Mirror flop with C11HD, how bad
#1
Posted 06 September 2012 - 01:19 PM
I wonder with the mirror lock how the new C11HD handles the mirror flop issue.
#2
Posted 06 September 2012 - 03:52 PM
#3
Posted 06 September 2012 - 06:31 PM
#4
Posted 06 September 2012 - 07:00 PM
One thing I have learned to look out for is to lock the mirror when doing mount alignments, as there can be enough mirror shift on opposite sides of the meridian to affect modeling precision. After completing modeling (I have a Losmandy C11/G2) I then unlock the mirror and focus/center for whatever target I'm viewing and if I need precise goto, I can sync on a star near the object to correct for mirror shift effects.
#5
Posted 07 September 2012 - 10:44 AM
#6
Posted 07 September 2012 - 01:44 PM
Dan, a couple of arc minutes don't sound too bad. My C11 exhibited much more than that when used with a binoviewer, and in this case, the primary mirror moved farther towards the sky, possibly resulting in a larger gap between the main baffle and the primary holder and thus excessive lateral movement. Not only did I lose the collimation of the scope, but I couldn't build the pointing model when I carried out the star alignment for the Goto function of my mount. The flop was less severe when I use an EP w/ a 1.25" diagonal though. In the end, I lost my faith in the C11 and sold it at a great loss to someone who could cope with the issue.
Ed, that's my thought too. I would mainly use the C11HD for visual since I've got other scopes for AP. A Crayford focuser sounds like a solution, but I wonder if I could use my binoviewer with the focuser in place though.
#7
Posted 07 September 2012 - 02:02 PM
Thanks for your responses!
I'm not sure on the binoviewer since I don't use one myself. You would need to check on the back focus distances.
In any case, it sounds like the C11 you had was particularly problematic. So far, I haven't heard of anyone with the C11HD that has a severe mirror flop problem.
#8
Posted 08 September 2012 - 06:47 AM
I'll miss the super long focal length for those small targets, but should be happy enough with an 8-inch. -David.
#9
Posted 08 September 2012 - 04:55 PM
#10
Posted 08 September 2012 - 07:31 PM
#11
Posted 08 September 2012 - 09:36 PM
#12
Posted 09 September 2012 - 10:35 AM
#13
Posted 09 September 2012 - 11:40 AM
Are you sure it's mirror "flop" and not just a loose primary lock nut? The effect is similar but more severe and you loose collimation.
Though not the C11 I'm concerning about, I suspect my older C11 suffered from some loose part in the mirror support mechanism.
#14
Posted 09 September 2012 - 12:01 PM
I've posted on this subject before and given the magnitude of the damage to the views, I think it should be a sticky.
On a C11 you have to remove the corrector sorry to say. You will need a spanner tool to tighten the nut. The yahoo C14 group has a file that shows dimensions for making a spanner out of 3 inch pvc pipe and a couple 4-40 screws. You have to cut and drill a bit to make one, but it's not a big deal. I made one and it works on all the C14's and C11's I've tried. I just checked the dimensions of the pins on my homemade tool and they are approx 3.450 inches on center.
To use it all correctors must be removed with the exception of C14 fastar which has a large enough opening for the tool to work through. The pvc pipe fits over the central baffle and the cut off screws stick out as pins from the end. The pins fit into the corresponding holes in the lock nut and allow you to tighten it. The tool is safe and self guiding. No chance of hurting the primary.
I prefer to put the tool in with the ota horizontal and then turn it facing up. Gravity will then help you. I've found that it's useful to work the nut back and forth a bit. The goal is to get the primary to settle back into the factory position and properly compress the cork and fibre washer. You can make it quite snug (hand tight) without pinching the primary. It needs to be tight enough to hold the relatively heavy mirror precisely when orientation changes.
In theory, the cassegrain primary should be supported on it's center of gravity (by hardened silicone caulk in this case) and the tension of the nut shouldn't matter much. I think that maybe at F2 it's front heavy or maybe they didn't put in quite enough silicone.
For what it's worth since I've been aware of this problem, I've discovered it in several C11's and C14's.
#15
Posted 09 September 2012 - 10:45 PM
that is really useful information. I'm filing it away for future reference in case I ever have problems.
