Inexpensive BT serial adapter for Sky Safari
127 replies to this topic
#126 MisterBill
MisterBill
  • Loc: Geezerville aka S.FL, MILE 271
Posted 24 November 2018 - 09:52 AM
"Does anyone know if the battery connector for this battery actually fits the on board connector?  I'm having trouble finding a connector that will plug into the jack on the board."
Yes it does.  However, make sure the polarity is correct. I had to use a knife to lift the board connector and turn it 180 degrees so the red wire would face the center of the board. YMMV,
other than that it works.
Bill
#127 Revtec
Revtec
Posted 26 November 2018 - 09:11 PM
Bill
Bill,
Thanks for the reply.  Did you just force the plastic plug away from the pins and then reseat without unsoldering?
I actually finally found a connector that fit from my local hobby shop and I noticed that the polarity was backwards, which would not be a big problem since I will have to solder the plug's wires to a battery anyway.  Still if your knife trick works easy enough that sounds like a better option.
Dennis
#128 MisterBill
MisterBill
Posted 27 November 2018 - 04:48 PM
The plastic just lifts from the board. In fact you can take it off, bend the pins to fit other battery connectors and leave it off. The pins are very stiff wire, no soldering required.
Good luck,
Bill
