The OTA under examination was an Orion Skyview Pro 127mm Maksutov. Specified aperture is 127mm (clear diameter at the meniscus), focal length is nominally 1540mm (f/12). The basic design has been produced under a number of guises & brands and has proven popular with owners and reviewers.
I chose 3 configurations for the "flashlight" test. Back focus in each case was measured from the edge of the threaded flange to the eyepiece field stop (+/-2mm). The eyepiece used was a 10mm Sirius Plossl. Refocussing to infinity was performed between each change in back focus distance. The disc of light from the OTA was projected onto white paper approximately 300mm (12") from the front of the scope to permit measurement (+/-1mm).
Accessory configurations:
a) 2" adapter tube and 2" mirror diagonal, approx back focus 155mm
b) 2" adapter tube without diagonal, approx back focus 60mm
c) 1.25" SCT mirror diagonal and 1.25" SCT visual back, approx back focus 126mm
The three cases represent the most sensible use of the accessories I have to hand. A 90° erecting prism I own was not included, but would give similar results to the other 1.25" setup.
Measured data:
Setup - Bck Fcs --------- Measured Aperture ----- CO shadow
A ----- 155 -------------- 117 ------------------- 45
B ----- 60 --------------- 118 ------------------- 45
C ----- 126 -------------- 118 ------------------- 45
(all data in mm)
The results are very interesting on two accounts. Setup A, longest backfocus, was measured first and I thought "Aha there's the aperture reduction that is warned about". However, I was surprised to see that the measurement changed little, if at all for ANY of the setups.
The measurements lead me to two conclusions:
1) This telescope is really operating at 118mm effective aperture, some 9mm less than the manufacturer's specification.
2) It is seemingly tolerant of the additional back focus present when employing 2" accessories.
On point 2 I MUST add further comment. A test suggested by Eddgie some while ago revealed that there is vignetting as one moves to the edge of field with long focal length EPs. This can be detected by observing the ring pattern of a defocussed star, then moving the scope to place this image at different positions in the apparent field. Vignetting can be detected where the concentric ring pattern is disturbed, and this has been confirmed in previous testing with a 35mm EP in the 2" visual back + 2"diagonal setup.
I hope this is interesting, and welcome comments & observations
Ed
