ToHo H-45 (Eikow) 114mm x 1200mm VERY COOL!!!
91 replies to this topic
#76 Bill Griffith
Bill Griffith
Posted 29 October 2012 - 09:50 AM
Another great thread Scott.
Your attention to detail and turn around time is second to none!
The light shield is perfect and still fits in the very nice case!
:woohoo:
#77 bremms
bremms
Posted 29 October 2012 - 11:49 AM
Very cool scope, and nice work.
#78 starman876
starman876
    Nihon Seiko
Posted 29 October 2012 - 01:06 PM
Vrey nice scope
#79 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:27 PM
Since my DEC locking rod is MIA and replacements are scarce, I decided to make my own. I picked up some pieces at the hardware the other day for the project. Here is the 3/16" x 36" plated rod, various knobs, 10-32 barrel nut and nylon washers. Not shown is the 10-24 T-nut and 1/4 nylon washers.
Also, the rod has already been cut to length (8 1/2" original length, thanks Keith) and threaded on both ends with a tap and die set from work. The long thread is 10-24 and the short thread is 10-32.
#80 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:31 PM
Also needed a little Loctite 271 High Strength thread locker. This needs to be put on both rod and knob ends.
#81 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:34 PM
Placed the assembly in the vise. Notice the soft aluminum channel in the vise jaws used to protect the rod. Tighten the whole assembly.
#82 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:36 PM
Completed handle end.
#83 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:39 PM
Now for the other end that will screw in to the DEC housing to lock it. This is the 10-24 long threaded end. Also installed a backing nut, nylon washer and SS flat washer. The original would have had only a collar here. This completes the handle.
#84 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:47 PM
Now for the DEC clamp. The holes in mine are very close to 1/4" but I had to open up the back hole slightly to make it 1/4". There are no threads on either side but the back side had a small hole for some type of pin, which was missing also. I guess to keep some sort of nut or threaded collar from rotating. I found a roll pin that fit it perfectly. Here it is installed.
#85 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:50 PM
I then modified a 10-24 T-nut and 1/4" nylon washer to accept the roll pin and keep it from rotating.
#86 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:55 PM
1/4" Washer installed. The outside diameter of the threaded portion of the 10-24 T-nut is also 1/4" and will pass through the 1/4" nylon washer and into the 1/4" hole of the DEC clamp. Just line up the roll pin hole.
#87 Compressorguy
Compressorguy
Posted 04 November 2012 - 03:56 PM
And installed.
#88 Compressorguy
Compressorguy
Posted 04 November 2012 - 04:01 PM
Finally with the rod installed!
What do you think?? Not exactly original (the original looks more like a small screwdriver handle) but I like it. I think it captures the essence of the original and compliments the RA and DEC slo/mo controls well.
#89 Compressorguy
Compressorguy
Posted 04 November 2012 - 04:02 PM
Close up.
#90 Compressorguy
Compressorguy
Posted 04 November 2012 - 04:04 PM
Dare I say Unitron'ish looking?
#91 Compressorguy
Compressorguy
Posted 04 November 2012 - 04:07 PM
It works flawlessly, locks positively and with very little effort. All for less than $10.
It sure works alot better than this and a screwdriver in the dark!!
#92 starman876
starman876
    Nihon Seiko
Posted 04 November 2012 - 07:33 PM
A great job of engineering.
