OR: NGC4290, Pal4 (not) and Markarian 205
7 replies to this topic
#1 Jeff Young
Jeff Young
Posted 21 May 2011 - 10:26 AM
This session was characterized by quite good seeing, but poor transparency. I probably should have gone for some small Planetary Nebulae, but I had already written up my observing list.
NGC4290 4/7/2011 21:51 UT; Pickering 8, NELM 5.5, SQM 20.6
400mm Mak-Cass @ 160X
NGC4290 easy direct vision, although indistinct and with a very weak condensation. Averted-vision bar at 160X; direct at 250X. Circular averted-vision disk with fleeting hints of annularity (perhaps 20% of the time). Annularity more prominent at 160X than 250X.
NGC4284 a bit more work, especially pulling it away from the 2 foreground stars. Never quite direct, but easily holdable in averted. No condensation noted.
And yes, M40 is in the field as well (the double-star asterism to the right in the sketch).
Pal 4 4/7/2011 22:16 UT; Pickering 8, NELM 5.5, SQM 20.6
400mm Mak-Cass @ 1X
Not visible at 150X, 235X, 335X or 450X. Had a finder chart, so I knew exactly where to look. Tried wiggling, panning, averted-vision from all different angles, even my right eye. Nada.
Mrk205 QSO B1219+755 4/7/2011 22:40 UT; Pickering 8, NELM 5.5, SQM 20.6
400mm Mak-Cass @ 350X
Under similar conditions with the 16" SCT I couldn't make out the arms of NGC4319. I'm not sure whether it's the instruments, or just more experience, but the bar is now quite distinct (borderline direct/averted) and two larger lobes (extending out to the NW and SE) are holdable 75% in averted.
[I can't see the distinction between the inner ring and the outer arms, but the extent of the lobes clearly includes the much dimmer outer arms.]
I make out the quasar to be very similar in magnitude to several field stars in the mid-14s, and brighter than one at 14.7. My catalog has it at 15.2, but I think it's considerably brighter (at least visually).
Jeff.
#2 JayinUT
JayinUT
    I'm not Sleepy
Posted 21 May 2011 - 01:22 PM
Jeff,
Great report and terrific sketches. Nice read as I lay here getting over pneumonia. Thank you for sharing.
#3 Jeff Young
Jeff Young
Posted 22 May 2011 - 03:57 AM
Ugh. I had pneumonia last summer; I don't envy you. Take care of yourself.
Jeff.
#4 frank5817
Posted 22 May 2011 - 06:20 AM
Jeff,
Always a pleasure to see your excellent deep sky renderings and well written reports. Your work is always in the best of the best category.
Jay- Get well
Frank :)
#5 timokarhula
timokarhula
Posted 22 May 2011 - 10:39 AM
I observed NGC4319, NGC4291 and Markarian 205 on April 24. That night my SQM-L meter showed 21.61 (the darkest reading so far at my regular observing site) even when the solar altitude was -17ยบ.7 at midnight (not really astronomical night). Using my 10-inch Dob and 250x, I estimated the quasar as magnitude 14.3-14.4 visually. It appeared stellar or possibly substellar. That night I observed three quasars, including 3C273 in Virgo and OJ287 in Cancer (very faint). The fourth quasar / blazar, BL Lacertae, was not seen in the growing dawn twilight.
/Timo Karhula
#6 Jeff Young
Jeff Young
Posted 22 May 2011 - 11:06 AM
Thanks, Frank!
Timo, sounds like you've got nice dark (and dry) skies! My skies are so humid that astronomical twilight usually drops my SQM readings into the upper 19's / lower 20's.
I'll have to track down some of those other quasars; so far the only other one I have is Mrk421.
Jeff.
#7 Jim Curry
Jim Curry
Posted 22 May 2011 - 07:05 PM
Great stuff, Jeff. I'm still waiting for the tropical rain forest weather to clear out of New England. I have'nt been out in weeks, Ugh!
#8 Jeff Young
Jeff Young
Posted 23 May 2011 - 03:07 PM
Thanks, Jim!
Jeff.
