AutoStakkert! 2
345 replies to this topic
#76 Kokatha man
Kokatha man
Posted 14 February 2012 - 10:11 PM
.....just for others following this particular aspect, here's one of the above R6 Mars wavelets (same values) using larger AP's centred more within the panet's disk and using slightly larger ones at the poles.....as Emil suggested, but now 1500 frames.
I'll work back through and (eventually!) post these nights' images of Mars and Saturn with both MAP's setups and results as well as "Edge" qualitor estimator.....I didn't bother about reducing the size of the whole box as my 8-thread machine makes mincemeat of the processing speeds anyway....! :grin:
#77 GreatGigInTheSky
GreatGigInTheSky
Posted 17 February 2012 - 04:19 PM
One (small) frustration I'm having with the program: I'm finding it impossible to select certain image sizes with the width/height sliders. It would be great if there were text boxes where the numbers could be entered as well as the sliders...
#78 Sunspot
Sunspot
Posted 17 February 2012 - 07:00 PM
I'd second that suggestion.
Paul
#79 MvZ
MvZ
Posted 17 February 2012 - 07:55 PM
I'll look into that. In the meantime - and perhaps it's already good enough - if you click on the sliders, you can then use the left and right arrow keys to move the slider. It will be much more accurate then.
Once I found a particular image size that I'm going to use more often, I simply click the 'remember' checkbox, and each following set of images will be cropped to the remembered dimensions.
#80 Sunspot
Sunspot
Posted 17 February 2012 - 09:07 PM
That certainly makes it much easier to set an image size. Thanks for the tip.
Paul
#81 GreatGigInTheSky
GreatGigInTheSky
Posted 17 February 2012 - 09:59 PM
Thanks, Emil -- that's what I was looking for. It's not very easily discovered, though. Having something more standard may save you being asked the same question in the future. And yes, the remember checkbox is great, but may not help if you're going from imaging Mars, say, to Jupiter with moons...
#82 Andy Taylor
Andy Taylor
    Twisted, but in a Good Way
Posted 19 February 2012 - 11:56 AM
Also a very useful feature for processing frames for animations...
I'm getting great results from this software - thanks Emil.
#83 Rankinstudio
Rankinstudio
Posted 19 February 2012 - 12:29 PM
Awesome work Emil. AS2 works very well. Here is a little comparison I did with some data I have.
larger: http://www.rankinstu...dnloads/AS2.jpg
I think I am liking the AS2 / Astraimage combination best so far.
Color Example
larger: http://www.rankinstu...loads/AS2-2.jpg
Cheers!
#84 Sunspot
Sunspot
Posted 19 February 2012 - 01:04 PM
Interesting. Looking at the colour images, I see some parts looking better with Reg6, for instance the barge, also the turbulent trail behind the GRS as well as overall in the equatorial region. Yet, the polar regions look better in A!S. The GRS itself is a tossup to me. This is the same sort of results I've been seeing with Jupiter as well.
Paul
#85 Rankinstudio
Rankinstudio
Posted 19 February 2012 - 01:12 PM
I agree Paul, it is a close call between the two. I will say a lot more effort went into the R6 version. Wavelets in R6, unsharp mask in PS, and then astraimage in PS, whereas the AS2 was just AS2 and Astraimage. They both do an excellent job of stacking, that is for sure.
#86 GreatGigInTheSky
GreatGigInTheSky
Posted 19 February 2012 - 02:00 PM
David,
Would you mind sharing what processing you're applying in Astraimage? I assume it's some flavor of deconvolution. I've been wondering about the possibility of skipping Registax completely when using AS2 for stacking.
#87 Rankinstudio
Rankinstudio
Posted 19 February 2012 - 02:03 PM
Hi Jeff,
I am just using the wavelets in the astraimage PS plugin. I usually start with the large details then work up the finer detail sliders. Not using the deconvolution. :)
#88 Asimov
Asimov
Posted 19 February 2012 - 10:34 PM
Emil. I'm just getting around to trying AS!2 on some Saturn data. I'm finding it almost completely obliterates the Crepe ring. Only a very small portion of it is visible. I've tried stretching it of course in the low, mid & high levels in all my editing programs including Registax. Even before using Registax waveletts it is not visible. In this particular example/AVI it is there in the RAW data as well as after aligning/stacking in Registax.
Any help would be very much appreciated as it gives a MUCH superior stack to Registax apart from this C ring problem.
#89 Kokatha man
Kokatha man
Posted 19 February 2012 - 11:00 PM
Hope you can take the time to look at my thread again Emil and see what you can make of my questions to you therein... :bow: :grin:
John, can't help you at all except to say that I haven't found any problems with AS!2 and Saturn's Crepe Ring.....except to say (and I'm sure you'd appreciate this already) that gamma levels influence the Crepe Ring very significantly - but AS!2 shouldn't have any influence there on what you bung in. :)
#90 Asimov
Asimov
Posted 19 February 2012 - 11:43 PM
I was about to ask you Darryl, as you're the only other guy here that (I thought) had Saturn data.
Yeah I know..about the gamma etc. Here's a registax version with all (mostly) the same levels etc. It's got me beat! :question:
I guess I'll work it out - Gotta be something I'm doing wrong..
#91 MvZ
MvZ
Posted 20 February 2012 - 09:19 AM
Could you post (or send me) the raw stacks?
Have you tried turning off the "normalize stack" option in AS!2?
#92 Asimov
Asimov
Posted 20 February 2012 - 12:25 PM
Can do yes.
"Normalize stack" was immediately disabled by me right from the start. I don't use that in any stacking program or procedure.
#93 Asimov
Asimov
Posted 20 February 2012 - 04:13 PM
Actually I have 75% solved it by stacking a final from AS!2 & 1 from Registax. I'd be much happier that it didn't happen at all in AS!2 naturally. Image sent BTW.
#94 Kokatha man
Kokatha man
Posted 20 February 2012 - 07:21 PM
Hi Jeff - in defence of Emil on this point where you're referring to the use of the arrow keys on the keyboard to "fine adjust" the slider values, this is a standard keyboard operation (once you've clicked on the control) on just about every program application I know of.....not trying to sound clever, as I only discovered it about a year ago on something else and then found it was a universal operation almost..... :)
#95 GreatGigInTheSky
GreatGigInTheSky
Posted 20 February 2012 - 10:13 PM
Hi Darryl,
I take your point -- I've since discovered this in some other programs (Registax, Gimp on Linux...) -- I was just unaware of it. It's just my ignorance of UI conventions... :o
#96 Kokatha man
Kokatha man
Posted 20 February 2012 - 10:19 PM
Hi Darryl,
.....well, I was in the same boat untill I accidentally "discovered" it awhiles back Jeff - in my case, so much to learn, so little to fit it into..! :lol:
ps: talk about ignorance - what's "UI conventions"..?!? :question: :)
#97 GreatGigInTheSky
GreatGigInTheSky
Posted 21 February 2012 - 01:05 AM
Darryl,
UI = User Interface. So UI conventions being the standard ways that users can manipulate controls. And you think I would have encountered this before, being a computer programmer by trade, but I work on web sites doing generally back-end server stuff, so I'll have to beg pardon on that basis.
#98 Sunspot
Sunspot
Posted 25 February 2012 - 07:27 PM
Emil,
As you know I drag and drop bmp files onto stacking programs (either Reg or AS!2). It seems that when I drop the bmp files on AS!2, the last bmp in the stack shows up as the first one on the display. Since I use Ninox to sort, the last bmp should be pretty lousy and the first one should be pretty good. I captured a screen to show what I mean. Be sure to note the slider position and the quality of the image. If I slide the slider only one image right, it goes from really, really bad to really good. If the quality of the first image has no effect on stacking, then it is nothing more than cosmetic. Thought you ought to know about it anyway.
Paul
#99 Freddy WILLEMS
Freddy WILLEMS
Posted 25 February 2012 - 07:40 PM
Interesting Paul, so how do your Saturn AS2 images come out ?
#100 Kokatha man
Kokatha man
Posted 25 February 2012 - 07:53 PM
.....wonder whether this has anything to do with the "0000" - "0001" - "0002" sequence the ninox'd bmp's are presented as Paul - but AS!2 is going to do its own thing regardless (just as R6 would also) so I think it is probably a moot point...
