Looks very nice but 500$ for one eyepiece is insane
I get my rent paid for less.
/Jake
LOL! Not where I live you don't! Double that at least. (More like 1100).
Great write up David.
Cheers
Jeff
Posted 12 September 2009 - 02:24 PM
/Jake
Posted 04 October 2009 - 12:31 PM
Posted 04 October 2009 - 05:06 PM
I pulled the trigger on the ES14! I ordered it through OPT, so I not only received the Explore Alliance $100 discount, but also the OPT member discount and another OPT temporary discount on top of that!
Posted 04 October 2009 - 05:39 PM
Posted 06 October 2009 - 07:39 PM
Posted 06 October 2009 - 10:00 PM
Posted 06 October 2009 - 10:58 PM
Posted 07 October 2009 - 12:27 AM
I pulled the trigger on the ES14! I ordered it through OPT, so I not only received the Explore Alliance $100 discount, but also the OPT member discount and another OPT temporary discount on top of that! I justified it to the wife as an early Christmas present for myself. (Also, once I described the eyepiece to her, she wanted to observe through it herself.) The estimated delivery date is this coming Tuesday, Oct. 6th.
I will use it in my 10" Newt and probably in my ST80 as well. The ES14 will provide a 1.2 degree TFOV in the 10" at its native magnification of 86x, 43x and 2.3 degrees with a 0.5x focal reducer, 129x and 0.8 degrees at 1.5x (the Owl barlow lens screwed directly onto the EP), and 171x and 0.6 degrees with my Owl 2x Barlow. If I want to use it at 2.5x or 3x, I could use extensions on the Barlow, but that will substantially add to the already considerable weight of the ES14 and a 2" Barlow. There are 2" 3x Barlows out there, and I'm considering that possibility. A 3x Barlow would yield 257X, 0.4 degrees, and a 1mm exit pupil. That's not bad, considering my other eyepieces that have about that magnification have only a 0.2 degree field!
But even the Orion model is about $200, and that is a little steep right after I just bought a multi-hundred dollar eyepiece.
The ES14 will yield a 7 degree TFOV in the ST80, a full degree wider than the 6 degrees through my 2" Owl 30mm! That will be great for observing large nebulae at dark sites, especially if I screw on an OIII or other DSO filter.
I'm not really concerned that the ES14 will only fit in 2" focusers. I would have liked to use it in my other RFTs, but that's OK. I thought I might like to use it on my 150mm Mak, but the ES14 is not really a good eyepiece for that scope, IMHO. The Mak is good for lunar, planetary and double stars, but it is not really the best scope I have for DSO work, and I accept that. I would not like to spend several hundred dollars more to buy the Ethos equivalent just to be able to insert it in 1.25" focusers.
Clear Skies,
Posted 07 October 2009 - 08:11 AM
I don't know if a 0.5 focal reducer will work visually with short focal length systems like an f/5 Newtonian or an ST80. There may be significant focus problems, as these reducers are mainly designed for longer focal length systems like SCTs which have a generous focal range (or for CCD systems). With an unmodified ST80, you can only get around 3.87 degrees of field without a reducer (6.6 degrees with a 2" focuser and the largest 2" field stop of 46mm). You would probably have to go to a 2" focuser to get more from using a ES 14 (it is 2" only), but even if you got a 2" 0.5x reducer to focus, running at f/2.5 is *really* hard on eyepiece performance. Good luck and clear skies to you.
Posted 08 October 2009 - 08:22 AM
Posted 04 November 2009 - 01:36 PM
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
