A new refractor concept
#1
Posted 23 June 2009 - 02:34 AM
#2
Posted 23 June 2009 - 04:15 AM
#3
Posted 23 June 2009 - 10:11 AM
#4
Posted 23 June 2009 - 12:23 PM
#5
Posted 23 June 2009 - 12:27 PM
#6
Posted 23 June 2009 - 05:01 PM
There is a new experimental refractor concept, it uses a very weak objective lens which is a single plano convex 100mm aperture imager of around F:40, this is not corrected for color, but if a small achromatic 7X50 binocular objective is placed half way along the focal length, the resultant F:6 image is very free of colour, the difference between the red and blue focus is only about 1mm, the color reduction is many more times than it should be, it can be reduced to 0.4mm by addition of a second lens. It is known as a "Wall Hypochromat", it is not a dialyte or a schup' as there is no flint lens in the system, the color is suppressed not corrected for. There is a little color left in the system and this can be ignored if you are not too fussy, it will make a superb RGB filter scope. The main thing it is very cheap, I have made a 5inch version.The system is in it's infancy and needs to be developed, how about it you ATM's out there. Ref to the Journal of The British Astronomical Association June 2009 vol :jump:119 No3. Wanna know more, discuss it with me.
Hello John,
could you supply the perscription for you lens design ?
when you mention there is no flint in the system.......
what type of glas makes up the second part of the bino
objective ??
also if the final focal ratio of you system is F6 then
colour error has to be less than 0.4mm to even be as good as
a standard achromat.
look forward to further details.
all the best
Ian Robinson.
#7
Posted 24 June 2009 - 02:32 AM
#8
Posted 24 June 2009 - 03:26 AM
#9
Posted 24 June 2009 - 09:57 AM
#10
Posted 24 June 2009 - 10:27 AM
#11
Posted 24 June 2009 - 12:26 PM
-Tim.
#12
Posted 24 June 2009 - 12:28 PM
I assume that focus can also be achieved past both the primary objective and the intermediate lenses, but in this case the aperture is reduced even further to the diameter of the observer's pupil!
#13
Posted 24 June 2009 - 03:24 PM
- Dave
#15
Posted 24 June 2009 - 04:58 PM
Further info Ian, The scope is unique in that it has an enormous depth of focus ranging from infinity to a spot of tape tacked to the front of the Objective, it will even focus on anything inside the objective lens, in this case the ob lens is out of play and only the reduction lens is doing the focusing, however there is a serious loss of aperture if the focus is on an object less than the focal length of the ob lens away. I fold the optics in three by using two flats, but the flats do not have to be high precision, within one wave is quite adequate, easy to make.
Very interesting for sure. What if you wished to use a bit stronger plano convexed lens...and its focal length was shorter...will the system still work accoring to your descriptions?
Rob
#17
Posted 25 June 2009 - 01:43 AM
#18
Posted 25 June 2009 - 01:50 AM
#19
Posted 25 June 2009 - 01:53 AM
#20
Posted 25 June 2009 - 02:00 AM
#21
Posted 25 June 2009 - 02:06 AM
#22
Posted 25 June 2009 - 02:19 AM
#23
Posted 25 June 2009 - 02:35 AM
#24
Posted 25 June 2009 - 08:11 AM
Hi GJJJim, The objective lens is so weak that there would be difficulty figuring it, the Hypo system is very insensitive to errors of figure, but the upside is that only a very shallow sagitta is required on the front surface, easy peasy to make.
Just curious, have you ever ground, polished and figured a mirror or a lens?
#25
Posted 25 June 2009 - 08:21 AM
