What's the point of a Schmidt-Newtonian?
#1
Posted 01 April 2005 - 07:03 PM
So a Newtonian exhibits coma (and astigmatism?) off-axis. Fine. So you add a Schmidt corrector, and it *still* exhibits coma and astigmatism (a bit less perhaps)? What's the benefit? Is it that you can use a spherical primary?
What benefit is acheived (other than having a cool and different optical configuration than your neighbor) by creating a SN?
ie, given a 6" f/5 Newt, say, and a 6" f/5 SN, what would you expect to be different in the image quiality produced by these two OTAs? I would assume that the fast Newt had a parabolized mirror. Note that the SN OTA is likely to cost about twice as much.
What gives?
Jimbo
#2
Posted 01 April 2005 - 08:07 PM
Reducing coma by half is a significant factor, especially for imaging. It's also much easier (read less expensive) to produce a well-figured spherical mirror at F/5 and below than a well-figured paraboloid. The SN's are twice the cost of the least expensive Newts at similar apertures - but they are less expensive than would be a Newt of similar quality even though the SN can perform better.
#3
Posted 01 April 2005 - 08:58 PM
From the spot diagrams in Telescope Optics, it wasn't clear that the corrector was reducing coma by as large a factor as half.
OK, so it's probably worth it to pick up a SN, all other things being equal, as long as the price was more or less right.
Jimbo
#4
Posted 01 April 2005 - 11:55 PM
This time I would like to point out that coma is not only a product of focal ratio, but that it is also linear. For example, coma is much worse in a 12-inch f/4 than it is in a 4-inch f/4.
Just a thought.
Bill
#5
Posted 02 April 2005 - 12:58 AM
I'm not trying to start a flamewar; I'm trying to get it.
What gives?
Jimbo
I don't know. An f/5 Newtonian with a halfway decent Paraboloidal mirror and a Paracorr would perform about as well or perhaps better than the Schmidt-Newtonian, and at a lower cost (although the Newtonian would now be f/5.75 instead of f/5). In addition, with the regular Newtonian, you wouldn't have the problems of dew on the corrector plate or lack of good ventilation for fan-assisted cooling. Clear skies to you.
#6
Posted 02 April 2005 - 02:33 PM
Also, diffraction spikes-haters should love the fact that a Schmidt-N does not need a spider to hold the secondary.
Not that I care in the least which one might be considered "best design".
#7
Guest_**DONOTDELETE**_*
Posted 03 April 2005 - 12:46 AM
Also, the SN series is supposed to have a wide, flat field for astrophotography (I don't really know how the Meade Schmidt corrector does that). A field-flattener/coma-corrector/focal-reducer for a fast Newt is a pretty specialized piece of optics (read: lots of tinkering/scope matching, and $$$).
The low (after-market) price of the Meade is due to the sub-par plastic focuser, un-flocked tube, mirror retaining clips, and unnecessarily large secondary mirror. Otherwise it would be worth close to a Mak Newt!
-- William
#8
Posted 03 April 2005 - 07:40 AM
The Meade SN6 goes for $220 shipped on AstroMart. This is less than the price of a Paracorr (even on AstroMart). Obviously, Paracorr wins when the aperture (and OTA weight) goes up.
Hi, William.
The cost advantage remains at larger apertures; a 10" parabolic mirror of comparable quality at F/4 would cost more than a complete 10" SN optical tube, and with a Paracorr would still be slower than an F/4 SN. It'd take a paraboloid at F/3.5 to achieve F/4 with a Paracorr. Prices go up quickly below F/5.
#9
Posted 03 April 2005 - 12:49 PM
It's clear to me that I'd need a Paracorr for photography with a 6" f/5 Newt, but I'm not sure whether the Schmidt corrector is going to correct the edge-of-field stars enough to obviate the need for a Paracorr on the SN.
Jimbo
#10
Posted 03 April 2005 - 01:02 PM
do you think that I'll still need a Paracorr if I am shooting through a 6" f/5 SN?
Jimbo
Hi, Jimbo.
The Schmidt corrector is to correct for the spherical primary. The reduction in coma is because spherical primaries have less of it than do paraboloids.
I've never shot 35mm so I don't have any experience there. I can say that S&T did a review on the LXD55 not long after it came out and the review included a couple of 35mm shots taken with them. I don't remeber noticing coma in those.
#11
Posted 03 April 2005 - 07:02 PM
I'd guess that the bigger f/4 SN could still use a Paracorr. The 6" f/5 might have a flat-enough, low-coma field as-is, but I haven't tried it myself either. (I noticed less field curvature visually than in my 8" f/6 Newt, but I can't swear to it.) It's certainly easier to do than with most Newts since the SN focal plane is (by design) a whopping 6.5" outside the tube, and Meade includes adaptors with the package. The only drawback to the 6" is the lack of choice in after-market 2" focusers for a 7"OD tube (though Moonlite does make a 7"D plate).
Regarding collimation, it's important to have the corrector plate perfectly lined up at the factory, since it's not user-collimatable. The SN comes in a steel tube which should help.
-- William
#12
Posted 04 April 2005 - 03:12 AM
Here's a followup question; if I'm going to use the OTA for photography, and specifically 35mm film photography (so I need as wide and flat field of view as possible), do you think that I'll still need a Paracorr if I am shooting through a 6" f/5 SN?
Jimbo
It lloks like a good choice because the 6" SN has a nice, wide, sharp flat field visually, so photographically it should be the same.
And no, the paracorr would not be of any use on it.
#13
Posted 12 April 2005 - 04:42 PM
The SN10 has one big problem that can be fixed with barnyard engineering - the tube is partially open, which is worse than wide-open (Newt) or closed (SCT). It takes quite some time for the boundary layer on the mirror to disperse. Some impatient owners install computer fans to the rear end to speed it along.
-drl
-drl
#14
Posted 13 April 2005 - 08:35 AM
Jimbo
I will hazard a slightly educated guess and say that it could even be worse...
Hint: If you really want to cancel coma and astigmatism with a 10in f/4 Schmidt Newtonian, just move the Schmidt corrector away from the primary mirror, a distance 80in should do the trick. The only drawback will be the not so compact OTA.
#15
Posted 13 April 2005 - 09:33 AM
Jimbo
#16
Posted 13 April 2005 - 10:23 AM
and a curved focal plane.
Nothing that a small positive lens with good anti-reflection coatings near the captor can't cure... As a bonus, the OTA gets 5mm-10mm shorter
#17
Posted 12 May 2005 - 04:32 PM
Rodger
#18
Posted 13 May 2005 - 12:00 PM
#19
Posted 13 May 2005 - 01:00 PM
Colour me puzzled. First, there's nothing that would make images "soft" in a newtonian, and these days in 8" even both Synta and GSO make pretty decent mirrors (certainly as good as the Meade primaries tend to be).or the image softness of a fast and cheap Newtonian reflector. Somebody mentioned that making a decent Schmidt corrector lens is cheaper than making a truly great reflector mirror.
Secondly, you still need a good mirror in that Schmidt-Newtonian. These days, I doubt it's the actual mirror figuring curve that limits mirror performance for the mass-produced mirrors, at least at these sizes.
Not to diss the Schmidt-Newtonian - it's a fine design, and certainly with design trade-offs that are different from those of a straight newtonian.
But I feel you're overstating the "problems" with straight newtonians (certainly at 8", where there are quie a few scopes with mirrors that aren't much faster than f/6).
#20
Posted 13 May 2005 - 01:02 PM
The major advantage of the S-N design is a relatively flat, well corrected, wide TFOV. For visual use, introduction of a Paracorr into a Newtonian system introduces a lot more air/glass surfaces that need good coatings.
And in what way does a Schmidt corrector not have air-to-glass surfaces, and how does it not need a good figure and excellent coatings?
#21
Posted 13 May 2005 - 03:44 PM
Sealing off the tube to where a cooling fan is not necessary is a possible third reason for choosing the SNT over a Newtonian. My reason was totally price for performance. The magnification possible with an 8" SNT exceeds whatever seeing conditions I am likely to encounter. That SCT-8 LXD75 sure looked tempting, but how often could I use its 400X magnification capabilities on the supplied mount under typical seeing conditions?
I know that there is more capability in Newtonians than mass manufacturers get out of them. The thing is that Schmidt-Newtonians can be f/4 and take more magnification before image breakdown compared to a fast Newtonian. Remember, I said utmost VERSATILITY was important.....don't want to be hauling both a fast scope and a long focus scope to the viewing site. I am talking equal prices here. Custom Newtonian reflectors and APO refractors are not in my price range:help:, and show me one that is f/4 fast AND is able to get around 300X power for $999(delivered) with a limiting magnitude of 14 AND on a Go To mount. If things work out for Meade, I am sure Celestron and Orion will hop on the SNT/MNT bandwagon with Meade and Intes. The Orion SkyView Pro 6LT 1200mm f/8 Newtonian reflector at $548 looks like an interim step to me (it gets the mag on the cheap), but it can't give the mag AND the bright wide view as well as any good SNT. An SNT/MNT can go high mag AND wide/bright on the cheap, and that was the bottom line for me. How it gets there really wasn't the point for me. The point was that I saved enough to stay stocked up on Lindemans Bin 50 Shiraz and Bin 45 Cabernet-Sauvignon while being able to view anything worth seeing, and that improves any view. That's two more items with a really great price/performance ratio. (Before buying your next $$$$ eyepiece, buy a case of both and see if you didn't have more fun on a starry night. The Lindemans Chardonnay really kicks derrierre also, but more for any SRF's out there. A crisp wine for crisp views. I suggest Walnut Crest Merlot for the Newtonian/Achromatic crowd. Very affordable, but far from bad.)
The MNT and SNT seem so similar that they should be basically considered the same type of spin on a Newtonian. A bit of a thickness and curvature difference on the corrector plate, but the aim is the same.....reduce the price well below that of an SCT and get a wider aperture.
#22
Posted 14 May 2005 - 02:11 AM
The front corrector plate of an SNT allows a mirror mount with no mirror vanes to cause diffraction loss.
And te central obstruction is larger, which causes much more diffraction loss than spider vanes (and curved vanes distribute the energy evenly in all directions, before we take another tangent).
Granted.Coma will be half in a well designed Schmidt-Newtonian.
And cooling behaviour is worse, much worse, so you get to enjoy your currents for longerWith a well insulated tube, internal air currents should be the same as a refractor.
If you believe they have all the answers, yes.The fact that Meade put their faith more in the Schmidt-Newtonian design (and compound designs in general) says something for the all around practicality.
I'm sure all those SCT owners that have a Lymax fan will now chuck it over the fence.Sealing off the tube to where a cooling fan is not necessary
Mass manufacturers get a lot out of them these days, and as I said before, there's no indication that the mirrors from Meade and Celestron are typically much better than the GSO/Synta mirrors these days (though undoubtedly the chance of getting a lemon may be less large).I know that there is more capability in Newtonians than mass manufacturers get out of them.
Granted, it will show less coma - and that is one of the reasons for the design. But an f/4.46 with a Paracorr is also a fine beast, and f/6 newtonians aren't *that* long in focal length either.The thing is that Schmidt-Newtonians can be f/4 and take more magnification before image breakdown compared to a fast Newtonian.
If you want very wide fields of view for your aperture, then yes, it's a fine design. It all depends on what you want to view.
And coma is not "image breakdown". The amount of coma in the centre of field of a well collimated newtonian is zero.
Look, it's pointless: you made a fine choice, which I'm not going to diss, but you're over-rationalising by dissing other designs, and while it's a fine way to resolve cognitive dissonance, it's not based on reality.
#23
Posted 14 May 2005 - 01:18 PM
#24
Posted 14 May 2005 - 05:10 PM
Closing the tube was listed as a plus by Meade. I totally agree. If you thoroughly insulate the body (which is ugly, adds to cost, and does not sell scopes......so Meade will NOT do it in an econo scope), then you stop significant internal currents. Preventing need for disassembly for internal cleaning is another big plus. Fans add vibtration, which hurts image quality at high magnification, and if you have such a slow cooldown that everything stays close in temp inside, then that's good. Most heat loss would then be through the front element since it is the only uninsulated part of the tube, which gives you a FREE dew suppression system for several hours as long as it's backed up with a well insulated dew shield/lens hood. It's something I will try.
There was a thread that told how to maximize reflector performance. Insulating the tube internally with cork sheeting (this looks best from an outside view) or making the tube out of heavy round cardboard will insulate the tube and slow down tube current generation. Steel and aluminum tubes are bad, bad, bad for temperature stability. Scope tubes can be wrapped from the outside with sleeping bag ground pad insulation material, an old wool army blanket, or other suitable material. An open Newtonian will still need cooling fans in spite of insulating the tube. An insulated tube should need less air through it, though, as current generation is less.
I knew about the curved vanes. The diffraction is still there, but just spread equally over the entire image. The central mirror in the SN-8 is not as big as you fear. It looks about 25% of aperture, not 35%.
Internal air currents are caused by internal temperature DIFFERENCES. This is caused by UNEVEN COOLDOWN of internal components and being open to outside air at a different temperature. If you seal the tube and slow cooldown, then air currents are proportinally slowed. Therefore, no need to cooldown to ambient air temperature. At some point, the currents will become unnoticeable. That point will get a name from somebody, and be another point for discussion. When a scope is cooled down, the point is to equilibriate the temperature of all components, along with the outside air. A highly insulated OTA will be self equilibriated internally as it VERY SLOWLY cools down. It can do this by thermal radiation without the need of swift convective air current cooling. Anybody who fooled with vacuum power tubes knows that the tube plates are in a hard vacuum and have no air cooling possible. They cool by thermal radiation off of dark plates. Very little is off the hot tube envelope, or the tube would be ruined quickly. The tube's glass envelope should be kept clean to allow this thermal radiation to occur. The front lens of a compound telescope will be a major radiant heat loss point when the rest of the OTA is well insulated. I am guessing that dew can be kept off for many hours as long as enough internal heat energy is available. It will also lessen the need for any external dew suppression energy needed later, so a very small battery powered unit will be sufficient. Meade places the dew heater around the perimeter of the glass lens in their new RCX400 series of SCT's. A few wraps of electrically insulated nichrome wire around the end of my SNT should give me a dew heater for almost no cost. If you wrap the ENTIRE OTA under the outer insulation and install a temperature sensing circuit to control the heat supplied, then you can keep the OTA at a constant temperature and forget about any cooldown whatsoever, or allow cooldown only to a point to prevent dew from forming. This varies with relative humidity, but cheap electronic sensing, servo and logic circuits already exist that are easily implemented. If somebody hasn't already done this, I am REALLY surprised. All the technology is just sitting there.
I view my new scope as a Modkateer platform. Getting it to outperform my brother's 10" Orion reflector on planets shouldn't be too difficult. He has added a cooling fan, but admits it is still far from optimal for the planets and lunar observing. Turbulent air is so bad where he lives (he typically looks over a couple of miles of open ground, then a river reservoir with cooler air over it) that he needs a scope that cuts a narrower optical path. Plus, he lives in a small town with light pollution. Something like an Intes MN56 or MN66 or Orion 5" Mak would serve him better for the planets and moon.
I have a Zuiko 65-200 f/4 zoom that has as much or more contrast than any of my Zuiko prime telephoto lenses. I can shoot straight into the sun with less flaring than with my prime lenses. Since the zoom has about twice as many elements, I would not think this would be the case. Obviously, other things come into play. I am thinking that my lens and mirror coatings and alignments will play a much bigger part than vanes or central obstructions or how wide the aperture, etc. The fact remains that Astronomics rated the SN-8 as great for planets while the SN-10 was knocked down 3 points to fair. I called before I bought and the SN-8 was recommended. If most 10" Newtonians perform like the Orion 10" does for planets, then I do not want a 10" Newtonian. Their ratings for the SN-10 would match my ratings for the Orion 10" from what I saw with my own eyes. It, of course, does better for DSO work.
Cooling down a rear mirror while heating up the front lens element is not what I call an elegant solution in an SCT. Keeping everything at a relatively constant temperature (indexed to relative humidity) sufficiently high enough to prevent dew formation looks like the more elegant solution to me. It might not LOOK elegant after I'm done, however. I am guessing that few optical design departments know how to integrate electronic sensing, servo and logic circuitry into something that would work right without hiring an outside engineer. My years of biomedical engineering might pay off here, and this is simple stuff compared to what goes on inside medical equipment. The SN-8 is a much better platform for experimenting with my ideas due to its sealed nature. Any MCT or SCT owner can run with those ideas as well. We have foam rubber insulators for our beer cans, why not for OTA's?
Now I know what to do with that pair of Orvis neoprene waders that don't fit me. Will add impact resistance as well.....and the olive green color will be military approved.
#25
Posted 15 May 2005 - 10:40 AM
The POINT of a SCHMIDT-NEWTONIAN is: 1) Produce a fast aperture with a flat, sharp field. 2) Reduce coma so that the magnification can be pushed up to compensate for the loss of focal length necessary for a fast aperture. 3) Close the OTA to reduce air currents and protect the optics (the average user does not want to clean and recollimate scopes on a frequent basis). 4) Allow the scope to take the place of both a long and short focal length standard Newtonian. 5) Do the above at a cost far below buying both a short and long focus Newtonian. 6) Reduce the size below that of a long focus Newtonian for better portability. 7) Be less expensive than the Cassegrain designs.
It is a single scope that can be used for astrophotography, DSO, planets/lunar, and star clusters while slightly underperforming the Cassegrain types for high magnification work, ruggedness and portability, but saving the purchaser some money to make up for it. Add a high quality Cassegrain design of long focal length over twice that of your Schmidt-Newtonian, and you are pretty well covered for everything you would want to do. The bottom line is that the SNT just makes a good all-rounder for those not needing the ultimate portability of a Cassegrain design. There is not a single thing it does better than any other scope, it just does a lot of things reasonably well at a fairly low price.
BTW, what was the first country to produce an MNT or SNT? I would guess the Russians, as their specialty seems to be compound designs. SCT and MCT designs have begun to dominate the long focus arena, and MNT and SNT designs will probably come to dominate the short focus arena for those who are moving up from cheap achromatic refractors and Dobsonian reflectors. The fact that truly great APO refractors and parabolic reflectors can be turned out at high cost will not sway the majority of amateurs looking for the highest performance at the lowest cost in long and short focus scopes. It is the age of the compound scope for serious amateurs with limited funds. The truly impoverished will stick to achromats and Newtonians. Those who can afford the best APO's and custom Newtonians will probably not be totally swayed away from them. However, a compound scope can be their travel scope.
Compound scopes seem to seek a balance of all things. That is why they incorporate lens and mirrors to draw out advantages of both worlds. Their rising popularity says that the reasoning in valid for most users. The real competition of the SNT/MNT is the SCT or MCT, not the Newtonian. I had already decided that I was getting a compound scope. Newtonians and refractors had already been dropped from my list. Change is inevitable, and standard refractors and reflectors have seen their heyday. It's the age of the compound scope for most serious amateur astronomers. You can't browse the high end amateur models from Meade and Celestron or the Russians without that fact hitting you in the face. Amateurs who buy high quality at a reasonable cost buy from those three sources more than any other, from what I am seeing.
