EQ mount in Alt-Az mode?
Started by
m00nless
, May 18 2010 10:42 PM
10 replies to this topic
#1
Posted 18 May 2010 - 10:42 PM
Is this possible to use an equatorial mount such as the Sky-Watcher EQ3-2 in alt-azimuth mode?
#2
Posted 19 May 2010 - 07:23 AM
I converted a CG4 from GEM to Alt Az. It involved temporarily removing a piece and a little grinding. Here is pic which shows the piece removed and where I removed a bit of material. I have plenty of other pics if you want to see more of the process.
#3
Posted 19 May 2010 - 11:23 AM
"Sky", I think the removed part on your photo exists and is the same on the EQ3-2 too, but why the grinding?
#4
Posted 19 May 2010 - 12:53 PM
There is a tab, which can be seen in the photo, that is is used to set the local latitude when using the scope in the equatorial mode. That tab only allowed the mount to move so far. I had to remove a bit of metal (using a dremel like tool) to allow the tab to swing forward enough to allow the mount to become Alt-Az.
#5
Posted 21 May 2010 - 08:31 AM
Ouranos, can u point me to your other photos for the conversion?
Many thanks!
Many thanks!
#9
Posted 21 May 2010 - 08:42 PM
It really is a simple process, one I learned about right here on CN. The only "difficult" part was removing just enough metal to allow the tab (seen above sticking out like a tongue) to swing past the stop. A little work w/ the dremel did the trick.
#10
Posted 21 May 2010 - 09:44 PM
Yup. I just did mine about half and hour ago and then saw your pics. Many thanks anyway and they will help others who want to do the conversion.
Cheers!
Cheers!
#11
Posted 21 May 2010 - 10:34 PM
I've been very happy with my Vixen Super Polaris mount in alt-azimuth mode. All you need to do with the SP is loosen one screw, shift the mount to alt-azimuth position, and tighten the screw back up.
Dave
Dave
