AstroCards?
#1
Posted 24 January 2005 - 09:56 PM
Steve (aka molniyabeer)
#2
Guest_**DONOTDELETE**_*
Posted 24 January 2005 - 10:06 PM
#3
Posted 24 January 2005 - 10:09 PM
#4
Posted 24 January 2005 - 10:39 PM
I added finder circles to mine which correspond to the field of view of the Telrad or finder scope.
A nice alternative to using an atlas at the scope.
Here's a link:
AstroCards
#5
Posted 24 January 2005 - 10:57 PM
Thanks for the link
#6
Posted 25 January 2005 - 10:16 AM
#7
Posted 25 January 2005 - 05:14 PM
#8
Posted 25 January 2005 - 05:23 PM
I bought them for the Messiers. Nice cards. I placed mine in a cheap photo album so they are protected from dew.
Arent they laminated?
#9
Posted 25 January 2005 - 05:41 PM
#10
Posted 25 January 2005 - 05:53 PM
#11
Posted 25 January 2005 - 06:08 PM
Aren't they laminated?
Nope. Just plain cards. I keep mine in a plastic index card box, and I also have the reader. To be honest, I always forget to take them out with me and use my SA2000 instead. BUT , they're really cool for Messier Marathons.
#12
Posted 25 January 2005 - 06:14 PM
#13
Posted 25 January 2005 - 07:57 PM
steve (aka molniyabeer)
#14
Posted 26 January 2005 - 09:14 AM
Checked out the link above the new set is
Set A: Messier Objects Plus
Set B: Finest Deep Sky
Set C: Finest Deep Sky Part 2
I have the older sets which was originally published in 1975 and the ones I currently have are the revised 1998. References were Sky Atlas 2000, Uranometria, amoung others.
Here is the difference.
Set 1: Messier Objects $Finest NGC objects
Set 2: The Finest NGC Objects Part A
Set 3: The Finest Double Stars
Set 4: The Finest NGC, Part B
Set 5: NGC for Larger Scopes
At the time they were going for $7.95
The two that I currently have is the Messier and the Double stars.These cards are 3x5 with observing hints etc. and a small star charts. My joy has been double stars and here is a small card of the finest ones you could check against an atlas. They list the constellations from Andromeda to Vulpecula. Caution these are not laminated and dew might be a problem also he used RA and Dec to locate the listed objects which if you wanted to really know your sky atlas this was how things were done.
Spoke to the author George Kepple who also assisted with the Night Sky Observers Guide; what happen to those neat little cards. Well as things change all the information is now in those 2 books plus more. The Messiers are nice for star hopping since they also add some NGC's but these didn't give you the big picture only the area around the object. In the end the sky atlas, computer star charts and others made these tools a thing of the past and nice to see that some are still being used.
Another observing aid was the the Finder Charts by Brent Wilson if I remember these were the Messier objects, Overlooked objects and another. They were the 6x8 flip charts with telrad circles.
Just reminiscing.
I still have my two sets and are fun to look at.
#15
Posted 27 January 2005 - 07:11 PM
#16
Posted 04 February 2005 - 09:39 PM
Clear Skies.
Steve
Tasco 10 x 50 binocs
Hardin 10" DSH coming in the mail
#17
Posted 05 February 2005 - 01:31 AM
#18
Posted 05 February 2005 - 02:33 PM
I only remember finding one card that had an obvious error or oversight but I honestly don't recall which one at the moment.
For what it's worth, another useful thing to do with the cards is to get a "circle template" and draw circles corresponding to the Telrad or finder scope's field of view on the detail side of the card. Gives a pretty good idea of what you should be seeing.
#19
Posted 05 February 2005 - 07:56 PM
I think I see what you mean but am still puzzled why the publishers felt the need to orient some of the cards so that both maps have north in the same direction (e.g., Set A, 12h-CVn for M94) and others with north inverted between the two maps (e.g., Set A, 12h-CVn for M106). What am I missing in the logic? Wouldn't it make more sense to have both maps oriented consistently on all cards? That way, as long as the left side is oriented to look like the sky, the right side would look like my finder (or be inverted, so long as it's consistent).
With the finder scope/Telrad circles, do you find that you start crowding the illustrations with too many extra circles? Or do you build "star hopping" chains of FOV circles to encompase most/all of the identified objects? Also, would it be more useful to put the Telrad circles on the left side of the card since you may not be able to see the target stars on the right without a lens/magnification? Are the wide-area maps the same scale from card to card?
Regards and clear skies.
Steve
#20
Posted 06 February 2005 - 02:48 AM
I only draw circles on the detail side to give me an idea what I will see in my finder. If you draw the circles with a fine pen it will not crowd out the detail in the chart. On some cards I only have one circle, on others there may be two or three.
The scale is a bit different on some of the cards so I use the tick marks on the border to determine the proper sized circle from the template.
Since I use a Telrad in conjuntion with a powered finder, I find that having the circles on the right side is the way to go. This way I can go from the Telrad to the powered finder (if necessary) to the eyepiece.
