Review of MEADE HD 60* FOV EP
63 replies to this topic
#1 hfjacinto
hfjacinto
    I think he's got it!
Posted 21 May 2011 - 04:21 PM
Hi all,
I recently purchased 2 sets of the MEADE HD 60* FOV eyepieces. I wanted to get a set for BinoViewing and was looking at the TV brands (Panoptics, Radian) but didn't want to spend so much, so I decided to get the Meade HD eps. They meet my needs; wider field than Plossl, nice eye relief and lower cost than a Radian or 24MM Panoptic.
I got a pair of 25MM and 12MM and will probably get a 6MM or 18MM pair depending on how much in focus I am able to use with the Baader Bino Viewer (which has not yet shipped). Since the weather in NJ has been terrible (rain since last week), I had been playing with them on terrestrial objects. Today we had a clear day so I used them on the sun. The scope was a Lunt 60MM HA scope with B1200 blocking filter. There were several nice prominences on the sun and a nice sun spot group in the center of the sun. For comparison, I also used an 11 MM Nagler, the Lunt Zoom and a 6MM Radian to get a feel of how these EPS performed.
So let’s get to the review:
Quality and Build:
They are very nicely built. The Meades come in a nice paper box with a custom foam insert. They have a rotating eyepiece cup which is smoother than the UWA mechanism and not as abrupt as the Radian. There is a large made in China stamp on the barrel (like in the UWAs). The best part is that they don’t have the round body like the UWA and Axiom. It’s a nice well built EP. They come with 2 covers that fit snugly. The only negative was in both 25MMs there is some nicking of the filter threads although 1.25” filters thread fine). Both 25MM had the internal nicks, the 12MM didn’t. Overall build was very nice. I would say A- (the only reason being the nick on the internal barrel)
Ergonomics:
The eyepieces are large for 1.25”, comparable in size to a Radian, larger than a T6 Nagler but weighing comparable. I don’t think they would cause any balance issues on a dob. I had no issues with using them on my Lunt. They have the barrel undercut, so for some that is an issue. The movable eye cup was a joy to use, not stiff at all, just a smooth motion. The eyecup has a soft flexible rubber, which I (and eye) like. One is also able to firmly plant the eye and not have any stray light which is important in solar viewing. Ove all IMO better ergonomically built than a Radian (I dislike the instaadjust) and better designed for daytime use compared a T6 Nagler. Ergonomically as well built as the Lunt Zoom and easier to use than the UWA and Axiom. I would say A+, other manufactures could learn from this EP.
Day Time Viewing:
Ok, this review was done during the daytime so I can’t say how the EP functions at night but the skies give clouds so I make due. I hope to have a clear night (HAHAHAHAHA) eventually but for now, this is the best I can do. So I set up the Lunt on a my deck (BTW no a review of the Lunt, but this scope is an A+, no wonder there is a 3 month wait for it) and started the LXD75 mount. Since I had set it to Sleep, I turned on the mount and select OBJECT>SOLAR SYSTEM> Mercury and then used the TV Sol Finder (another A+ product) to find the Sun. I started off with the Meade 25MM and the Lunt at the 21.5MM and the first thing I noticed is that the Eye Relief is more (much more) on the Meade. It was actually difficult to find a position that I would not get a black out. Once I raised the eyecup, it was just perfect, the Sun was in view and blackouts stopped, it did take 3 trys to figure out what to do, but once I got it, it just worked. The view was nice, I tuned the Lunt and several large prominences were visible at 12 and 6. I put in the Lunt Zoom and the eye relief is less but not bothersome, the same prominences appear, but I also noticed that some phages by the sun spot were not visible. I put the Meade back in and they were there, the Zoom they were but not as visible. It could be magnification. I also noticed a progressive darkening of the image in the Zoom while the Meade did not have it.
I then went to the 12MM Meade and the suns disc was fully visible without the darkening that accompanied the Lunt Zoom, the difference was that the solar disk was not so clear on the Lunt Zoom, but had more contrast on the Meade. More stuff was visible with the Meade on the solar disk. The view on the Zoom was just softer. I then put it the Nagler and the image was slightly better on the solar disk, I could make out a phage was slightly longer and the region around the sunspot was better defined but I did find one negative, the Larger clearly showed the edge of the 12MM Blocking Filter (considering the Nagler has a 14.9MM Field Stop, it was expected, but bothersome) while the Meade just showed the solar disk floating in space. This is probably the first time, I have been bothered by a large FOV.
I finally tried at the Zoom maximum of 7.2, the 6 MM Radian and the 12MM Meade Barlowed with a 2.5X powermate. Not exactly equal and the viewing wasn’t allowing it on the solar disk, but the prominences showed some very fine details. I had to do a lot of focusing to adjust the view as seeing was just not great. At this power with the not great seeing, none of the EPs performed as expected.
Please note that since this was a daytime test, I wasn’t able to notice any color difference between the EPs.
I would say that for daytime use the Meades are an A- (not as sharp as a Nagler or TMB Monocentric, but comparable to a Radian)
Overall
I have to say that I like the Meade, I actually put away the Zoom and Nagler and stayed for over an hour using the 12MM. It was a really nice view. For $79 these eyepieces are a bargain. If you are looking at getting a Radian, consider these, they have the same features and if used for daytime the same view.
I will do a night review when or if it ever clears up.
And here are the pictures ;)
#2 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:22 PM
Boxes opened
#3 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:23 PM
Slight nick on filter threads. Only on the 25MMs
#4 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:24 PM
With a filter and a Baader Filter (these are the hardest to get on), it went it on smoothly, no cross threading.
#5 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:25 PM
All 4 ready for first light. Please note I tested all 4 and the views were the same from each set.
#6 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:26 PM
On the Lunt
#7 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:27 PM
With a power mate 2.5X (which way do you look through ;) )
#8 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:28 PM
Looking through the Eye Lens
#9 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:29 PM
Through the objective.
#10 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:30 PM
Eyecup rotated all the way up.
#11 hfjacinto
hfjacinto
Posted 21 May 2011 - 04:31 PM
Testing eyepieces is such hard work ;)
#12 Mark9473
Mark9473
Posted 21 May 2011 - 04:35 PM
Nice review and terrific set of images. I'm looking forward to Part II under the night sky.
#13 jhogan10
jhogan10
Posted 21 May 2011 - 04:46 PM
Nice eyepieces you have there. I was wondering myself on getting one to try out. After seeing your review and pics I'm sold. Thanks! :D
#14 thomas68
thomas68
Posted 21 May 2011 - 04:52 PM
Great review, great telescope. Looking foward to next review!
P.S where did you buy them from?
clear skies, Tom
#15 JIMZ7
JIMZ7
Posted 21 May 2011 - 05:15 PM
Excellent review. Now we will be waiting for the night reviews. You put a lot of effort into this. Thanks!
#16 Vondragonnoggin
Vondragonnoggin
Posted 21 May 2011 - 05:24 PM
Nice review and very nice scope to test with! Have to say that you are the second to come on the forums after buying several different sizes and post excellent results for such a reasonable cost eyepiece. look forward to your binoview report too. Congratulations!
#17 Phil Cowell
Phil Cowell
Posted 21 May 2011 - 05:27 PM
Well done on a nice review. I wondered who caused all the rain here in the North East. The HD's do have a nice look to them.
Cheers
Phil
#18 REC
REC
Posted 21 May 2011 - 05:45 PM
Wow, what a nice set up! It appears that you had a nice clear day there from the scope pictures you took outside. Hopefully it continued on into the evening.
These new series look promising for the features and performance at this price point. If they perform as promised, they could be a great contender for Bino Viewing vs. EP's at twice the cost....let's hope so :)
#19 THEPLOUGH
THEPLOUGH
    ELEVEN Grandchildren; FIVE Ducklings
Posted 21 May 2011 - 05:52 PM
Great review Helder looking forward to the night time report. Seems like you have some keepers there.... :waytogo:
#20 hfjacinto
hfjacinto
Posted 21 May 2011 - 06:03 PM
Hi all,
Its now pouring rain here. No night testing unless it stops.
I got the eyepieces from Telescopes.com (with a $15 off $150 purchase and free shipping) the cost of each was $71.50
I don't think these will replace my night time widefield set-up, but for what I was looking for they seem to meet my needs. As I wanted a wider field (not Nagler/Ethos wide as its unusable to be with Bino Viewers), good eye relief and not $200 per EP. I really need to try them in the Binos before I say they are keepers but so far for daytime viewing they are excellent. The below was a lull in the rain, its heavier now :(
#21 REC
REC
Posted 22 May 2011 - 08:27 AM
Looks like it's pretty green where you live with all that rain:) I looked at some of your images on your gallery, pretty nice! Do you also do some from your yard there as well as observing in a suburban location?
#22 hfjacinto
hfjacinto
Posted 22 May 2011 - 01:13 PM
I usually do Solar at home and when the moon is between 1/2 and full I don't go to our dark site. I'm am 17 miles south west of NYC and the skies are terrible so I go to our dark site any chance I can get. I imaged some things from home, but its so much easier from Jenny Jump, that I do the 100 mile round trip.
#23 Mark9473
Mark9473
Posted 22 May 2011 - 03:34 PM
Please send some of that rain this way, we've had a record drought for the past three months or so.
#24 GeneT
GeneT
    Ely Kid
Posted 22 May 2011 - 09:14 PM
Nice review! Your Meades give good value for the money spent.
#25 hfjacinto
hfjacinto
Posted 25 May 2011 - 07:33 PM
Hi all,
Did some more daytime testing as I got the binoviewer and they work excellent. It was hard getting my eyes to see one image and its still hard but the they work really well in daytime.
I used the 25 MM Meade on the Lunt with 2.6X corrector do its functioning as a 9.6 and what a view the sun filled up the whole FOV if felt like I was there.
I then tried it in my 120MM without the corrector and with a Baader prism and was looking at the trees, a bug flies in and I can see its legs and wings, even its eyes, all I can say is wow.
For now, for $71, what a bargain. Really worth it. I don't have any other pairs so I can't say how good they are compared to other eps in the binoviewer, but if you want inexpensive nice eps these should be at the top of your list. Let me check at night and see if my opinion stills holds.
