First, I apologize for continuing the autocollimator theory discussion in this thread (I did suggest moving it to another thread back on page 5, but...) Understanding autocollimator theory isn't necessary to use the carefully decollimated primary procedure (which, incidentally, works very well with the Glatter 1mm aperture stop too!) But the theory does explain why the carefully decollimated primary procedure works, so...I wish you guys would translate all this high tech info into simple terms and how the Howie Glatter & Blug, or the Catseye, would apply to these problems or conditions you describe.
When you ask how the Howie Glatter and Blug compares to the Catseye, I suppose you mean the Catseye trio--sight tube, Cheshire and autocollimator. I think this has been covered already in the discussion, but I'll take a few minutes to review the pros and cons again, specifically targeting the three Newtonian alignments.
Primary mirror axial alignment:
The Glatter laser Barlow attachments (includes the 1mm aperture stop, standard Barlow attachment, Blug, and tuBlug) all magnify the primary mirror error 2X with zero parallax error and all are easily visible after dark. The Blug and tuBlug additionally make the error visible from the rear of the scope where adjustments can be made without moving from the back to the front repeatedly (although good vision may be necessary to see the alignment from a distance).
The Catseye BlackCat XL Cheshire eyepiece also magnifies the primary mirror error 2X and the smaller XL series pupil reduces parallax effects. The tool is easily illuminated after dark, but some people have difficulty reading the alignment to a high precision for various reasons (issues with depth of field, triangle to circle calibration, etc.) Cheshire eyepieces are often found combined with sight tubes (the Catseye TeleCat) and this makes them economical and more useful for the other Newtonian alignments.
The Catseye Infinity XL can magnify the primary mirror error 2X, 4X or 8X depending on how it's used and the latency of the reflections. Since it's usually used in conjunction with a Cheshire eyepiece or Barlowed laser, I'll defer to the Catseye Backcat Cheshire for the head to head comparison.
Advantage--too dependent on personal preference to call.
Focuser axial alignment:
The Glatter laser point attachments (includes the 1mm aperture stop and the holographic reticle) magnify the focuser axial error 1X with zero parallax. Using the 1mm aperture stop and carefully decollimating the primary mirror allows the central beam to be collimated to the silhouette reflection of the primary mirror center spot (carried back to the 1mm target face by the laser diffraction pattern) which simplifies focuser axial adjustment similar to the Blug (no need to head back and forth from the front of the scope to the primary mirror for a closer look). The alignment is also easily visible after dark.
The Catseye TeleCat and Infinity XL alignment tools magnify the focuser axial error 1X and 2X (with a CDP) respectively. The read precision with the TeleCat can be compromised because of the focal distance differences, especially when compared to the Infinity XL, and the performance of either tool after dark is diminished to some degree (depending on one's vision and the amount of illumination available).
Advantage--before dark, the Infinity XL. After dark, the Glatter laser with 1mm aperture stop.
Secondary mirror alignment:
The Glatter laser holographic attachment is an excellent tool for evaluating secondary mirror alignment (especially after dark), but can be difficult to read when a combined (tilt/rotation/offset) secondary mirror is present.
The Catseye TeleCat is an excellent tool for evaluating and correcting all types of secondary mirror alignment errors.
Advantage--the Catseye TeleCat combo tool.
You should have almost perfect axial collimation (focuser and primary mirror axes) especially if you use the 1mm aperture stop (assuming it's easily visible from the front aperture of your scope). If you include a TeleCat with the Glatter, and you're willing to take the time to get the specific alignments right, you shouldn't have any problems assessing and correcting the three potential alignment errors.I'm going to be using the HG & Blug. What can I expect? Will I have almost perfect collimation?
