NexStar8i and Apogee 2" SCT Focuser
2 replies to this topic
#1 Guest_**DONOTDELETE**_*
Posted 10 December 2003 - 07:24 AM
I may be able to acquire an Apogee 2" SCT Crayford focuser for my 8i but wondered whether or not I'd then face more problems? In particular I was concerned about the clearance between the scope base and focuser/diagonal? I'm assuming the focuser must be attached to the scope directly and then the diagonal could be inserted into the focuser? If so wouldn't this simply stop the scope being able to slew towards polaris etc? I'm going to fire off an email to Apogee makers but wanted to check here to see if I could get a quick clarification?
Thanks in advance
#2 jrcrilly
jrcrilly
    Refractor wienie no more
Posted 10 December 2003 - 08:21 AM
It's an issue but there's a solution. Check out Ray's Brackets at www.buyastrostuff.com - they permit moving the optical tube forward which solves both the clearance and the balance problems when mounting heavy accessories on the back.
#3 Guest_**DONOTDELETE**_*
Posted 10 December 2003 - 11:10 AM
Thanks, I suspected as much. One accessory after an another.
This one goes a little further than I would feel comfortable with.
