I stopped short at the RA shaft and the drive.
Removing the drive will be straight forward...the problem is that I know there are a set of bearings inside the RA shaft housing.
I do not know if these were press fit with an arbor or can be removed with a puller (the goal is to remove the shaft).
Being very cautious, I decided to call Meade to get some information about the assembly of this portion of the mount.
I was very suprised with the response I received from their customer service staff.
After explaining my situation, I was told "that system is obsolete"
Wow, I would rather have turned aluminum, cast fitings and brass than the plastic that some of these companys call progress...less I digress.
Anyway, I explained that the Research Series GEM is the same as the current one offered on the Starfinder 16". I was then told that "nothing is interchangable".
I asked to speak to some one in the technical dept. and got dumped into voice mail.
Granted, those that were on staff in the 80's when my system was built are probably gone, and those there now doubtless have any clue about the fine equipment that was produced here in the 80's. ( I am not slamming Meades products...just thier poor product knowledge)
I dont expect a detailed drawing, just an informed idea to help me out since the mount is the same.
It is not like I am asking them to support my old equipment, however, if it is the same GEM, they should have the info I need.
So here is some advice to those of you who have some modern scopes and mounts, order extra parts that will probably wear out, and a tech manual if it is available, otherwise you might end up with an "obsolete system"
Anyone with any experience with the older Meade GEM's that could help out here would be thanked.
