MCT Secondary Baffle Mod
193 replies to this topic
#101 azure1961p
azure1961p
  • Loc: Triton
Posted 28 November 2013 - 08:25 PM
The last one is subtle but the sky is even a little bluer. Its enough that at least in daytime spotting Id opt for the dew shield ontop of everything else.
Pete
#102 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 28 November 2013 - 08:58 PM
I plan on a shoot out after I complete both of mine. I will then compare the contrast from the C6 vs my 6 inch refractor. Seems many SCTs have gotten a bad wrap because of poor baffling.
#103 Ed Holland
Ed Holland
  • Loc: San Jose, CA and Oxford, UK
Posted 29 November 2013 - 12:36 AM
Pete - thanks for doing the crops on my pics, it really highlights the differences.
#104 azure1961p
azure1961p
  • Loc: Triton
Posted 29 November 2013 - 02:05 AM
Ed -
No problem. Do you infact do daylight spotting with the Mak? Now and again I like to take out the 70mm refractor to the shore and such. I'm promising myself to take the C6 too - but after seeing this - Ill wait till I flick it out.
Again a great set of revealing pics.
Pete
#105 azure1961p
azure1961p
  • Loc: Triton
Posted 29 November 2013 - 02:09 AM
I'm very interested in your results. The primary baffling on the pic you presented would appear to be throwing glare from its exterior . I suppose this could be wrapped in flocking too?
I look forward to your tests and pics.
Pete
#106 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 29 November 2013 - 05:14 AM
Powell, Don, thank for adding to this thread. It seems I have more work to do, too. Very nice.
My scope also has that ~2mm ring of unused secondary. I guess a nice rubber ring outta do the trick. That plus a few additional mods Don mentioned. I added a knife edge in the bottom of eyepiece insert tube of the diagonal just above the mirror. Eyepieces still fit with the barrels not quite reaching that deep into the diagonal and stopping just short of that knife edge. This seems to block scatter inside the diagonal eyepiece barrel from bouncing into the eyepiece itself. It's just an appropriately sized (square) rubber ring, too.
Ed, how did you mix your flat black paint. It's time to try some of that but am concerned about out-gassing, as well. Thanks in advance.
#107 azure1961p
azure1961p
  • Loc: Triton
Posted 29 November 2013 - 10:55 AM
What's with the out gassing thing anyway? Protostar sells flocking paper recommending double backed tape - has anyone ever had issues here? Its prudent to exercise caution here but protostar seems like they've got this kinda thing in hand. I might order some flocking paper and do the entire sct interior . I'm 50/50 on the out gassing - I get how it'd happen but I think it'd been more documented at this point if it were happening. Still I'm cautious .
I have to believe at this point when folks have talked about their apo having the same contrast on deepsky nebula as much larger sct that the culprit here is all that off axis skyglow in the optical train bouncing off the baffles and such.
For the reflector Ive thought of have a black velvet insert opposite the focuser as a definitive black backdrop to the light one entering the eyepiece.
Pete
#108 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 29 November 2013 - 12:23 PM
Not sure what products out-gas, Pete. Never heard of commercial flocking do it.
I'm sure the refractor guys talk about their baffling, but really the end result to contrast is a combination of lens scatter, sky glow, and internal reflections. We can't do much about the former two, but the latter we can get a handle on. So, that leaves sky glow and lens scatter with the latter being the only thing to boast about, optically anyway. In the tropics, atmospheric scattering (humidity plus aerosols) can be pretty hard on a guy especially with bright objects. But flocking and baffling gets rid of what we can get rid of, so it's worth the effort as Ed's images show. But, improvement's harder to see against dark skies and dim stars. Just knowing it's there, though, is nice when you turn your scope to Jupiter.
#109 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 29 November 2013 - 10:39 PM
OK, just finished the C90. What a pain this all was, but a good pain. To do it right I had to pull the whole unit down and man it has a lot of little, washers, spacers and a ton of grease, to much grease. Soon as I got it apart, I had grease everywhere! I intended to take pictures pulling it apart but no way was I going to touch my camera with all the grease I had on my hands. So I wiped all the grease off with paper towels and put the parts in the sink for a good washing. I used GoJo first to cut the grease and then dish liquid for the final wash. It worked really good and the parts came out squeaky clean.
I then baked the parts in the oven at 200 degrees for 20 minutes to get them dry and hot before painting them. That was the easy part! Due to how smooth the primary baffle was on the inside, even after painting it with flat black, there were still small reflections from it. So, I went the way of Mr. Ed Holland and opted for a painted and rolled up tube of sandpaper of 180 grit. This most definitely did the trick! I also used a black marker around the edge of the primary mirror to blackened the reflective 45 degree edge.
This scope is so small it is hard to work on with all the rubber o-rings and washers. So it was a bit of a pain to put it back together. Not hard, just tedious. What was a pain was collimating the scope after a complete disassembly. I also found that the mirror was off center on the baffle slider and shimmed it with masking tape to center it and take up the slack on the baffle slider tube. So was all this work worth all the trouble? You bet! The little scope now star test better than it did before! There are also no more flares from bright stars, etc. And as Ed had shown, the contrast seems to be about four times better.
I know it's a little scope and that actually makes it worse, so don't jump into this mod if you have never done this kind of work before. I have rebuilt many scopes and binoculars and this was still a challenge for me. The good news is, I really love this little scope now!!
Tomorrow, I will try to post some images taken through the scope before and after the mods. Until then, here are some pictures of the C90 as I was doing the work...
#110 PowellAstro
PowellAstro
  • Loc: Tennessee
Another...
#111 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 29 November 2013 - 10:40 PM
Another one...
#112 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 29 November 2013 - 10:41 PM
Another another...
#113 PowellAstro
PowellAstro
  • Loc: Tennessee
Another another one...
#114 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 29 November 2013 - 10:42 PM
Last one...
#115 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 29 November 2013 - 11:23 PM
:gotpopcorn:
I wait your results. Excellent. Thank you for posting, I might have to probe deeper and do some flat backing. Your baffle 'looks' darker. Really curious to know if there is a noticeable improvement.
#116 hardwarezone
hardwarezone
  • Loc: Singapore
Posted 30 November 2013 - 06:16 AM
Thank you for the photos of the scope innards, I downloaded all of them.
#117 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 30 November 2013 - 03:05 PM
OK, here are the before and after shots from the C90. Both were taken with a Canon EOS 7D at prime focus and no processing was done. They were both shot in manual mode at 1/640 of a second, in standard mode. Each shot was at ISO 400. These are 100% crops from each image about the same time of day, around 2:15 - 2:30pm. I like what I see!! The C6 is next on the list to get this treatment!
  • Zachrey likes this
#118 PowellAstro
PowellAstro
  • Loc: Tennessee
Now after...
  • ANM and Zachrey like this
#119 GlennLeDrew
GlennLeDrew
Posted 30 November 2013 - 04:23 PM
Glen,
Were those two pics taken on different days? They look so similar that you must have taken them at very nearly the same time, indeed, and not so many days apart (given the Sun's lowering declination.) And from pretty near the spot. I can detect only a slight difference in the placement of the vertical shadow near the bottom.
The contrast difference is most striking.
#120 miketz
miketz
  • Loc: Greece
Posted 30 November 2013 - 04:28 PM
Ok. The difference in contrast is huge. Well done. Especially for a scope like C90 ,which can easily used as a spotting scope, the mod is extremely successful. However, after reading Edgie's thread, I think also that in night time use the effect will be much less noticeable and probably insignificant,depending on the target. If anyone else decides to do similar flocking mod, it would be interesting to provide us with night time photos of landscape objects. Some poor light urban areas maybe, that can simulate better situations like while observing the moon or planets. Oh by the way excellent thread!!
#121 GlennLeDrew
GlennLeDrew
Posted 30 November 2013 - 05:32 PM
Veiling glare is most detrimental on the darker parts of the scene. The scene brightness is increased *linearly* in all parts. But the resulting brightness *ratio* is decreased; adding a quantity of glare to a dark zone is relatively a larger brightening in that area than results from the same glare superimposed on a brighter zone. The result is a 'flattening' of the brightness range, which is a decrease in contrast.
If the scene has uniform brightness, such as a patch of blank daytime sky, veiling glare increases brightness but does not alter contrast, for there was no contrast to begin with.
A nighttime sky is in a fashion different to the kind of daytime scene illustrated above. The latter sees the generally lesser 'shadow' zones affected most. A night sky is more like a vast shadow zone with a very much smaller collection of brighter highlights. Yet the same principle reigns. The veiling glare raises the brightness of the sky relatively more than it does for the brighter parts, thereby reducing contrast.
And the eye is primarily a contrast detector. Veiling glare afflicts all scenes having any intrinsic contrast, always lessening it.
#122 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 30 November 2013 - 06:18 PM
If you look at my first picture showing the problem I was having, you will see flares off of almost any object, even 5 or 6 mag stars. The image is shown as an inset image. This was at night and it would happen in every image. So, it does make a huge difference at night because those flares are now gone!
@ Glenn
They were shot a day apart within about 20 minutes of the same time of day. And the tripod was marked and in the same spot.
#123 GlennLeDrew
GlennLeDrew
Posted 30 November 2013 - 06:31 PM
Glen,
You got onto and finished that mod/enhancement in mighty short order! And good work it is. We amateurs fret and fuss over infinitely tinier differences than shown here; wander over to the refractor and eyepiece Forums to see what I mean. :grin:
#124 PowellAstro
PowellAstro
  • Loc: Tennessee
Posted 30 November 2013 - 06:48 PM
@ Glenn
After I took the pictures yesterday, I came in and pulled it down. I started cleaning and washing parts and once I had it all cleaned, I heated parts in the oven and went out back to paint. While they were drying, I took a break for dinner. After that, it took an hour or two to put it back together and get it collimated.
#125 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 30 November 2013 - 10:17 PM
Glenn, absolutely. I think observing is a game of micrometers. When optimizing we struggle with every faint gain we can get to observe both very faint objects as well as planetary contrast. I suspect many amateurs would love to squeeze every bit of performance from our instruments, which is why we argue over minutia of it all.
Glen, I find your results nothing short of astonishing, especially since the artifacts that troubled you are gone. Very well done. In your case, the results are definitely showing some improvement. In my case, I really do not notice much, if anything as Eddgie talks about, but I cannot escape the idea there has been improvement. And that's enough reason to pursue it, if one is so inclined. Seems I still have some room for additional improvement since this thread was revisited (thanks, Pete!) :)
