Hi guys
The orignal thread is here
Where WayneJ recalls cleverly that it's completely impossible to synthesize B from R and G. The B data can't be found outside its band. Just imagine if you were trying to synthesize R from G and B ?
You can make convicing "fakes" on a planet like Jupiter where the details are relatively the same on each channels, but at the expense of true colors. Images will be pink-greenish. However, it will be hopeless on Saturn and above all Mars, where the B details are widely different even from G and R...
First of all, the best method to go on with this is... to try to get good B images
. It's not that difficult ; a first step is to improve the capturing sequence : re-focusing, lowering the frame rate, getting longer B movies.
Next, a very good tool exists to considerably improve the quality of the B image : the atmospheric dispersion corrector. All the amateurs that are using it are happy of it. Damian Peach does, just as an example. It even improves the G channel also... Beautiful RGB images have been done with it.
Finally, the true LRGB method (with the luminance coming from an IR-cut filter) is also a good way to go. But because all the colors are mixed together, you will absolutely need the atmospheric corrector, or the L will be blurred, unless the planet is very high in the sky.
My personal philosophy about processing...
never use a processing that
obviously tweak the "reality". Synthezised channels, IR luminances...
