SR 4mm lens arrangement
#1
Posted 19 August 2013 - 04:57 PM
#2
Posted 19 August 2013 - 05:06 PM
Two plano convex lenses. Same focal length and diameter, thus symmetrical
Eye and field side flat. In between curved facing each other.
#3
Posted 19 August 2013 - 05:07 PM
#4
Posted 19 August 2013 - 05:10 PM
Maybe it's time to get the magnifying glass out!
#5
Posted 19 August 2013 - 05:15 PM
If there's an meniscus lens, it's probably part of a HM eyepiece.
If its convex on both sides, it may not be even from an eyepiece - possibly a microscope objective.
Check the focal lengths for a hint.
#6
Posted 19 August 2013 - 05:19 PM
I'll have another look tomorrow, it's difficult with such small lenses!
#7
Posted 19 August 2013 - 05:33 PM
Or, if it's a "standalone", the source/sink of the other parts may be inaccessible.
Where this happens, is someone takes apart all of the lenses and either leaves them in a pile or randomly reassembles them. Seen both.
#8
Posted 20 August 2013 - 02:12 AM
The SR 4 shows no evidence of being tampered with as the paint seals were intact. Having a quick look now (before dashing off to work) at the assembled eyepiece the eye lens certainly looks as if it has a convex outer surface (although I might have reversed the lens - despite trying not to - when I dismantled the eyepiece a couple of days ago). The field lens looks similar although it is harder to tell as it is recessed in the barrel and I didn't have time to unscrew anything.
However, the SR 5 mm from by SNS badged Eikow looks like it has plane surfaces on the outer side of both the eye and field lens, as expected from the Ramsden diagram in your post above.
If I get time tonight I plan to have another closer look at the SR4,
#9
Posted 20 August 2013 - 08:27 AM
#10
Posted 20 August 2013 - 10:19 AM
I don't know why they called this a symmetric design, but it surprised me that both the eye lens and field lens were double convex, albeit of different diameters. The eye lens is symmetrical, and field lens appears to be more convex toward the field stop; but since I have no tools to measure this on such a tiny lens, I don't know for sure.
I made a small paint brush out of a tiny piece of rolled newspaper and used it to blacken the interior of the field stop barrel. After cleaning the lenses by soaking in alcohol, I reassembled everything and found a marked improvement in flare control. As Terra notes, these can give very decent images, aside from the almost non-existent eye relief. It became one of my favorite high power "experimental" eyepieces (until I sold it with the 313). A Unitron Or. 4mm has now taken its place.
Here are some photos: (the ruler does not indicate the proper spacing between lenses)
#11
Posted 20 August 2013 - 11:41 AM
#12
Posted 20 August 2013 - 12:05 PM
Marc, well, the eye lens is symmetrical! Maybe it's a Surprising Ramsden!
#13
Posted 20 August 2013 - 12:09 PM
I have found that well made SR 5mm and HM 6mm eyepieces are not bad when used within the 60X per inch limit. I have a couple of Royal Astro and APLs that are really quite good.
Hi Terra, that's encouraging. As acquired both the Topic/Towa and SNS/Eikow lenses were quite dusty so the views weren't that great.
I've also just bought a hybrid diagonal so I can try my other eyepieces and am also thinking of getting the Vixen 36.4 mm to 1.25" adapter.
#14
Posted 20 August 2013 - 12:12 PM
Took it apart and it was a Plossl or achromatic symmetrical. not an Ortho. Felt a liitle cheated..But it still gave a good image. The 10mm Celestron Halloween 0.965 (still have)plossl was clearly better.
#15
Posted 20 August 2013 - 03:16 PM
#16
Posted 20 August 2013 - 05:14 PM
I think what you've both got is a longer focal length eyepiece fixture that someone used up the inventory for.
So what they did was order up lenses to fit "good enough" - they made a "modified" Huygens out of.
If you test it, I suspect you'll find a) it's longer than 4mm EFL, b) its got the AFOV of a Huygens, and c) its got significant field curvature.
A case of "I'm short parts and need to make shipment".
#17
Posted 20 August 2013 - 06:37 PM
I've known the symmetric design to have two identical simple lenses, as if it were a non-achromatic Plossl. The SR lenses were nowhere near that design, although one known design for a simple magnifier does employ two double-convex lenses spaced inside their focal lengths from each other, and the arrangement doesn't appear to exhibit terrible field curvature.
#20
Posted 22 August 2013 - 10:59 PM
#21
Posted 23 August 2013 - 04:20 PM
We're now in London visiting our son where my Topic scope lives, but, unfortunately, it's overcast tonight so no chance to see how the cleaned lenses perform. Probably just as well after a 12hour trip with delays due to Bank Holiday traffic/accidents and frequent stops for the dog to stretch her legs!
