Swarovski ATX 95 binoculars
171 replies to this topic
#151 DRodrigues
DRodrigues
Posted 30 March 2017 - 03:48 PM
I heard Swarovski objective is optimised to use with their prism module, so use it individually will downgrade its optical quality. ...
I hoped you were wrong but it seems not... http://www.pt-ducks....i_X_derivations I still didn't test if a star diagonal or prism correct the image quality but the Vixen lens erector do.
#152 Tamiji Homma
Tamiji Homma
  • Loc: California, USA
Posted 31 March 2017 - 09:02 AM
just wondering if anyone's had a chance to use these for star gazing?
cheers
Jeelan
Which instrument are you referring to?  ATX95 binoscope? It is my primary night sky gazing instrument.
I've had a few hundred hours under the skies with it since I got it.
Tammy
#153 Jeelan
Jeelan
  • Loc: Perth, Western Australia
Posted 01 April 2017 - 08:28 AM
hi Tammy,
sorry, I was referring to the BTX binocular module on the 95mm objective...
havent seen any comments around how this is for stargazing so just curious..
cheers
Jeelan
#154 Tamiji Homma
Tamiji Homma
Posted 01 April 2017 - 10:25 AM
hi Tammy,
cheers
Jeelan
Hi Jeelan,
BTX isn't yet available at least in the U.S. market.
I posted that I would be interested if Swarovski came up with binoviewer module.
https://www.cloudyni...e/#entry4897332
Yes, I am interested in, even though it is limited to 35x without extender.
Tammy
#155 DRodrigues
DRodrigues
Posted 23 April 2017 - 06:04 PM
I had a chance to look through a BTX a couple of weeks ago and today I updated my http://www.pt-ducks....#CR-binoviewing info with a BTX small test and comparing it to my STX as also to my CR-binoview combo. I found some interesting points that no one mentioned until now:
- there are absolutely no ghost images at all!!! My MARK V have these if I look for...;
- there is no polarising effect within both ocular sides;
- within some lowlight conditions the BTX bested my STX! This might be interesting for astro use although others mentioned a small increase of CA compared to the STX, that also shows minor CA - having used extensively my Optolyth 100, I hardly notice any CA on my STX95... The X85 is supposed to be better corrected for CA but I never tested one.
More info and photos at the page.
  • teelgul likes this
#156 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 02 September 2020 - 12:57 PM
A 115mm objective module is coming for the ATX.
Tammy, we're looking forward to your upgrade! ;-)
  • ianatcn and ArsMachina like this
#157 Tamiji Homma
Tamiji Homma
Posted 02 September 2020 - 10:57 PM
Really?  Upgrade? I've already done binoscope upgrade.
115mm objective module probably won't fit current binoscope harness for ATX 95.  It probably runs out of backfocus. Setting objective module a little wider apart to align two OTAs in parallel eats backfocus unless new objective module has more backfocus than ATX 95 objective module. But it may be a good excuse to get it with BTX if it is true :)
Tammy
  • Mark9473 and ianatcn like this
#158 edwincjones
edwincjones
    Close Enough
Posted 03 September 2020 - 04:32 AM
question.gif     Is it-BirdForum's thread indicates that this is just a rumor
edj
#159 range88
range88
  • Loc: Shanghai
Posted 03 September 2020 - 05:11 AM
edj
Recent rumors(eg. the SF32 rumor, the big afov Swarovski rumor) did come true.
This is no exception.
#160 PEterW
PEterW
  • Loc: SW London, UK
Posted 03 September 2020 - 05:31 AM
If you’re fit you could just buy some 120mm ED binocukars.... my 70mm bins provide some great views.
Peter
#161 DRodrigues
DRodrigues
Posted 03 September 2020 - 05:41 PM
I also hope that will be released with improved eyepiece modules to reply to Harpia...flowerred.gif
A variable focal length extender would also be interesting for the BTX users...grin.gif
#162 DRodrigues
DRodrigues
Posted 03 September 2020 - 05:48 PM
...unless new objective module has more backfocus than ATX 95 objective module.
It should be parfocal. With the increased aperture you can use 2 OCSs to regain some backfocus,,,wink.gif
#163 DRodrigues
DRodrigues
Posted 10 September 2020 - 02:10 PM
Confirmed https://aa.swarovski...module-p5006348
Expected price 2870 euros...
  • Mark9473 and ArsMachina like this
#164 PEterW
PEterW
Posted 10 September 2020 - 04:56 PM
Looks like a snake that’s swallowed an elephant. Wonder it we’ll see others making larger objectives.... how much weight will birders want to carry?
Peter
#165 ihf
ihf
Posted 10 September 2020 - 08:00 PM
The BTX halves the brightness. Isn't that somewhat unpleasant in daylight? Just curious because birders usually care about the last percentage point in transmission...
#166 range88
range88
  • Loc: Shanghai
Posted 10 September 2020 - 09:24 PM
The 115 looks very head-heavy.
The optic is fantanstic, esp. the CA control is noticeably better than 95mm, a wonder for a 115mm F4.8 objective. Report has it that it can easily support over 200x and the optic is better than any right angle telescope(except the ones equipped with Matsumoto EMS) in this world. I bet they use multiple ed glasses.
#167 range88
range88
  • Loc: Shanghai
Posted 10 September 2020 - 09:26 PM
So I bet when they pair with EMS, the optics will be...
#168 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 11 September 2020 - 02:43 AM
... mediocre? I can't see how switching from a prism to a mirror wouldn't hurt the image.
#169 edwincjones
edwincjones
    Close Enough
Posted 11 September 2020 - 08:03 AM
these have  long been on my wish list, but
 I  would  have to choose between  binocular view or zoom viewing
or get both options that cannot be used together.
edj
#170 Tamiji Homma
Tamiji Homma
Posted 11 September 2020 - 10:47 AM
I would think that they need a riser something to attach long dovetail rail to tripod collar to clear the fat objective module to shift center of gravity.
The 115mm objective module weights 2.1 Kg.  The 95mm objective module weights 1.34 Kg.
I'll check it out when it is out :)
Tammy
#171 Tamiji Homma
Tamiji Homma
Posted 06 October 2020 - 05:21 PM
I placed my order of 115mm objective module.  It looks like it would take 4 - 6 weeks to deliver...
In case you haven't seen the optical bench test of ATX 95 objective module.
https://www.cloudyni...5-optical-test/
Tammy
  • Erik Bakker, ianatcn and ArsMachina like this
#172 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 07 October 2020 - 04:02 PM
