Searching for that right hard case for NEXSTAR11
32 replies to this topic
#26 rboe
rboe
Posted 09 November 2003 - 09:38 PM
You forgot to mention its' Celestron orange too. That drop down extention is trick. You wouldn't have a brand name would you?
#27 ridurall
ridurall
Posted 09 November 2003 - 10:53 PM
I just went out to my garage to check it but there was no brand name on it. Even did google search for hand truck w/folding nose and the only ones I found were way too high priced. I suggest checking at a big farm supply store that sells feed. If I get to town tomorrow I'll try to remember to check on it.
Ron
#28 Rusty
Rusty
  • In Memoriam
Posted 10 November 2003 - 12:27 AM
More on the JMI case (Or, will the "undocumented features" never end?)
Well, after sitting in my inside storage area undisturbed for three weeks, I tried to open my N11 JMI case to show my sister the scope. The top refused to go beyond about 30 deg without protest. I finally forced it open.
Figuring it was a bent or bowed hinge (which was impossible, because nothing could have damaged the case), I found it was a bowed hinge. I suspect this happened becasue the plastic was still curing, and the stress caused the edge of the case to deform. So, yet another case modification project...I'm SO happy. :flame:
#29 ridurall
ridurall
Posted 10 November 2003 - 04:35 PM
Ok Ron, Checked with the farm store today and found the info on the hand truck. It's a DDI Sack Hand Truck and sells here for $39.96. I also finally found a link to the maker. http://www.ddicorp.c...diweb/pthh3.htm Good luck tracking one down.
#30 rboe
rboe
Posted 10 November 2003 - 10:17 PM
I knew I guy named Ron had to be an gentleman. Many thanks, I owe you one. :bow: :bow:
#31 Rusty
Rusty
  • In Memoriam
Posted 15 November 2003 - 09:57 PM
I like that feed sack hand truck, Ron! Gotta find one.
More on the hinge issue with the JMI case - although the hinge was warped, its main need was not for straightening, but for lubrication - a bit of SuperLube, and it's easy to open.
OT - I finished cutting the foam for my New Improved EP case - anybody need about a bushel of itty-bitty pieces of ground up foam? Note: Forstner bits work great, but they're a teensy bit messy.
#32 ridurall
ridurall
Posted 15 November 2003 - 10:00 PM
Thanks for the idea Rusty. I'm off to lub the hinges on my JMI.
Ron D.
#33 Guest_**DONOTDELETE**_*
Posted 17 November 2003 - 02:33 PM
You can go to JMI's web site and look at the Wheel Upgrade. They look like wheelbarrow tires attached to a bracket on the bottom of the case.
gary
