Any 18"UC owners out there?
77 replies to this topic
#76 Papa Taylor
Papa Taylor
Posted 02 July 2013 - 10:28 AM
Here is something you can check. Determine how much in-focus range there is remaining when viewing a star (or other object at infinity). If you have 1/2" and you loose 1/4" after combining the two rings together then problem solved.
JimC
Thanks, Jim
I will take the scope out and check this if it ever stops raining. :smirk:
#77 wfj
wfj
Posted 14 July 2013 - 11:27 PM
You can also have the stiffening plate avoid the mechanical interference with the strut fasteners and then not have to modify the length of the TE
I like this suggestion. So are you saying that the aluminum ring could be pierced to allow an open space for the top truss brackets to still contact the birch ring directly?
Correct. Realize that stiffening affects the entire component and does not have to be over the entire surface to work. Also, stiffness comes from the surface/shape of a geometric support, not the volume/weight of material.
The parts of the aluminum ring that would then be left going around the truss mounting brackets would not be very big. Might this be a place where deflection would still occur?
Unlikely but remotely possible. By the way, you should check the brackets as well as possibly cracked.
I would also inspect the bracket to see if it was not flat but convex - that would be an example of how you might get the appearance of flexure without any breaks, because the thrust bearing angle of the TE's might rotate/tilt because the bracket isn't fixed against the ring, allowing freedom of movement.
The general theme is to "stiffen" a structural member and see if the deflection amount changes - sometimes you don't need to stiffen everything.
#78 Almagne
Almagne
Posted 12 August 2013 - 02:44 PM
Although this thread is a month dead, here is a link to the ATM forum, where my fix for the upper ring flexing is shown:
http://www.cloudynig...6017607/page...
