Mega-mod thread for Zhumell dobs
1610 replies to this topic
#1351 Sam M
Sam M
  • Loc: Maryland
Posted 29 July 2019 - 01:22 AM
So, is the compression ring actually present and the screws are somehow frozen?
The compression ring is nothing more than a thin strip of brass fed into a slot. Many people on here have made their own replacement ring, it isn't overly difficult. The material is readily available at craft or hobby shops.
So, the brass ring is in place.  The problem is that one screw is frozen, (broken off), and the other has very little travel, and I fear could be non functional at any moment.  If not the compression ring, then I'm not sure what the part is called that holds the screws that hold the 2" eyepiece in place?  That's what I need to replace.
#1352 SteveG
SteveG
  • Loc: Seattle, WA
Posted 29 July 2019 - 05:36 PM
It's called a visual back. You can probably get one from any astro store, if not Scopestuff.com.
#1353 Sam M
Sam M
  • Loc: Maryland
Posted 30 July 2019 - 11:00 PM
I've always thought the term 'visual back' only referred to SCTs.  Thanks for clearing that up for me.  I've searched a good bit for an OEM part with no luck.  I didn't see one in stock from Scopestuff, but I just emailed them to see if they have anything.  I emailed Agena already, but no luck, and I haven't found anything that looks promising anywhere else.  At this point, I think I'll wait for  a run of cloudy days, and see if I can get the set screws out and tap the hole.  If that fails, I'll probably just replace the focuser.
#1354 Sam M
Sam M
  • Loc: Maryland
Posted 02 August 2019 - 03:11 PM
Scopestuff doesn’t sell it. They informed me that the visual back and drawtube are a solid piece. So that’s what I’m looking for.
#1355 SteveG
SteveG
  • Loc: Seattle, WA
Posted 05 August 2019 - 05:29 PM
That's too bad. I looked at some pictures of my old GSO dob focuser which is the same as yours, and it does appear that the back & draw-tube are 1 piece. Still, I would drill and tap a new hole. I've done this many times using a 1/4-20 tap and then use a nylon set screw. You can then remove the compression ring completely.
  • Sam M likes this
#1356 Maxtrixbass
Maxtrixbass
  • Loc: Camano Island, WA
Posted 06 September 2019 - 09:28 AM
Many thanks to all for this excellent thread! I have utilized many of the ideas into my z12.
I replaced the base top of the dob stand with a circle from Home Depot which may have helped some, but noticed a much bigger difference when I attached 4 velcro squares (smooth side) between the two plates. It stabilizes it and gives a bit more needed dampening to the rotation.
Also included: internal flocking, light shield, velcro carry straps, telrad, small grab knob for movement while at the eyepiece, balance weights plus slideable magnetized stack of washers with rubber on bottom (helps between 2" and 1.25" eyepiece changes) , and a leveling platform (most of my yard has slight slope). The feet of the dob base are removed and between it and the leveling platform I use 3 small drum practice pads (they look like the telescope vibration suppression pads) which grab a bit better and reduces vibration time a bit.
note the required clouds that rolled in soon as the modded base was complete..
  • halx, Sam M, earlyriser and 3 others like this
#1357 Natdiamond
Natdiamond
Posted 07 September 2019 - 11:39 AM
This is the setup I've been using for several months now on my Z12. The pneumatic tires go over thresholds and up and down stairs & grass very well. It's a $35 Harbor Freight dolly with 8"Pneumatic tires. 2 Ratchet straps around the base. 1 Bungee cord to firmly hold the OTA against it's own base so it doesn't rock back & forth. With these basic modifications to the dolly. The Z12 is Rock Solid when I move it on the dolly!! Meaning when I pull back on the dolly there is no wiggle or empty space. I pull back 1/4" on the dolly and the base lifts off the ground 1/4". Nice and tight.
The 2 brackets (yellow) I made here (below) were for supporting the sides of the base. I noticed with the dolly & 2 straps on the base, it may be putting stress on the sides of the base. Both upwards and downwards. Maybe leading to a weak point down the road. So I cut some matching notches in these 2 top pieces of wood. they are screwed down into a  1" thick piece of wood that was glued & lag bolted to the dolly (lags represented in green).
(Below)-I also felt like since the bottom dolly plate was not flush against the bottom of the round bottom plate of the base (since the base has 3 legs to keep it off of the ground), I insert a piece of wood (yellow) manually every time I move it to prevent any flexing of the bottom of the base. If I put the wood on the dolly 1st, the fit is too tight and the wood gets pushed all the way to the back of the dolly's base plate. I want it as far under the scopes base as I can go. So I slide the dolly under the z12, then push the wood in by hand. Or use my foot to tap it in.
  • Heitman, txmnjim, Blueox4 and 3 others like this
#1358 wdavidsmc
wdavidsmc
  • Loc: Ohio
Posted 09 September 2019 - 04:16 PM
Excellent setup.
I have a question about your setting circle;  what type of "pointer" are you using to show what number your on?
#1359 prototype3a
prototype3a
  • Loc: Christiansburg VA
Posted 10 October 2019 - 10:53 AM
Somewhere in this thread there is a reference to adding an aperture stop to the Zhumell laser collimator.  I chose to machine a small bushing that I inserted into the front of the laser.  I also noticed while I had it apart that the brass bushing on the back of the laser was a very loose fit and it allowed the laser to have a lot of play so I simply removed it and I'm now careful with my setscrew pressure.  I may make a new bushing but I've also been thinking about drilling and tapping 4 new holes for the adjusting setscrews closer to the back of the laser to allow a bit more precision.
In the past, I used to machine VERY small parts and I was actually surprised how tricky this little bushing was to machine despite the part being relatively large.
I did, rather foolishly, make it from aluminum.  I may make a new one from 303 stainless steel.
Edited by prototype3a, 10 October 2019 - 10:54 AM.
#1360 prototype3a
prototype3a
Posted 10 October 2019 - 09:47 PM
Okay.  Maybe I have a picture....
DSCF1266
#1361 halx
halx
    Vendor (DSO Planner)
  • Loc: Albany, California, USA
Posted 30 October 2019 - 09:26 PM
Excellent setup.
Clamp with wire to the bottom board. See the first image.
Though, there is a clever way to have a neat pointer fixed permanently in a convenient spot.
  • wdavidsmc likes this
#1362 halx
halx
Posted 30 October 2019 - 09:36 PM
I have removed everything from the pointer inside but the diode pcb. And using the USB power for it. No need in the screw button and it is hard to break the alignment. See in my blog. Also, with the barlowed laser colimation method the larger beam spot is actually beneficial.
Edited by halx, 13 November 2019 - 01:50 PM.
#1363 earlyriser
earlyriser
  • Loc: Cincinnati
Posted 14 November 2019 - 03:47 PM
Do you have any idea of the weight of the wood circle verses a same size circle cut from 3/4 inch plywood? I figure the plywood will be lighter since it is 1/4 inch thinner. I'm considering building a new mount to cut down on the weight of my AD10, so weight is the main criteria, but buying the pre-made circles would save a lot of work.
#1364 Maxtrixbass
Maxtrixbass
Posted 14 November 2019 - 04:05 PM
The wood circle I used was thicker than the original piece, but the weight wasn't much different. It actually wasn't plywood, but a pine or spruce "cutting board" looking thing and was stiffer overall probably because of its thickness (again, precut, but unfinished from Lowe's). I don't think one piece by itself would make a huge difference weight-wise unless it was significantly different.
#1365 Natdiamond
Natdiamond
Posted 14 November 2019 - 05:12 PM
Excellent setup.
I no longer use the setting circles as I've been having success with the EZ push to device & app. But When I was using it, I wrapped a strip of magnetic tape around the bottom base. Then I took a round magnet and a second hand off of a cheap dollar store clock I took apart. Glued the second hand to the magnet and bent it in an "L" shape. So it would stick straight up, then bend over the numbers on the top plate, but not actually touch the top plate of the base or the numbers. And of course I was able to move the magnetic pointer at will.
#1366 halx
halx
Posted 14 November 2019 - 06:11 PM
If you are using an app for pointing, you don't need a movable hand at all. Having the Az scale on the base board you can make a nice illuminated window in the top board located always conveniently under the eyepiece when you pointing. As there are apps which allow to calibrate the Az Scale after the setup using a single star, so after that the Azimuth value from the app will be always adjusted for your setup orientation. No need to move anything down below or complicate the mechanical construction.
#1367 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 12 January 2020 - 05:56 PM
Bump for CN member asking about mods to mass-produced dobs.
My best mods include a dedicated equatorial platform, a new base, and a filter slide.
Edited by kfiscus, 12 January 2020 - 06:05 PM.
#1368 Edward Swaim
Edward Swaim
  • Loc: Little Rock, Arkansas
Posted 17 January 2020 - 07:56 AM
This is my beat-up Z-10 that I bought off an auction site years ago with no base. This base is made from second hand plywood cabinet doors. It has a platform for finder mounting since the metal was getting messed up from all my reconfiguring and repositioning. The rocker box has a swing-out holder for an iPad mini that gives coordinates for the setting circle and Digital angle gauge.  There’s a hidden cutoff shampoo bottle inside one corner of the base to hold pencils and flashlights.
kids at outreach events love the stickers.
Ed
  • halx, Allanbarth1, Lukes1040 and 1 other like this
#1369 RKK
RKK
  • Loc: Colorado
Posted 17 January 2020 - 10:18 AM
Nicely done Ed.
#1370 halx
halx
Posted 17 January 2020 - 01:06 PM
Good job, Ed! Nice idea with the settings circle in the window as well. Kids should love that feature too, especially if you have a red light mysteriously shining inside grin.gif
From the practical standpoint, I would avoid adding too much weight to the base, especially in an asymmetrical way, especially on a smallish base of a 10". That affects the smoothness of motion in Azimuth.
Also I have removed the similar EPs rack from the side of my z12 base. Heavy EPs are creating that disbalance again, and leaving EPs optics unprotected from the dust rising from the ground and other random stuff falling down from your clothes when you are dancing around the scope is not good for EPs. Kids might also easily bump into them in the dark (me too, actually). I had an outreach case once when one very eager to see shiny goodies little kid used it as a ladder step to try reaching out the EP high above on his own, when I was away (fortunately I stopped using it long before so none of my $300-700 EPs been harmed). Finally when transported it always snugs on other stuff in my car (but my base is for z12 so it's a much tighter fit in the hatch of my Forester). I'm keeping my EPs capped in large zippered pockets of the dedicated fishing vest over my top clothes. That's also 100% preventing the dew on them.
#1371 Edward Swaim
Edward Swaim
Posted 20 January 2020 - 11:31 PM
Worst thing about the weight, besides moving the telescope, is the strain on the pivot bolt when I move the scope from place-to-place. The bronze bushing I have in the base is a little too short and not snug enough, so the wood wears, and the azimuth circle shifts some.
Ed
#1372 RKK
RKK
  • Loc: Colorado
Posted 21 January 2020 - 09:26 AM
Ed,
You might be able to reinforce the attachment point with some epoxy.
#1373 sunrag
sunrag
  • Loc: Carmel, Indiana
Posted 24 January 2020 - 10:32 PM
Has anyone tried these "Tech2000 Transporter" wheelbarrow handles on their Zhumell/Apertura? I contacted the company by email but there was no response. The concept described in their web-page is quite interesting (http://www.tech2000a...m/transporters/) but I am not able to visualize how it is attached to the Dob without any pictures at all. Apparently the wheel barrow handle doubles as an Azimuth turner.
#1374 sunrag
sunrag
Posted 24 January 2020 - 10:50 PM
Sorry, I should have introduced myself first!! My name is Sundaram Raghuraman. I am from Indiana, and just recently got into Astronomy and Telescopes, starting August 2019.
I bought a Apertura AD12 from High Point Scientific 3 months ago, and have been trying to tweak it. Just came across this topic yesterday for the first time and started reading all of it. I am up to page 25 now. Really useful topic with a lot of great ideas.
It has now convinced me that I need to do the following tweaks urgently ! 1) Flocking 2) Secondary mirror milk jug washers 3) upgrade collimation springs with stiffer springs.
Anyways I will be watching this topic almost daily!
Clear skies!
Edited by sunrag, 24 January 2020 - 10:56 PM.
  • sparksinspace likes this
#1375 jessebear
jessebear
  • Loc: Grand Junction, CO
Posted 25 January 2020 - 12:32 AM
This has been a very helpful thread that's given me a lot of ideas for modifications. I was debating between an Apertura/Zhumell 10" or 12" and eventually settled on an AD10 last month. I'd have liked the 12", but in the end I had to go with what would fit in the cargo area of my SUV with two car seats taking up the back. There's also more screws in my shoulder than in the OTA, so weight is an issue.
So far I've only done a few minor things with hardware store supplies and a 3D printer. OTA knob, stiffer mirror springs, rubber feet, zenith stop, and some Bob's Knobs knockoffs. I'm hoping to get around to flocking soon and making a dew shield. I'm planning to mount a Rigel I've had for a while between the focuser and RACI, but I might try to make a Telrad fit if I can design something in the space available. I've also thought about a GLP and maybe piggybacking an Orion 80mm, but I don't want to go too crazy mounting things I don't need.
Thanks for all the advice and great ideas!
  • halx, Sam M and westgl like this
