5" F12 Istar Refractor project
#101
Posted 30 May 2011 - 04:08 PM
#104
Posted 01 June 2011 - 01:06 PM
There must be some suppliers of irrigation tubing in Australia like Hastings in the US.
Dan
#105
Posted 02 June 2011 - 07:52 PM
Here is the red paint, two coats brushed on. This is a marine type alkyd enamel, 'bordeaux red". I probably should have thinned it a little and done 3 or 4 coats but it will do for now.
#106
Posted 02 June 2011 - 08:07 PM
#108
Posted 03 June 2011 - 05:00 AM
#109
Posted 03 June 2011 - 05:08 AM
#110
Posted 04 June 2011 - 07:12 AM
Back to the telescope and I have now fitted the lens, finder and focuser. To check the focuser alignment to the optical axis it is handy to have a collimation laser. You need a paper circle over the lens to show the centre of the lens. Then with the laser inserted into the focuser you can see how close the alignment is.
#111
Posted 04 June 2011 - 07:14 AM
#115
Posted 04 June 2011 - 07:24 AM
Next is collimation of the lens. This is done in a similar way using a cheshire eyepiece instead of the laser. The lens must be covered. A light is allowed onto the diagonal face of the cheshire while looking through the peephole. The eye should see small concentric circles in the crosshair centre. The lens is adjusted with shims or push/pull bolts until the little circles are aligned concentrically.
I am itching to try out the scope now but must wait a little longer until the mounting arrangement is finished. In the meantime here are some more pictures. The finder scope is a standard straight through GSO 8x50.
#119
Posted 04 June 2011 - 11:52 AM
#120
Posted 04 June 2011 - 04:51 PM
Using bathroom scales the weight is around 6.8 kilos (15 lbs) as shown in the photos complete with finder, diagonal and 40mm eyepiece. Tube rings will probably add another kilo. I am happy with that.
Andy
#121
Posted 04 June 2011 - 06:16 PM
Did you make the brass tube adapter on a lathe? I might go this way on my one simply because it looks so good! I am using the same focuser as you so should work.
#122
Posted 05 June 2011 - 01:48 AM
It is an easy job on a lathe. Just copy the profile from the original GSO adapter. I used 100mm brass stock.
Andy
#123
Posted 05 June 2011 - 03:04 AM
#124
Posted 05 June 2011 - 03:08 AM
Andrew
#125
Posted 05 June 2011 - 04:11 AM
