Thank you everyone!!
Craig, I made a modification to the camera to eliminate the amp glow. The 350D keeps the sensor amplifier active during the long exposures and this produces the glow, don't know exactly why. We need the amplifier active only at the beginning of the exposure and during the readout, but not during the exposure. I made a circuit which feeds the sensor with 3.5V during the exposure, instead of 5V. This makes the amplifier to be inactive and the glow is not produced. The circuit is activated by a switching signal which is taken from the camera board.
The first to make an amp-off cicuit for a Canon 300D was Mike Kudenov. I asked him about the possibility of doing the mod for the 350D. He gave very valuable information and helped me a lot, although he hasn't finished his mod yet. A bit later I knew about the work of a guy from the Netherlands who had done the amp-off mod for the 350D succesfully, Cas Wilders. He gave me the idea where to take the switching signal from. However, my amp-off circuit is different from Cas' circuit, it is based on Mike's circuit for the 300D, just a bit different. Here you have links with more information about the mod:
http://glogg.jupiter...off/amp-off.asp
http://members.chello.nl/c.wilders/
And here you have a link to a post from a spanish forum where I published my work. I have used google translator to translate it to english (sorry the translation is far from being perfect):
http://translate.goo...684&sl=es&tl=en
gatsbyiv, nickatnight, Erik: don't know if you know PixInsight. The processing philosophy and the tools is radically different from PS, so maybe you don't undestand part of my processing workflow. If you need more information please tell me:
1) Callibration and stacking of the exposures with DSS: I got three images: 30", 90" and 360".
Starting of processing with PixInsight:
2) Color calibration: doing a preview taking only M81. I assumed all the flux from M81 must be neutral (it is a good assumption for Sa, Sb, Sc, Scd, SBa, SBb, SBc and SBcd galaxies). With this step I got the coefficients to apply to the G and B channels. I did this for the three images.
3) Background neutralization: this is a PixInsight tool, you need to choose a preview from an area where there is only background. I did this for the three images.
4) HDR Composition of the 3 images: this is another Pixinsight tool. I got an only image with the contribution from the 3 images with different exposure times.
5) Masked Stretch Transform: this tool does an iterative stretch of the histogram masking the image with its inverted luminance at each iteration. This prevents the stars from growing up and the brightest parts from getting saturated.
6) At this stage I created a mask for the galaxies and the stars and their halos. This is the trickiest part. Pixinsight has a powerful tool based on wavelets transformation to create masks. With this tool you can separate parts of the image based on their scales. So I firstly made a mask for the stars, then a mask for the star halos, and then a mask for the galaxies and then combined them all. All this stuff took me several hours, you have the tools but you need to fine tune the paremeters to create a mask with the desired sizes for all the objects to protect in the image.
7) With the mask applied to the image, I did a strong histogram stretch and the IFN came up... and also a lot of noise.
8) Noise reduction with ACDNR. First on the chrominance, and then on the luminance of the image.
9) Final histogram adjust.
10) Soft stars reduction with a star mask and a morphological filter.
11) Final touch, color saturation: first to the stars and after to the galaxies, both steps with masks.
Sergi
