2" Eyepieces on a C-8
4 replies to this topic
#1 Thom_Tapp
Thom_Tapp
Posted 16 September 2005 - 08:46 AM
What would I have to do to use 2" eyepieces on my orange tube C-8? Would I see much difference?
Thom Tapp
#2 khoferer
khoferer
Posted 16 September 2005 - 10:33 AM
You would need a diagonal that accepts 2" eyepieces and, depending on the model you might choose, an upgrade to your visual back. Generally speaking, you will be able to see a wider field of view with 2" eyepieces. Any differences you might see would depend on which eyepieces are chosen at a given focal length.
Clear skies,
Kevin
#3 Burnim
Burnim
Posted 16 September 2005 - 11:00 AM
The load on my original N8 (single fork) with a 2" diagonal and a big, fat, 2" ep required counter weights. Motors didn't like it much.
B
#4 John_Gillies
John_Gillies
Posted 19 September 2005 - 06:50 AM
Hi Thom,
Let's see...you're asking about 2" eyepieces here and about focal reducers over there. You might want to consider a diagonal upgrade to a Denkmeier 2" Power x Switch Star Diagonal. Their #S1 model has a Dual Arm Power X Switch that enables focal reduction and barlowing with only the slide of a switch. So with one eyepiece you get 3 magnifications without changing anything out. You can use 2" and 1.25" eyepieces. Give Denkmeier's website a look over.
#5 sixela
sixela
Posted 19 September 2005 - 07:09 AM
Hi Thom,
I'd have to add that it's usually pointless to try to combine the two for *even* wider views - on the C8, the secondary baffle's clear aperture restricts the illuminated field anyway.
