Lanthanum based glass?
#1
Posted 22 December 2008 - 09:30 AM
#2
Posted 22 December 2008 - 09:38 AM
I've read a number of reports regarding lanthanum elements in eyepieces resulting in better performance. Just what type of benefits does this glass type offer over more traditional glass types and is it a real benefit that is noticeable in real world conditions? Thanks.
Quite a few manufacturers--Pentax, for example--use Lanthanum glass elements. The reason? To minimize chromatic abberation in eyepieces. Does it work? Yep.
#3
Posted 22 December 2008 - 09:47 AM
#4
Posted 22 December 2008 - 11:12 AM
#5
Posted 22 December 2008 - 11:14 AM
And simply because it is easier to precision figure and polish a lens with less surface curvature, figure and polish related aberrations "MAY" be less likely to occur. For the same reason a given lenses "POTENTIAL" of achieving a superior scratch/dig surface rating may also be improved by lowering its surface curvature.
So while the chromatic aberration benefit is real (primarily for instances where the flint component of a doublet grouping contains lanthanum oxide), it might also be possible that there are other "POTENTIAL" benefits such as those I have listed above for lanthanum oxide containing lens elements.
Also, since a lens with a high RI bends light to a higher degree with less surface curvature (by definition), this should directly (not just potentially) reduce spherical aberration.
The "power" of one surface of a lens is given by the general formula:
P = 1/FL = C * (N - 1)
Where:
FL = focal length
C = curvature
N = refractive index
From this it can easily be seen that in order to achieve the same power 'P' (and thereby perform the same function) as a lanthanum oxide containing lens element of RI = 1.8 (while maintaining the same focal length), a less expensive lens element of perhaps RI = 1.6 or so would be required to have a greater 'C' (or surface curvature).
#6
Posted 22 December 2008 - 11:41 AM
Kinda makes you wonder why it ain't used in objective lenses.
#7
Posted 22 December 2008 - 11:43 AM
I understand that both the Panoptics and Radians use Lanthanum elements as well.
I believe that it is highly likely that the T5 and T6 Nagler's do likewise, whereas the first generation Nagler's (at least) most probably did not. Lanthanum may have played a large part in TeleVue's being able to downsize the Nagler's, and/or permit FL's like 26 mm and 31 mm which were impossible to earlier generations.
#8
Posted 22 December 2008 - 11:47 AM
Perhaps where the term 'ED' is used in regard to objective lenses, lanthanum is one of the several potential 'ED's' that are available to be chosen as a representative of the 'crown' component of a doublet?
But since ED means 'extra low dispersion', and 'flint' glass is where the high refractive index of lanthanum is most likely to be found of benefit, and on top of this flint glass has the general characteristic of high dispersion, my thinking is quite likely all wet here.
There do exist however both LaK (lanthanum Crown) and LaF (lanthanum flint) types of glasses, but I can't imagine where the benefit of lanthanum would be of much use in a low dispersion application where so many lesser cost glasses would seem to suffice.
#9
Posted 22 December 2008 - 12:03 PM
Kinda makes you wonder why it ain't used in objective lenses.![]()
It was used in the Stellarvue 102ABV doublet...and the result, was quite nice. the problem was manufacturing cost. It cost as much as a triplet to produce.
#10
Posted 22 December 2008 - 12:28 PM
#11
Posted 22 December 2008 - 01:14 PM
It [lanthanum] was used in the Stellarvue 102ABV doublet...and the result, was quite nice. the problem was manufacturing cost. It cost as much as a triplet to produce.
I'm assuming it was used in the flint (or high dispersion) component of the doublet, and not the Crown (low dispersion, possibly even 'ED') component. Do you know if this was the case?
#12
Posted 22 December 2008 - 01:19 PM
I'm assuming it was used in the flint component of the doublet. Do you know if this was the case?
Yes, Larry, you are correct. The SV102ABV is a 102mm f/7.75 doublet apo with OK4 glass for the low-dispersion element, and lanthanum glass for the mating element.
#13
Posted 22 December 2008 - 01:44 PM
... I don't see how it's even relevant to consumers ...
It's relevant, IMO, because there is a deep desire in human nature for there to be an element of mystery or magic in everything. It keeps life interesting and imaginative. So whether it be "FPL-53" or "Lanthanum" or "TV" or "AP" or "Spacewalk" or "Majesty Factor" or even the somewhat clinical "Well executed design", each of these qualities is really nothing more than the "magic element" for the consumer to latch onto. Different folks grab onto different elements as containing the "magic" for them, just depends what sparks one's imagination.
#14
Posted 22 December 2008 - 02:06 PM
Lead is considered highly environmentally unfriendly, and thorium (actually used from roughly 1932 through at least WWII in various military optics) has a radioactive component of decay which makes it undesirable, as well as yellowing the lens with time. Some day lanthanum will probably be found to either be environmentally a disaster to dispose of, or to have some unsafe level of radioactive decay (there are naturally present radioactive isotopes of lanthanum), and another substitute will have to be found which duplicates the same optical properties.
#15
Posted 22 December 2008 - 02:32 PM
The Zeiss Abbe orthos use it as well.
#16
Posted 22 December 2008 - 02:37 PM
Well stated, sir. For that reason people trends to think that the best eyepieces or scope are the hyper-expensives or the discontinued ones.
#17
Posted 22 December 2008 - 02:40 PM
...and Pentax XW...
#18
Posted 22 December 2008 - 02:53 PM
#19
Posted 22 December 2008 - 03:04 PM
#20
Posted 22 December 2008 - 03:07 PM
So what DOESN'T use lanthunum? How about the Stratus line?
I think that the Orion Stratus DOES use Lanthanum glass.
#21
Posted 22 December 2008 - 03:31 PM
I never thought of it that way. I thought it was just an attempt to overlay some objective data on the subjective matter of eyepiece performance. As I said, I don't think this particular datum (does it use lanthanum glass types or not) is helpful for that. Generically, high index glasses are of some interest, however, for the reason I think it was Lawrence who pointed out. However, lanthanum glass is of particular interest in this regard why? Only reason I've ever heard or know about is that the marketing geniuses at Vixen managed to make this rather obscure thing a household name.
#22
Posted 22 December 2008 - 03:42 PM
#23
Posted 22 December 2008 - 06:46 PM
Canon was the first (to my knowledge) to introduce fluorite into their photographic lenses. Who will be the first to do so for telescope eyepieces (and at what 'astronomical' price level)? Will Fluorite eyepieces make the Ethos line appear to be in the 'economy' class?
#24
Posted 22 December 2008 - 08:35 PM
It isn't eyepiece but Baader FFC (FlatField Converter) uses CaF2 element.
It is as good as 4x Powermate if it isn't better. Visually, I can not see difference between FFC and 4x Powermate.
It is excellent barlow lens.
Tammy
#25
Posted 23 December 2008 - 12:07 AM
Thank you guys.
