Carl Zeiss Jena NVA DF 7x40 Binoculars
#1
Posted 12 June 2005 - 03:02 PM
#2
Posted 12 June 2005 - 03:31 PM
Eager to try them out, I stepped outside and scanned the neighborhood. Once focused, the on-axis images were sharp and clean, and suffused by a pale yellow color. The color is much less intrusive than the strong yellow of the Russian BPO 7x30 binos, but it is very apparent in the DFs, nontheless. I felt that the color would not be of too much concern to me, but I think a birder might find it annoying. Using the reticle scale as a yardstick, I noted that the image began to soften slowly at, or slightly more than, 50% of the distance from the center of the fov. Even so, the image held up well until nearly the very edge, at which point it quickly dropped off. This also isn't a problem for me because I wear glasses, and the very edge of the image is hidden from me unless I mash my glasses against the soft rubber eye guards. I also noticed that the image reveals a decent depth of field. I felt that, for daytime use, these would do fine for many purposes, but where color fidelity is important, some may take exception to the light yellow color. Night time use is a different story, however. Taking the DFs out after midnight, I was immediately struck by the dimness of the views of the Milky Way. I admit I am accustomed to 10x50 and 12x50 hand-held binos, and the views are much brighter through them, but the smaller objectives of the CZJ 7x40 binos made their presence felt. Once this feeling passed, I went hunting for some of the brighter objects in the vicinity of Sagittarius. I easily found M22, M8, and M20, as well as M6 and M7. M4 was apparent in Scorpius, too. I split Mizar and Alcor, of course, but Mizar itself remained intact. The wide fov made it possible to view all three stars making up the spout of Sagittarius' teapot and all four stars of the teapot's handle could be framed in the fov, too. The two stars composing the teapot's base were barely out my fov, however. Also, the stars at the edges were noticably soft, conforming to what I had seen during the day. Even so, the stars were pin points near the center, and the yellow color that was so noticable during the day was barely apparent in the darkness. Finally, the DF's weight became an issue as the evening wore on. I think I will find these binoculars very servicable during daylight hours, but less so during the night.
#3
Posted 12 June 2005 - 03:38 PM
#4
Posted 12 June 2005 - 03:48 PM
I should mention that I meant that I couldn't quite fit both stars in the same fov.
#5
Posted 13 June 2005 - 08:46 AM
Posted 13 June 2005 - 07:42 PM
Regards
James
#7
Posted 13 June 2005 - 08:46 PM
#8
Posted 12 March 2007 - 12:37 PM
I bet if a tank rolled over them,the tank would come off worst.
Steve.
#9
Posted 12 March 2007 - 03:02 PM
I can't for the life of me think why I didn't say as much in June 2005 , when I first read the posts !
Regards , Kenny
#10
Posted 12 March 2007 - 09:34 PM
I still have the "Checkpoint Charlie" binocular and it continues to meet my needs for coastal viewing and camping. While I haven't tried the tracked vehicle test yet, this is a very solid and well made binocular. Overall, it is a good optical instrument and fun to take on trips.
#11
Posted 13 March 2007 - 08:56 AM
Steve.
#12
Posted 13 March 2007 - 10:56 AM
Belated thanks and appreciation for a very informative review Walter !
Regards , Kenny
Kenny,
That's probably when you were on holiday on the Isle of Wight, watching Lesser and Great Black-backed gulls on the high cliffs of the Needles.
On another holiday, you apparently missed my post about Laura Erickson's article reconciling her birding w/ her brother's hunting. On that same thread, another member posted a link to her photo gallery, which you recently "rediscovered".
Frankly, missing such major events on CN/CD is negligent of your duties as the forum's most prolific poster, master archivist, dry wit, and all around know-it-all. I suggest you request funds from Anacortes for a laptop and satellite ISP service so you can keep up with what's going on and post replies from wherever you are, be it at work on the top of a chimney or on holiday at the top of Culver Cliff. :-)
Walter,
Thanks for that review, I've been curious about these binoculars. I read an article somewhere that described how to take out the reticle. I think I would probably find it distracting like my "floaters" on a bright day.
As far as the NVA's sharpness softening slightly at 50% off axis, I noticed this with the 10x42 SE! That's right, even a binocular with field flatteners, IF you look very carefully will start to sour off axis, albeit slightly. However, the image doesn't steadily degrade but stays about the same until 75% out where there is a narrow band of astigmatism, and then it's sharp again almost to the edge. You can probably confrim this with your pair. If not, Steve better send his back. :-)
It's binoculars like the 8x32 Ultima that fall off SHARPLY at 50% that I find disturbing, particularly when panning when my leading eye will see out of focus images as I scan in the direction of the pan while my other eye lags behind and sees a sharp image. Ugly, ugly, ugly!
Wish Nikon had put rubber armoring like the NVA's on the E2s, including the rubber objective guards!
Did you review the Checkpoint Charlie bins on the forums? I don't see a review on CN/CD mini-review sections.
The Fuji 6x30 FMTR-SX has the same wide 8.5* FOV as the CZJ 7x40 NVA, also built mil spec, also 20mm ER, and the edge performance is excellent for such a WF, thanks to the field flatteners. I'm loaning them to Steve M. this week so he can compare them with his Leupold 6x30s. I hope he will resist the temptation of testing their mil specs by running them over with one of his buses. :-)
I will have his beloved 7x30 Swaro SL as hostage. I will resist plans to dunk them in water and put them in the freezer overnight to test their WPing. :-)
#13
Posted 13 March 2007 - 11:02 AM
http://logicpathsw.c..._binoculars.jpg
#14
Posted 13 March 2007 - 06:26 PM
Steve
#15
Posted 13 March 2007 - 09:40 PM
Well, many of his critics do say that he lacks "vision." :-)
You missed Walter's review, too? As Master Archivist, I think Kenny should provide CN/CD members with a weekly binoforum digest in case we missed something important. Anyone second that motion?
#16
Posted 13 March 2007 - 09:47 PM
Thanks to all for your kind words!
