First Look: Tele Vue 17mm Ethos
#1
Posted 13 March 2009 - 12:23 PM
#2
Posted 13 March 2009 - 01:31 PM
#3
Posted 13 March 2009 - 01:52 PM
#4
Posted 13 March 2009 - 02:07 PM
Maybe that would help us get what many yearn for
#5
Posted 13 March 2009 - 02:31 PM
#6
Posted 13 March 2009 - 04:31 PM
#7
Posted 13 March 2009 - 09:11 PM
Another great writeup, as usual.
BUT! - note what sixela says! The dilemma is at last resolved!
Mike Rapchak Jr.
#8
Posted 13 March 2009 - 10:45 PM
Very well done report. I especially like the mention of Roger Clark's book. I've never seen any book more invaluable for deep sky observing. I got my copy when it was first published and am sure glad I never parted with it, although, somewhat ironically, one could sell it now and almost completely fund an Ethos!
#9
Posted 14 March 2009 - 01:46 AM
It now has replaced my much beloved 20mm T5 which I had considered the best widefield I had ever used in that scope but not any more!! As with the 20mm before the 17 lives in the focuser for most of the night!!
#10
Posted 14 March 2009 - 08:53 AM
But on axis, i still find that the TV plossls are sharper than the nagler or ethos, for small targets. Havent done the comparison on planets yet.
#11
Posted 14 March 2009 - 08:55 AM
In my opinion, the correct way to select the proper eyepiece is to go for the highest power that seeing will support which properly frames the target while taking the sky background to black. Beyond that, contrast is simply lost between the target and the sky and increased magnification becomes counterproductive.
great article Tom... but in your above comment... where do you find that sweet spot? is it by any chance, at 2mm exit pupil?
with so many f5 and f4.5 dobs out there, i can't believe there isn't a 10mm Ethos yet!!!!
thank again for another great review.
david
#12
Posted 14 March 2009 - 12:41 PM
#13
Posted 14 March 2009 - 03:28 PM
My experiences with the 13, 8, and now 17 have been simply amazing. These eyepieces deliver where it counts for me - right at the optic nerve.
Ron
#14
Posted 14 March 2009 - 09:03 PM
In fact, there is quite a bit, and it is easily seen as a bending of telephone poles near the edge of the field when used in a spotting scope during the day.
TeleVue says the angular magnification distortion is nowhere in excess of 1% in the field of view, and my tests confirm that.
Which means, of optical necessity, that rectilinear distortion is significant. At 50 degrees off axis, the 2 curves of RD and AMD deviate by a fair amount. If AMD is controlled (and TV does an exceptional job at that), then RD must be significant.
That, however, is no put-down for an astronomical eyepiece. RD is unnoticeable on a field of stars unless quickly scanning across fields of view, whereas AMD is noticeable quite easily on any extended DSO [on pure stars, AMD would be hard to detect].
What that does mean is that, though the Ethos eyepieces are stunning in the field at night, they are not the absolute best in the field during the day. Eyepieces with less RD would be better for typical daylight, spotting scope, use.
Other than this nitpick, Tom's comments are apropos.
I would also add that I have found that light transmission does not seem to be noticeably less than with eyepieces having half the element count, pointing out that TV has used some fairly exotic coatings here, probably partially explaining the cost.
Hey, TV people, how about a 22?
#15
Posted 15 March 2009 - 09:16 AM
#16
Posted 15 March 2009 - 09:22 AM
Tom said that there was little or no rectilinear distortion in the Ethos.
Don, I intended my statement to mean as compared to say - a panoptic - where the rectilinear distortion is noticeable even at night when scanning starfields.
I'll clarify. Thanks for pointing that out.
The statement now reads:
and while scanning starfields
there's little to no noticable rectilinear distortion to my eye (especially as compared to something like the 22 panoptic)
T
#17
Posted 15 March 2009 - 09:32 AM
david
Hi David, IMO, it depends on the scope, target and sky conditions. 2mm is a good rule of thumb, but not a natural law.
#18
Posted 15 March 2009 - 09:35 AM
But, until Bill Gates and I have more in common, the Ethe will always be beyond my price range.
Too bad, it's a nice EP.
#19
Posted 15 March 2009 - 11:37 AM
I got my first good look through the 8mm Ethos at the PSSG last year and was very impressed with it's clean resolution, particularly with globular clusters.
I attended this year's WSP with the intention of adding a new Ethos to keep my 13mm company. I was fortunate to be able to testdrive the 17mm in both my 22 F/4 StarStructure Telescope and a friend's 5-inch AstroPhysics refractor. While the views were, as Tom says, "Ethos quality", I was finally swayed by the rampant rumor mill trumpeting a forthcoming 21 or 22mm Ethos. So I bought the 8mm (and sold my 9mm t6). I was truly stunned by the 8mm combined with the WSP's legendary seeing. The Pup was easy, Saturn's rings and moons were tack sharp, and M82 was simply loaded with dozens of "sparkling" stellar points, particularly in the star forming region--something I had never seen before in any aperture!
FWIW--I also sold my 20 t5 anticipating my next Ethos acquisition. I'm still on the fence whether or not my 26 t5 (arguably one of my favorite low power widefield eyepieces) will still keep its space in my eyepiece box next to the 31mm t5 if a new 22 Ethos is indeed in the works. If not, the 17 Ethos may eventually win me over, but the 13mm Ethos already delivers 200X and a half degree true fov in my 22SST, and it's a killer view!
#20
Posted 15 March 2009 - 11:47 AM
I've seen stars in M31 with 12.5", at just past mag.17.
Your 22 under the same skies might reach 18.2 or so. Are there any stars in M82 of that magnitude, or do you think you just saw star clusters?
Don
#21
Posted 15 March 2009 - 01:58 PM
Well, I think I'll wait for the $1K 20mm Ethos, since I have the 13mm E. and a 17mm N. I'd like a little more spread for the money laid out.
One problem between the 13mm E and the 17mm E is the difference in focus of 0.66 inches...not exactly handy for swapping back and forth. If the difference in focus is scaled (with the 17mm E needing to be racked in 2/3 inch from the 13mm E) the (putative) 20mm E may be a challange to many low profile focusers to have enough in rack focusing.
On the positive side, if the fieldstop is scaled like the difference between the 13E and 17E, the 20E would be around 35mm, easily doable in a 2 inch format.
#22
Posted 15 March 2009 - 05:05 PM
You know Don, I'm not sure. But I am sure I was seeing lots of tiny stars embedded in M82 because several other observers also saw them. I haven't been able to find a high resolution image of M82 that shows the number of stars we were seeing, but I won't soon forget the view! And I don't think these were foreground stars because they were definitely visible on the galaxy structure--not around the galaxy.So, Vic, do you think you were actually seeing supergiants in M82?
Some of the stellar points seemed to sparkle a bit (these were tiny points reminiscent of the central star in the Ring Nebula when it can be seen with direct vision) and several were visible the next evening long before M82 culminated.
#23
Posted 15 March 2009 - 05:56 PM
So they could have been forground stars or simply chunks of star regions (likely).
Here's a deep photo to compare:
http://www.astrophoto.com/M82.htm
#24
Posted 15 March 2009 - 06:19 PM
They seemed to be associated with the brighter star regions but they definitely appeared stellar (sans diffraction rings). I'm equally puzzled. Like I said, it was the first time I've ever seen anything quite like it. There were too many involved within the galaxy structure (and nothing similar in number away from the galaxy) to all be foreground stars....could have been forground stars or simply chunks of star regions (likely).
If you look at this image (zoomed in), the stars in the left/center of the galaxy are where we were seeing the most sparkles.
http://www.sflorg.co...42406_02_02.jpg
For reference, the star to the left of the brightest star in this image (just on the edge of M82--looks like a foreground star) was easily visible by comparison.
#25
Posted 15 March 2009 - 06:40 PM
