Orion SkyQuest XT8 Classic Dobsonian Telescope
#26
Posted 07 February 2010 - 09:37 AM
#27
Posted 07 February 2010 - 12:09 PM
My suggestion is having a 32mm, 25mm, 18mm, 14mm, 10mm, 5mm ep's with up to 60 degree fov in your ep case. Now some will suggest a barlow for cost concerns, but if you can afford it get ep's spread out nicely that are parfocal. IMO a barlow is a pain in the rump, however if you can't afford a barlow with a 32mm, 25mm, and a 10mm will cover most of what I stated before.I'm also planning to buy an Orion XT8 and am also thinking of buying 2 accessories that would go with it: a telrad and a planetary EP (the package only has a 25mm which I guess would not be ideal for viewing planets).
Do you guys have suggestions on what eyepiece would perform well with this scope? Or would it be better to buy a 2x barlow lens now and just double the magnification of the 25mm EP provided (instead of buying a separate EP)?
#28
Posted 07 February 2010 - 03:03 PM
You might want to consider the XT8i instead of the XT8. While both will give you great views, the i version comes with some extra accessories you may end up buying anyway which make the $200 extra cost a great value.
The XT8i includes these extra items the XT8 lacks:
- A 9x50 RACI Finder (value $85)
- A 10mm plossl eyepiece and a 25mm plossl - XT8 only has 25mm (value of 10mm plossl $46)
- Intelliscope (not sold separately)
This means you only pay $69 for the Intelliscope feature that gives you push-to technology to find over 14,000 night sky objects.
I really enjoy my RACI finder and I use it with a Telrad. The combination of the two are a lot more powerful and make it easier to find objects than the simple red dot finder that comes with the XT8 even if you don't use the Intelliscope function.
#29
Posted 07 February 2010 - 03:38 PM
#30
Posted 07 February 2010 - 11:16 PM
I got a couple of Burgess/TMB planetaries, and will probably get another, slightly higher power for when seeing allows. Astronomics has them for less than $60 and a little discount for entering your user id from here. They seem really good for the price. I just ordered a Meade 4000 QX 2" 36mm from adorama.com for $50 and free shipping. I don't know how long that price will last. I've been told that eyepiece works well in our scopes for DSO, although I haven't looked through one. I saw the low price and just took a chance.
#31
Posted 08 February 2010 - 02:53 AM
#32
Posted 08 February 2010 - 09:23 AM
#33
Posted 08 February 2010 - 09:32 AM
#34
Posted 08 February 2010 - 10:18 AM
#35
Posted 08 February 2010 - 11:09 AM
Sounds like a good plan, however dont underestimate the importance of an observing chair. Keep that high on your list.
I would get the barlow first though.
#36
Posted 08 February 2010 - 05:34 PM
#37
Posted 08 February 2010 - 10:05 PM
I'd also like to second the idea that about a 7mm planetary eyepiece is probably the ideal one to have in these scopes if you only get one. The more I think about it, I'm going to get that one first, then get a 3 or 4 later.
