Messier List v. Binoculars
13 replies to this topic
#1 mnpd
mnpd
Posted 04 July 2005 - 04:45 PM
Has anyone ever roughly calculated how many of the Messier objects can be seen with a quality 10x50 bino? Maybe some of the more experienced have even tried this.
It's strange what thoughts occur to me in the middle of a holiday thunderstorm. ;)
#2 lighttrap
lighttrap
Posted 04 July 2005 - 05:01 PM
Go here.
There are those that might claim to have seen all 109 M objects with 10x50s. Frankly, I'm more than a bit sceptical. For a couple years, I tried, and failed, to complete single night Messier marathons with some mounted 16x70s, but will readily admit that my seeing conditions were far from optimal. I'm embarrassed to admit that my tallies of M objects in 10x50s, 12x50s and 16x70s are all around more or less the same 70-80 something objects. Perhaps in much better skies, with much more sky visible that would radically change, but it seems to be where I'm stuck, viewing from various tree lined bowls in central NC.
#3 milt
milt
Posted 04 July 2005 - 05:33 PM
I confirmed 102/110 in my 18x50's over 3 years, missing only M109 and 7 members of the Virgo galaxy cluster. I have not attempted a Messier tour at 10x50. At 70mm or larger it would be easy.
#4 EdZ
EdZ
    Professor EdZ
Posted 04 July 2005 - 07:08 PM
A few will post a challenge for any size binocular. deep dark skies is your most important asset. I've not seen m109 in any binocular. M74 was seen only in the BT100 at 24x under mag 5.7 skies. And there are a few in the Virgo/Coma area that I just can't seem to see even in 100mm binoculars.
edz
#5 Glassthrower
Glassthrower
    Vendor - Galactic Stone & Ironworks
Posted 04 July 2005 - 08:08 PM
As of right now I have 29 Messier objects bagged. Out of those, only one (Andromeda) is a galaxy. Galaxies have proven elusive in my mag 4.5 skies. As a beginnner, I have finally learned what more seasoned astronomers already know - dark skies are king. Apeture is nice and magnification is nice, but all the apeture and power in the world means little from the center of New York City or Los Angeles. As bad as my local skies might be, I am thankful I do not live in a major metropolis.
Hey EdZ - this a little bit "cross-topic", but have you even given thought to putting together your own or a Cloudy Nights "Bino Club" or similar observing list? I'd be interested to see what a veteran like you would include on it.
MIkeG
#6 milt
milt
Posted 04 July 2005 - 09:41 PM
Hi Ed,
Right you are. I should have mentioned that all the Messiers I saw (or not as the case may be) with my 18x50's were in skies at least mag 5.5. For some of the more challenging galaxies like M74 probably closer to mag 6. Also, I mounted them for the serious hunting so I could leave the eyepieces to consult a star chart without losing my position in the sky.
I've not seen m109 in any binocular....there are a few in the Virgo/Coma area that I just can't seem to see even in 100mm binoculars.
I would suggest using a higher magnification to finish the Messier list in your BT100. I captured every M galaxy at the marathon this year in my 32x82 Highlander except for early object M74 - will have to pick it up this fall.
Take care,
Milt
#7 AJTony
AJTony
Posted 04 July 2005 - 09:55 PM
I have attacked the Messier list first with 15 X 50 Canon IS binos. With these I located 82 Messiers. I switched over to 25 X 100 Apogees, which brought me up to 104 Messiers. The BT100-45 bino brought me up to 108, with two to go, M74 and M76. Note that I am using the 110 list vs 109.
So that was my approach, but along the way, I discovered what was repeated above over and over. Dark skies rule. With a good dark sky site, you should be able to approach 100 Messiers with 10X 50s. Something else I found along the way was that your naked eye doesn’t always tell you that you have a great night for DSOs. On what appeared to be a great night at Cherry Springs, PA, I could not see M33 through my big binos; I later suspected there was excessive moisture in the air. My first visit to The Stella Della Star Party was last fall. Their site is only 20-30 miles from the Philadelphia suburbs. It was right after a rain, and it looked like just “good “viewing. However, the DSO viewings through my 25 X 100 Apogees were great. M31’s full spiral filled the entire field of view. M27 gave the best 3D image I had ever seen.
Bottom line: Once you reach your apparent Messier limit with your binos, seek out dark sky sites, and keep returning until the sky conditions match the darkness.
AJ
#8 lighttrap
lighttrap
Posted 04 July 2005 - 10:26 PM
That's a very interesting perspective, and a very interesting post & challenge, AJ. Thanks for posting that!
#9 mnpd
mnpd
Posted 05 July 2005 - 12:34 AM
Thanks everyone That is a wealth of information that I'll try not to forget. I'm going to see what I can do with my Leupold 10x50's, especially since I'm taking the motorhome up to Wyoming to visit my son and grandson next month. I'll be camped out at Curt Gowdy State Park which is a about a mile and a-half above sea level in the Rockies. I've been there many times before, and it's very dark (and cold) on summer nights.
I've looked at the "M" list since I was a kid, but never logged anything...until now...I'm retired. I sat outside in a lawn chair tonight after seeing the firework display in Nashville, and logged 14 entries. Of course these were the easy ones; mostly in Sagittarius. Cygnus is directly overhead late at night, but save M29 and M13 most of the Messier objects in that area are small and dim. I'll get 'em next time though, but probably not with what I had in hand tonight.
I suppose my rant bores you old sages. But, it's fun on this end.
#10 Rich N
Rich N
Posted 05 July 2005 - 12:35 AM
I agree with Milt. It helps to have quite a bit of magnification to easily see many of the Messier objects.
The outstanding optics in the KOWA HighLander also help. :)
Rich
#11 CESDewar
CESDewar
    GorillAstronomer
Posted 05 July 2005 - 02:07 AM
I went back and reviewed my observing notes and noted that I did manage to catch M109 with my 25x100mm Binos on April 27th of this year with good seeing conditions. On the 16th (11 days earlier) I noted that I could not catch M109 but did catch TYC3833-781-1 (mag 9.6, 4' away) quite easily, so I may have just been lucky subsequently with an unusually dark sky (on the 16th, moon was at first Q). I did observe it without too much difficulty in the C9.25" on the 16th. Although I am in the East, the North GA skies where I am have a reputation of being some of the darkest in the Eastern US which helps. M109 is usually listed at Mag. 9.8, although I notice Starry Night pegs it at 10.6 which might be a bit more realistic given the difficulty in observing it. The glare of Phecda just 38' away is also an issue.
However, I'm also returning to astronomy after a nearly 35 year hiatus, and your comment has caused me to flag this observation for reconfirmation as I realize you have logged a lot more hours than I have in recent years and I want to be sure my notes are accurate!
#12 Alby
Alby
Posted 05 July 2005 - 04:41 AM
Hello;
I was going to post an account of sorts when I had some time about my recent viewing session.
I'm just so happy about it I can't resist mentioning it here:)
A few nights back I viewed with my BT 100 45 binocs at 25x NGC 6992(eastern half of Veil Nebula). The skys weren't the greatest and the light dome to the south of me has gotten worse!!!!!!!
It took a while to spot but that faint ghostly arc was one of the reasons I wanted 100mm binocs.
I've had no problem finding Messier objects as of yet, however that hasn't included M74/M109.
Think I'll have to give those a try when able.
Cheers....must run
Alby
#13 Guest_**DONOTDELETE**_*
Posted 05 July 2005 - 07:24 AM
Of the two parameters, magnification and aperature area, magnification is a greater contributor to increasing the LM. When I swtich my BT100 magnification from 25x to 43x, it's a whole new sky at times.
#14 EdZ
EdZ
    Professor EdZ
Posted 05 July 2005 - 08:20 AM
I've already put together a Binocular double Star List. It has about 75 double stars listed for binoculars ranging from 8x40 to 40x100. It can be found through the binoc forum links or thru the double star forum links.
For a list of the Messier objects and a plan to view them, refer to the links to websites and access Stephen Tonkin's (CN member) Messier marathon Guide.
We could compile a list of NGCs since there are many that can be seen. You could spend a whole night just observing NGC's in Cassiopeia/Perseus area. Much of all these targets are here in the forums in bits and pieces. There are some links in the "Best Of" thread to Targets.
There are probably a lot of observing posts in this forum that are not tagged thru that link. If anybody finds good old posts that are not linked to ther Observing targets Best Of post, point them out and I'll add the link.
edz
