Thanks for the kind words. Of course donations are appreciated, but remember that you don't HAVE to donate. You can use the software or make suggestions either way
Whether or not I do something with those suggestions depends on 1) my mood, 2) if I'm convinced it makes sense, 3) how time consuming it will be to implement.
-- 2.0.0.46 is online. List of changes: ---
- Changed name of Coarse Alignment to Image Stabilization, which makes a bit more sense.
- Added option to manually set coarse alignment window location in surface mode. You should set it around a feature that stays in the FOV at all times. The default location works 95% of the time, but sometimes AS!2 surface alignment loses track because there is nothing interesting to see in the center of the screen.
- AS!2 is now aware of OS limitations on amount of memory available per process. There should be no more lockups caused by out of memory on 32-bit OS.
- Fixed caption of frame number at bottom left, it didn’t update properly in batch processing.
- Fixed caption of frame view in batch processing.
- Fixed unable to press Cancel button in batch processing.
- Added some extra lines at the back of the quality graph at 0, 25, 75 and 100% to increase readability of this graph.
- Tiffs are now saved uncompressed (instead of LZW). Should increase compatibility with processing software.
- Added support for 8-bit single channel bmp files.
- Fixed surface alignment bug causing a more or less random lock up during buffering or image alignment.
- Should be more stable now, especially for surface recordings containing poor frames.
- Automatically turn off bad frames with horizontal or vertical shifting artifacts.
- Speed increase for surface alignment (approximately 30-50% faster).
- Introduced two Surface options: ‘Expand’ will try to make the very biggest image stack possible, the edges will contain less frames (this was the default option). ’100%’ will crop the image such that each pixel will contain the same amount of data (the edges should be fine).
- Batch processing for surface recordings. When more than one surface recording was opened, when processing, for each frame all APs are replaced by a set of automatically placed APs (in a grid, just like when you press the grid button).
