonal.
But, you won't find out until you try. :thinking:
If you have the chance to pick up a good quality right-angle prism diagonal for a reasonable price, it's fun
to experiment and possibly discover for yourself how to optimize your scope's image quality.
#2 Thomas A Davis
Thomas A Davis
Posted 02 July 2008 - 08:09 AM
Clive,
I would find that I got similar results on my Orion 80ED.
That scope tended to have the red fallout a bit, and to have
some undercorrection. What I seemed to notice was that the
prism added a bit of overcorrection that improved the star
test on the scope. Like you, I found the image to be
sharper with the prism diagonal versus the mirror diagonal.
Since most scopes tend to have a bit of undercorrection,
this does indeed help. Where a refractor is figured with
a bit of overcorrection, and I had one that was this way,
it actually can make things worse. My 90mm fluorite was
better with the mirror diagonal than the prism. What was
a small amount of overcorrection became enough to be
noticed in the final image. While on the 80ED, it helped
both the spherical correction, and improved the red
correction.
#3 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 02 July 2008 - 10:41 AM
Thanks for your input, Tom! :ubetcha:
With the growing popularity of relatively fast, inexpensive ED doublets, perhaps trying out a prism diagonal will result in a cheap way to improve optical performance in some of those scopes. :idea:
Long live the prism diagonal! :bow: :lol:
#4 rick rian
rick rian
    Seeker of Truth(s)
Posted 02 July 2008 - 11:23 AM
Very informative and thought provoking report/comparo, Clive. Much appreciated, I'll have to try some of the things you suggest and see what results I get.
Thanks for posting. :waytogo:
#5 jrbarnett
Posted 02 July 2008 - 11:40 AM
Great, informative, useful post Clive (as usual)!
When I first received my Antares 105mm f/14.4 achromat, I used a 2" Meade Series 5000 dielectric mirror diagonal to test it out. All well and good, but I then swapped in an old 1.25" Vixen prism diagonal to try out the focuser extension tube that shipped with the Antares. On that particular scope I found that the prism diagonal was actually better for higher magnification resolution. On double stars especially companions were more easily spotted using the prism rather than the mirror. I didn't think to check for differences in chromatism though.
Since that swap, the prism diagonal hasn't left the Antares' focuser. Very nice since I hadn't messed with that prism diagonal in a couple of years and it was collecting dust.
#6 Mr Onions
Mr Onions
    Two Time International Photographical Competition Winner
Posted 02 July 2008 - 12:37 PM
Clive,that was {as Rick stated} very informative. I have read that the little Tak prisms are superb.
I wonder how this would compare to a top of the range diagonal?
Im going to have to see if they"re for sale here in UK.
I could use it on the ZS66.
Thankyou, young Clive Gibbons.
Barty Onions.
#7 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 02 July 2008 - 12:49 PM
Cheers to Rick, Jim and Barty. :wavey:
The most disappointing part of the experiment was felt by Pip (see bottom of picture in original posting).
She thought it was feeding time, but was badly mistaken.
:shameonyou:
#8 southmike
southmike
Posted 02 July 2008 - 12:54 PM
lol
I was going to ask what your helper (pip) thought of all that .
#9 JoeBftsplk
JoeBftsplk
Posted 02 July 2008 - 12:55 PM
Thanks for that post, Clive. I've got an FS78 (dear, but not departed) and a Tak prism diagonal. Intended to try them together but with the focal extenders in place (FS78 NSV, I think) and a laser collimater in the prism diagonal, the spot was well off center on the objective. Went back to the 2" adapter w/2" MaxBright and 1.25" Lumicon adapter and the spot fell dead center. Kinda forgot about using the prism on the FS78 after that. The prism does do well on the C6 SCT. Hard to believe it could improve on the FS78/MaxBright images, though.
Based on your report, I'll give it another try. I think the extenders or maybe the laser are the problem. If it's the laser, there's really no collimation issue.
Bob
#10 Tamiji Homma
Tamiji Homma
Posted 02 July 2008 - 12:58 PM
FYI.
Here is a few prism/mirror diagonal test (Baader Planetarium,
WO? (not sure, it says made in Taiwan), Zeiss, Televue).
Diagonal test in Japanese
There are only a few samples but good to have some data points.
Tammy
#11 timmbottoni
timmbottoni
Posted 02 July 2008 - 01:00 PM
Intersting observations! I would be curious to see how a 2" prism compares and how a 1.25" mirror diagonal compares just to see if the size is a factor.
Timm
#12 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 02 July 2008 - 01:05 PM
Hey Bob.
I strongly suspect that the moderately long f/ratio (f/8.1) of the FS78 combined with it's already excellent correction, would result in very little performance difference between a prism or mirror diagonal. Perhaps nothing noticeable.
If you've got the mirror and prism diagonals handy, tho... it would be fun to see if there's any difference. :)
#13 Deep13
Deep13
Posted 02 July 2008 - 01:10 PM
Baader has that 2" prism that they say is more accurate than a mirror. I would have tried it, but the Denk II requires a TV diagonal.
#14 wprince
wprince
Posted 02 July 2008 - 06:33 PM
Don't want to argue, but I notice that my low cost Vixen 1.25" prism will ADD color to the image in my F7 SV85S APO, but not to my F11 Vixen-spec achro. This is only barely noticable on bright daytime observations. Haven't really looked if the prism improves for spherical undecorrection though. I'm still quite inexperienced, but for some reason I just trust my mirror diagonals more. Maybe I need to try a high end prism?
#15 Eddgie
Eddgie
Posted 02 July 2008 - 07:25 PM
I believe that the reason that many refractor manufactures used to include diagonals with their long focal length refractors is because many years ago, the Prism diagonal could be made with very little light loss as opposed to mirror diagonals back then. The were MUCH more efficent than mirrors even as recently as 10 years ago. In a small refractor, every little bit helped...
They were usually recommended for f/10 and above, the reason being that the refraction COULD cause problems with a steep light cone. For faster refractors, mirrors were usually recommended.
Now of course, mirrors with Dielectric coatings can match the light transmission.
I would personally think that it would be more likely that the mirror would contribute less to spectrum disbursal than a prism diagonal.
I still prefer prism diagonals for small scopes because of the efficency. I see no benefit to a dielectric mirror in a small medium speed telescope. I think that Diagonal manufacturing has been pretty much perfected, but Dielectric coating technology is a bit more difficult. I don't know if cheap Dielectric diagonals are any better than even cheap prisms except maybe in build quality.
In 2", the problem with prism is that it is big and heavy, and harder to get three sides perfectly flat than it is to get one surface on a 2" mirror.. But again, I think that the dielectric coatings are quite tricky to get applied evenly. I trust AP and Televue to get it right, but I don't know if I trust some of the mass produced products. If the surface isn't applied correctly, apparently it can build up around the outside and give a result similar to a turned edge on a mirror...
Haven't tried a prims in a fast refractor.. Maybe I will try on in my TV 101. Nah... TV 101 looks 100% color free to me usint Everbright.. I'm happy...
#16 Patricko
Patricko
Posted 03 July 2008 - 12:01 AM
BK7 (borosilicate crown) prisms help correct color, it's a property of the glass.
#17 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 03 July 2008 - 08:03 AM
No problem, Sir. :imawake:
Yup, a prism will change the overall correction of a system, depending on a few factors. The f/ratio of the objective lens is one. The level and type of color correction the objective lens has, is another. As Tom Davis reports, if the objective is slightly undercorrected for spherical aberration, the natural overcorrection a prism adds can help null it out.
In the case of your SV85S, the lens is as visually well corrected as as ED doublet of it's speed can be, so the refractive properties of the prism won't help. In fact, as you saw, it adds some color.
That's why folks have to test for themselves and assess the results on an individual basis.
#18 Herenomore
Herenomore
Posted 03 July 2008 - 08:14 AM
Here's an old thread from the TMB group in which which Tom Back speaks to the matter of prism vs. mirror diagonals:
http://tech.groups.y...l/message/23861
You may find this helpful.
#19 Clive Gibbons
Clive Gibbons
    Mostly Harmless
Posted 03 July 2008 - 08:51 AM
Thanks Tom. :waytogo:
This posting probably sums it up best.
But the way some ED scopes are corrected these days, the prism can actually reduce color (or shift the type of correction), rather than add c.a..
It seems to be one of those factoids that gets overlooked and then "rediscovered".
There's so many more inexpensive ED doublets on the market these days (which are somewhat undercorrected) perhaps the timing is right for those users to reconsider the prism option. :thinking:
#20 HARRISON SCOPES
HARRISON SCOPES
    Vendor-Harrison Telescopes
Posted 05 July 2008 - 09:01 AM
I have the Zeiss / Baader prism on my Tak FS128 and this compared to expensive dielectric versions shows better planetary detail and less scatter.
Ed
#21 HARRISON SCOPES
HARRISON SCOPES
Posted 05 July 2008 - 09:05 AM
Mr Onoins, check the clearance page on www.telescopehouse.com where you will find a Tak prism diagonal very cheap!
Ed
#22 jtpowers
jtpowers
    more clever in the first place
Posted 05 July 2008 - 10:27 AM
Excellent point. I think the lower scatter that prisms can offer has been understated so far.
#23 Luigi
Luigi
Posted 05 July 2008 - 10:49 AM
Ya know, you can get the same aberrations as a prism from a chunk of glass equal in thickness to the ligh path through the prism. This "correcting element" could be used straight through or with a mirror diagonal. Various thicknesses could be offered to fine tune the correction for a particular scope.
#24 niplater
niplater
Posted 05 July 2008 - 02:45 PM
u alright mate have u seen anythink spectacular lately
#25 little_ hubble
little_ hubble
Posted 05 July 2008 - 03:17 PM
i´d like to refer to user rohr`s tests on the ed80:
http://www.astro-for...read.php?t=8621
star tests show a significant improvement in color correction.
obviously it was designed for the use of a prism.
header is: ´with zenit prism almost an apo´
regards, martin
