Monolux 60mm zoom
28 replies to this topic
#1 Muhammad Arif
Muhammad Arif
Posted 10 July 2012 - 04:10 PM
I have the opportunity of buying a Monolux 20-60x zoom 60mm telescope. Is it worth collecting? Any info about this telescope would be appreciated.
#2 roscoe
roscoe
    curmudgeon
Posted 10 July 2012 - 05:42 PM
Can you look through it before paying? Perhaps you have a chance at a real gem, however I have a Monolux 40mm zoom with an internal image-erecting lens, and even after cleaning all the glass, it is terrible. (it does look just like a real scope, though....)
Russ
#3 Muhammad Arif
Muhammad Arif
Posted 10 July 2012 - 07:16 PM
unfortunately, I won't be able to look through the scope. I was asking my brother to pick it up for me and he is not too knowledgeable about telescopes.
#4 Bonco
Bonco
Posted 11 July 2012 - 04:13 PM
Most of the zoom refractors I've viewed thru had poor optical performance. Wouldn't buy one without looking thru it.
Bill
#5 droid
droid
    rocketman
Posted 11 July 2012 - 07:46 PM
At worst you can chop it off and make a richest field refractor out of it, what I did with an old Tasco zoom type, as a zoom scope it was horrible to terrible, as a richest field scope, it rocks.
#6 roscoe
roscoe
    curmudgeon
Posted 12 July 2012 - 04:58 PM
Yeah, it'd make a great 60mm finder-scope!
#7 Muhammad Arif
Muhammad Arif
Posted 20 July 2012 - 06:45 PM
Converting this to a finder is a great idea and I couldn't resist the temptation of having a 60mm finder. So, I picked it up. Pics to follow.
#8 Muhammad Arif
Muhammad Arif
Posted 20 July 2012 - 06:54 PM
pic 1
#9 Muhammad Arif
Muhammad Arif
Label
#10 mdowns
mdowns
Posted 20 July 2012 - 08:41 PM
In the past I collected a stack of spotters. I had several Monolux in the group though I think they were all prismatic spotters. The brand didnt carry any real value though they can be fun and to me,that was always the point.To collectors this model probably wont generate alot of interest.However,it is a circle't',Towa made model, which someone might find appealing. Harder to find american made spotters like Argus and B&L always retain value.
#11 Muhammad Arif
Muhammad Arif
Posted 21 July 2012 - 01:04 PM
I totally agree. "Fun" is the main reason here - I'll have fun converting it to a finder and in the process, I won't destroy anything that's valuable or collectible.
#12 Muhammad Arif
Muhammad Arif
Posted 21 July 2012 - 01:07 PM
Looking through an old Tasco catalog (1968, I believe), this looks surprisingly similar to the Tasco 88TEZ.
#13 Muhammad Arif
Muhammad Arif
Posted 24 July 2012 - 11:53 AM
Now the fun begins - dissecting this little beauty. I'd like some help/suggestions but before I continue, should I move this to the ATM thread?
#14 roscoe
roscoe
    curmudgeon
Posted 24 July 2012 - 09:14 PM
When I dissected a somewhat similar scope, I found an image-erecting lens inside, mounted on a long internal drawtube.
I don't remember if it came apart, or if I amputated it with a fine-tooth blade hacksaw, but away it went! This changed the focal length to something rather shorter, I unscrewed the lens cell, taped it to a hunk of wood, and holding an EP in my hand, found something approaching the focus point. Then, I unscrewed the focuser, set it up like normal (with a diagonal, in my case), and taped it to the stick where I thought it should work.....then moved it around till 3 or 4 of my EP's focused sort of in the center of travel. Then, I measured the space and cut the tube - about 1/2" long just-in-case, tried it with everything in place, and ended up cutting another 1/2 or more off. Then, I had to mark and drill holes for the focuser attachment bolts, and it seems somewhere in there I had to move, and ultimately remove a baffle. I believe I ended up shortening the focuser drawtube some more, too. My focuser was a standard rack-and-pinion, if yours has that twist-to-focus, you'll have to work with what you've got.
I ended up putting a 45-degree erecting prism on mine, and use it as sort of a spotting scope, though it begins to get chromatic over about 30x.
Here's a photo of mine, with a paint job and a photo tripod mount:
#15 amicus sidera
amicus sidera
  • In Memoriam
Posted 25 July 2012 - 08:06 AM
I "dissected" an older Edmund reflector here over the course of about 10 pages, so I think you're safe! :grin:
#16 Muhammad Arif
Muhammad Arif
Posted 25 July 2012 - 01:59 PM
Well, I also found an old thread about another Monolux getting converted: http://www.cloudynig...ll/fpart/1/vc/1
I'll be posting some more pics soon.
#17 Muhammad Arif
Muhammad Arif
Posted 25 July 2012 - 02:33 PM
Nice spotting scope. I'm aiming for a decent finder at the end. Thanks for the info on how you determined the new tube length - I was wondering about that and I'll try your method. There is a separate tube with moving lenses to change the focal length for the variable magnification (sort of like a variable barlow) that was easy to remove. The focuser is rotating type (helical?) and I want to keep it.
#18 Muhammad Arif
Muhammad Arif
Posted 25 July 2012 - 02:37 PM
Here is the objective. Air spaced doublet? The outside surface has some dust but nothing major. The inside is clean.
#19 Muhammad Arif
Muhammad Arif
Posted 25 July 2012 - 02:40 PM
Here is the zoom mechanism. Rotating moves the two lenses closer or apart to change the zoom.
#20 Muhammad Arif
Muhammad Arif
The focuser. I really like the feel of it - so, I want to keep it and figure out a way to attach a 1.25" EP.
#21 Muhammad Arif
Muhammad Arif
Posted 25 July 2012 - 02:45 PM
The focuser has only about 5/8" travel and the drawtube is 1" OD. So, I'll have to figure out a way to attach a 1.25" EP - probably using an adapter.
#22 roscoe
roscoe
    curmudgeon
Posted 25 July 2012 - 10:35 PM
Wow, that's a pretty fancy focuser mechanism! If only the scope worked well, eh??
Any chance you could get a .965 tube inside that focuser end?? if so, you could adapt a diagonal to it. If you were planning to use it as a one-EP finder, 5/8" of focus travel would be plenty.....
#23 Muhammad Arif
Muhammad Arif
Posted 27 July 2012 - 11:30 AM
Great suggestion. And I did try a .965 diagonal and it fit like a glove :)
Now I just have to figure out a way to lock it down so it doesn't fall out.
#24 roscoe
roscoe
    curmudgeon
Posted 30 August 2014 - 05:46 PM
I tracked down ths old thread, because today the mailman brought me what looks like a practically brand new 1986  Monolux 4445 spotting scope, which looks exactly like the 'no-number' monolux posted here.
I'll resize and post some photos tonight.
#25 roscoe
roscoe
    curmudgeon
Posted 31 August 2014 - 07:26 PM
Here, as promised, is a photo of my seemingly brand new 1986 Monolux 4445  20-60 x 60mm spotting scope.  It came with a quite nice tabletop tripod, an instruction sheet, a Halley's guide, and except for a glue-smudge on the tube, appears totally unmarked, even the box is barely scuffed!
Optically, it's ok, but nothing special, my hope is to keep the twist-focus intact, and add a 45 degree correct-image diagonal to take .965 EP's.DSCN0752.JPG
