Samsung SDC-435 = 8.5 seconds integration @ $153
179 replies to this topic
#176 RickShelton
RickShelton
Posted 20 August 2010 - 06:08 PM
My thoughts exactly! Well, will see how long it takes to get here from Korea!
I have one the way as well, if not for using paypal I would have been a little leery of ordering something from Korea...
Rick
#177 mclewis1
mclewis1
    Thread Killer
Posted 20 August 2010 - 06:10 PM
I'll be waiting ... :gotpopcorn:
:grin:
#178 ccs_hello
ccs_hello
Posted 20 August 2010 - 06:28 PM
re: PAL 50Hz videocams used in NTSC-M 60Hz countries
A commonly seen problem is the AC beat 60-50Hz = 10Hz which shows up in the screen as a (slightly brighter) wide bar slowly scrolling (up or down). This is independent of if any device (including the TV/video monitor) is AC powered or not. If using AC power, the interference is even more severe. Without AC supply, it has something to do with the "grounding coupled signal". Very often the ground will influence/inject the 60Hz sine wave (if NTSC countries) into the signal path.
P.S. the ground is not 0 volt potential. It is also connected to the Neutral (the White-colored wire) in the house power panel as well as in all power distribution substations and power plants.
P.S., sometimes you can even hear the harmonics of 10Hz if the volume is not lowered.
P.S. the story is also true if using 60Hz videocams in 50Hz countries
Clear Skies!
ccs_hello
#179 Tele
Tele
Posted 20 August 2010 - 10:41 PM
Thanks Scout72,
I think I'm going to try to stay with the NTSC stuff. I am also over here in Afghanistan right now so I'll give a couple of local venders a try at getting it for me ;)
Clear skies
#180 Dragon Man
Dragon Man
Posted 21 August 2010 - 12:31 AM
Afghanistan is on the Pal system so you might not find any NTSC products over there
http://en.wikipedia....-NTSC-SECAM.svg
