1920 130mm Zeiss
#1
Posted 31 March 2012 - 07:13 PM
Steve
#6
Posted 31 March 2012 - 07:21 PM
#7
Posted 31 March 2012 - 07:24 PM
#8
Posted 31 March 2012 - 07:26 PM
Do you have any more details to share about the scope (aperture, f/ratio, etc.)?
Okay, never mind. If I had taken the time to read the post title more carefully, I'd have already known it was 130mm. It looks around f/15 to me--am I close?
#9
Posted 31 March 2012 - 07:31 PM
Zeiss 130mm E lens Someone needs to buy this one before myself, Dan, PJ, or others buys another scope we dont need.
#10
Posted 31 March 2012 - 07:35 PM
Thanks for sharing,
Dan
#11
Posted 31 March 2012 - 07:49 PM
#12
I have seen a few pictures of Harold`s telescope collection. Does he keep his scopes at his house or in another location? Did you get a chance to see it. I`m sure it looks much more impressive in person than in the pictures and his collection looks fabulous in the pictures.
Dan
#13
Posted 31 March 2012 - 08:14 PM
We were only able to see 2 of his collection with all the other activities we had planned. My wife has relatives in Amsterdam so we spent time with them, and also spent 3 days at an island on the West coast as well. The size of these big refractors is really something you have to see (and touch) in person to get the full impact. I'm not sure where Harald normally stores his scopes. I did send him and email, and hopefully he will chime in on this thread.
#16
Posted 01 April 2012 - 02:01 AM
#17
Posted 01 April 2012 - 05:01 AM
I am researching the Lens and telescope numbers of Zeiss between 1897 and 1950. From the telescope number (Nr 7744) and the lens number (Nr 8030), this telescope was made about 1915. It appears to be about f/18 and so would be an "A" type semi-apochromat. However Dan S states it is an "E" type which is a two lens Franhofer type usually of between f/10 and f/15. Additionally, Herr Jurgen Kost had an article on this telescope in Astromat.de some time ago and stated it was an "E" of focal length 239cm, an f/18.4 , quite an unusual focal ratio for an "E" lens.
The telescope as pictured has had it's original steel field tripod replaced with the present wooden one and has also lost it's vertical fine motion drive. The wooden tripod has also lost its cast adjusting feet.
A very fine and handsome telescope. It should be noted that these changes occurred prior to the photo that was included in Herr Kost's article.
#18
Posted 01 April 2012 - 05:18 AM
The 110 you show in your photos has tube number 11104 but the first 1 is not visible in the photo. It dates from 1924/5. If this is the correct number, it should have a lens number of 14000 to about 14600. With a number in this range, it could have an early AS lens.If not, then an "E" or "B" Could you provide a photo of the lens showing the inscription with the lens type and focal length.
#19
Posted 01 April 2012 - 02:30 PM
--Ken
#20
Posted 01 April 2012 - 04:00 PM
I don't have another photo or camera available.
The lens is 12923 E f=165cm.
Mark
#21
I agree that wooden pyramid stand was made by Zeiss. However, it may not be original to the mount. Take a close look where the metal base contacts the wood. Usually the metal base is the same or slightly less than the diameter of the wood. In this case, it greatly overlaps the wooden pyramid stand. My quess is that stand came from another Zeiss telescope. In my opinion this telescope would require a larger stand, either steel or wood.
Dan
#22
Posted 01 April 2012 - 04:49 PM
Do either of you have a link to a site that has the telescope production numbers by year. I remember seeing it but can't find it.
Mark
#23
Posted 01 April 2012 - 04:51 PM
There is no site that I am aware of. Please remember it and let me know. The dates that Trotts1 is referring to come from his research.
Dan
#24
Posted 01 April 2012 - 05:10 PM
I had found a place and didn't bookmark it with serial numbers...darn!!!
#25
Posted 02 April 2012 - 06:22 AM
here my Asaliter, 130 mm Zeiss terrestrial observation refractor:
http://www.cloudynig...67/Main/4375977
Objective E type SN 7357, and SN 9064 is printed on the big prism box. Can you help me to define better fabbrication date ?
Thank you and best regards, Antonio.
