Miscellany
680 replies to this topic
#601 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 29 November 2018 - 10:44 PM
 Excellent that the secondary is Cervit. Since a cassegrain secondary can have a power from 2x to 5x or even more, you don't want the figure changing with temperature since it can have  a large effect in image quality and focal position.
  As for the using the Sun I think that is your best bet in finding the focus at the cassegrain focal plane. I was just try to point out that the diameter of the  image your going to get isn't got to by a point but a very  large disk. So you need to look for that.
                  Happy Holidays,
                    - Dave
Edited by DAVIDG, 30 November 2018 - 09:40 AM.
#602 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2018 - 11:35 AM
I very carefully miked the secondary knowing a small error in my measurement will probably make a
big difference and the sagitta is .030" thirty thousandths.
We have these known measurements:
Primary diameter 7-5/8"
Primary ROC 86.5"
Primary fl 43.25"
Primary fr 5.67
Secondary diameter 2-11/16"
Secondary sagitta .030"
Do you think the secondary fits the prescription?
I did try this calculator and it doesn't seem to fit, but it may be the wrong application for a convex secondary
especially if its not spherical and may have a hyperbolic or partial hyperbolic figure:
https://stellafane.o...ag2fl-calc.html
Robert
Edited by clamchip, 30 November 2018 - 12:17 PM.
#603 DAVIDG
DAVIDG
Posted 30 November 2018 - 12:19 PM
 Doing a little math,  the sagitta = r/ 2 R  and we know that r = 2.6875 / 2  and S = 0.030 I get a radius of 30.09".
Assuming that the  design calls for a  4x secondary, the cassegrain focal length is going to be 173.0". Doing a bit more math and I find that with  a 30" radius on the secondary and 173" focal length the back focal is 13" behind the primary and the separation between the primary and secondary should be 32.0"  So the reason why you might not be able to get an image is that the secondary needs to go back more.
        - Dave
Edited by DAVIDG, 30 November 2018 - 12:28 PM.
#604 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 30 November 2018 - 01:39 PM
Hope you guys don't mind, but I love playing with the  math:
RC of the secondary = 2 x p x p'
                                       p' - p
If I used the numbers that I guessed at previously,
RC = 2 x 10.25 x 41    =    27.3"
              41 - 10.25
So the sag of .03  is in the ballpark.
#605 DAVIDG
DAVIDG
Posted 30 November 2018 - 02:24 PM
 Here is another way to find the approximate position of the secondary. You'll need two people and a finder scope or binoculars that are focus at infinity.
   Tape a bright light like LED to the end of the eyepiece focuser tube.  You may want place a star diagonal in the focuser tube and tape the LED to where the eyepiece would go. The star diagonal will give a couple of more inches of back focus and the scope should have been designed to work with one.
     Stand back a couple of feet from the scope and look through the binoculars/finder into the scope ( ie at the primary) You should see the light bulb. Now have someone rack the focuser tube through it's full range of travel and see if at any time the bulb comes into sharp focus. If not move the secondary a little and try again. Hopefully you will  find a spacing of the secondary that the bulb comes to focus. Since the secondary is most likely not figured, you most likely won't find a sharp image but still you should see one that isn't too bad.
                    - Dave
#606 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2018 - 08:04 PM
Thanks you two, I would not be able to work on this telescope without your help.
I'm going to try the new numbers tomorrow.
Something I'm a little confused over is if the secondary radius of curvature is 30 inches
won't the secondary's focal plane be half that at 15 inches? it looks like secondary to
focal plane is going to be around 45 inches.
Robert
#607 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 30 November 2018 - 08:41 PM
Yes, if the RC of the secondary is 30", it's f.l. will be 15".
The secondary, according to the parameters that we guessed at, should be about 33" from the primary.  But I think you said the professor's measurement was 30-3/4".  What distance do you have in your set up?
As was said, small movements in the secondary can move the final focus a lot.
Since we don't have the actual parameters (I love that word), finding focus may not be easy.  It will be a lot of trial and error.
I won't show the math, but I played with the formula with the parameters from before, just to give you an idea.
Starting with the secondary 10.25" inside the f.l. of the primary, the final focus would be 41".  (10.25 x 4 = 41).
Now if we move the secondary away from the primary by .25", the focus moves to 37",  4" in, and the amp changes to 3.7.
If we move the secondary .25" toward the primary, the focus moves out to 45", and the amp becomes 4.2.  (but we really don't have to worry about the amp)
So moving the secondary away from the primary, moves the focus in, and vice versa.
#608 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 30 November 2018 - 08:59 PM
I then plugged some other number's in.
If the separation of the mirror's is 30.75", as the professor had.  And you had a sagittal of .03 giving a RC of 30".
The number's don't work.  (doesn't the sag have to be measured to three places?)
if the separation of the mirror's is 30.75", then the secondary is 12.5" inside the focus.  If the amp is 4x, as we guessed at, then the focus would be 50"  (p = 12.5", p' = 50")
But something isn't right, for if I use the RC of 30" and have p = 12.5", plugging the numbers into the formula, p' becomes 75", not 50".
Sorry, that was a little math, just to show that something is wrong.
So, it's just going to be a lot of trial and error, of moving the secondary around to get a BFL of 8 to 10".
I hope I haven't made this discouraging.
#609 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2018 - 09:01 PM
The professor placed the secondary 30-3/4" from the primary, he may have done this because he
had done the math, or just locked it down in the center of it's travel. You can see where the hub has been sitting
on the shaft for half a century, since he last worked on the scope. From talking to the professor work ceased on
this telescope when his studies at the Yerkes Observatory and Univ of Chicago got pretty heavy and left him with
no spare time.
#610 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 30 November 2018 - 09:08 PM
In #598, what is the distance between the secondary and the primary?
#611 clamchip
clamchip
  • Loc: Seattle
Posted 30 November 2018 - 09:18 PM
That's the 'as purchased' default setting of 30-3/4" here is the setting:
Edited by clamchip, 30 November 2018 - 09:20 PM.
#612 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 30 November 2018 - 09:29 PM
Hmmm, doesn't look like there's much room to move it back.
If you could just get a good far away light source, the whole set up could act like an optical bench.  Or a flat and use DP.
Maybe you could make a sliding section to mount the secondary, that fit inside the tube.  You need to find a focus somewhere.
#613 DAVIDG
DAVIDG
Posted 30 November 2018 - 11:49 PM
  A minor technical detail, the secondary is convex so it doesn't have a focal length on it's own since the light reflected off the  the convex surface is divergent. So in this application it increases the focal length of the primary.
   Since this is a  home  made instrument  you always have to consider that the radius on either or both of the mirror was not made to spec.  When you make a mirror for  a Newtonian if you miss the exact focal length it is not an issue. It is easy to calculate the correction and easy to modify the design of the OTA to fix the actual focal length.
   It's  a  different story when you have a  multi-element system and the elements all have optical power. Now the radius, spacings and figures all have to be within tolerance or it wouldn't work. The need to work much more accurately is missed by many ATM's when they decide to try a system more complicated then a Newtonian.  So when things don't make sense, don't rule out the optics weren't make correctly.
    To solve this mystery you need the exact radius on the secondary. Once you have that you can calculate if it will work with this primary or not.
                          - Dave
Edited by DAVIDG, 01 December 2018 - 09:44 AM.
#614 TSSClay
TSSClay
  • Loc: Manchester MI
Posted 01 December 2018 - 08:23 AM
Dave,
I wonder if a Coordinate Measuring Machine (CMM) would be able to give an accurate radius of the glass?   I know they can take a great number of point readings and integrate them all together.
I have one of these at the shop and if Robert wanted to ship the secondary to me I could measure it for him.
Clay
  • clamchip and Garyth64 like this
#615 DAVIDG
DAVIDG
Posted 01 December 2018 - 09:36 AM
Dave,
Clay
 As the old saying goes " You need the right tools for the job".  A simple ring spherometer or lens gauge will measure the radius of the secondary to the needed accuracy. Here is  a picture of mine. I made the ring spherometer from a brass tubing fitting that I  faced off the end so the ID and OD are  sharp edged.   I then accurately measured the OD and ID. A digital micrometer fits in it, so by measuring the deflective and knowing the ID and OD of the surface that touches the glass you can calculate the radius. The other option  is inexpensive lens gauge that is used to measure eyeglasses. It reads out in diopters but that can be converter into a radius.
                 - Dave
#616 clamchip
clamchip
  • Loc: Seattle
Posted 01 December 2018 - 07:14 PM
I adjusted things around so I could space the mirrors 32 inches apart, still no focus, just a blur
and even the blur doesn't change while focusing.
I decided to try Dave's idea with the the light bulb in the focuser tube.
With the mirror spacing at 32" I moved the focuser starting with the bulb at 14 inches behind the
front surface of the primary, my binocular at infinite focus, and me about 15 feet in front of the
telescope viewing the bulb off-axis in the primary.
I found the best light bulb filament focus was with the bulb 1 inch in front of the primary!
So then I set the bulb at 13 inches back focus and started moving the mirror spacing in and
out in small increments but never could get the same focus.
I wish I could place a eyepiece and my head at 1 inch in front of the primary!
Robert
#617 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 01 December 2018 - 08:51 PM
I set up a small refractor and put a light in the focuser.  I went and stood 16' away with a pair of binoculars.  I could read the writing on the bulb, whether the focuser was racked all the way in or all the way out.
I'm sure that the light coming out of the scope the opposite way is suppose to be parallel light, if the bulb is at the f.l. of the lens.  I'm sure I understand the concept.
If I did something wrong, I don't know what it is.  Maybe the binos are just too forgiving with my eye.
Clamchip, try another scope and see what happens.
Edited by Garyth64, 01 December 2018 - 08:51 PM.
#618 DAVIDG
DAVIDG
Posted 01 December 2018 - 09:41 PM
When you place a light source at the infinity plane of a telescope then the light exiting the telescope in theory is parallel.   So if another telescope or binoculars that  is also focused at infinity is used to examine  light exiting the telescope,  the light bulb will also be in focus. If the light bulb is not at the infinity position of the telescope then the light exiting the telescope will be either divergent or convergent. So the bulb will act like one that is closer then infinity.  So the object in the binocular or other telescope will not be in focus.
  I have used this  methods many time to focus the optics in spectroscopes and also to focus finders so they are at infinity so I can find objects that Venus and stars in the daytime. If the focus is even slightly off the objects would be invisible in the daytime.
   Try using your binoculars that are perfectly focus at infinity to look down into a finder that has cross hairs. If the finder is focused at infinity the cross hairs should be in sharp focus. Then defocus the finder  and the cross hairs should also go out of focus.
                        - Dave
#619 clamchip
clamchip
  • Loc: Seattle
Posted 01 December 2018 - 10:02 PM
I was observing the light bulb filament reach sharp focus, and also watch as the sharpness went away
when the mirror spacing and focus were adjusted. The only thing is sharp focus was one inch in front of the primary.
And anything I tried, like moving the secondary, or the light source, only made it worse.
I think I should build a Spherometer. Like Dave mentioned I've got to know the exact radius of the secondary.
I have all the necessary parts to build one and a flat to zero the micrometer head.
Robert
#620 terraclarke
terraclarke
  • Loc: 39° 4' 19" N / 84° 28' 22" W
Posted 07 December 2018 - 07:48 AM
I took this picture in 2011 in Pearl Harbor at the USS Arizona Memorial, 70 years after the attack on December 7th, 1941. Oil is less dense than water and so when a drop floats to the water’s surface it disperses radially into a thin film. When a beam of white light strikes the top of the film a portion of it is reflected upward at an angle, equal to the angle of incidence as measured from a line perpendicular to the surface. The oil is transparent and so some of the light is transmitted downward through the oil. This light is refracted or bent downward slightly, more toward the perpendicular. Each of the colors corresponding to the beam of white light have different wavelength and so travel through the oil at a slightly different velocity. Violet light travels more slowly than red light and is thus refracted more. The angle of refraction lessens slightly with each wavelength, each color- VIBGYOR. At the bottom surface or interface between the oil film and the water, reflection and refraction again take place. This secondary upward reflection occurs along a slightly different path and the difference between the two light rays causes interference. As the oil drop spreads out radially from its point source, it thins. This produces differing thickness of oil outward, resulting in a lens-like effect. This results is a slight difference in path length. The combination of these factors produce a circular a rainbow-like pattern across the surface which is distorted by ripples and currents in the water.
The diesel oil still percolates up from the fuel tanks of the USS Arizona. A sad and solemn reminder of the nearly 1200 US service men (USN and USMC) still entombed in her. The smell of the oil is still strong. The rainbow colored haloes form and drift away as each drop rises which to me was symbolic of the ascending souls of the men who perished on her. REMEMBER THE ARIZONA!
  • semiosteve, jjbird, CCD-Freak and 13 others like this
#621 steve t
steve t
  • Loc: SW Ohio
Posted 07 December 2018 - 11:28 AM
Terra,
Very well said.
My late father inlaw, a navy vet from WW II, once told me that according to legend the USS Arizona will stop leaking oil when the last of her crew passes.
Steve T
  • terraclarke likes this
#622 Exnihilo
Exnihilo
  • Loc: Tempe, AZ
Posted 07 December 2018 - 11:41 AM
Terra, thanks for sharing.
#623 terraclarke
terraclarke
Posted 07 December 2018 - 12:24 PM
Terra,
Very well said.
Steve T
Sadly, none of the surviving members of the USS Arizona are still with us. They’re all 2,512 officers and crew topside now! She continues to leak approximately 9 quarts of diesel oil a day.
In an odd coincidence, both my biological father (Marine, Gunnery Sgt.) and my father-in-law (Army, Master Sgt.) were at Pearl Harbor on the day of the attack. (Neither ever knew each other to my knowledge.) Another weird coincidence, it was my father-in-law’s 28th birthday, (he went in at 16). Both survived WWII.
  • TOM KIEHL and Bonco2 like this
#624 clamchip
clamchip
  • Loc: Seattle
Posted 09 December 2018 - 07:58 PM
This is so true!
"You know your a equipment freak when..."
https://www.scoperev...com/page1c.html
Robert
  • DreamWeaver, TOM KIEHL, Bomber Bob and 1 other like this
#625 clamchip
clamchip
  • Loc: Seattle
Posted 10 January 2019 - 11:28 AM
Return to "Starlight Nights" here:
https://www.aavso.or...s-eBook_(2).pdf
and the book Starlight Nights by Leslie Peltier:
https://archive.org/...StarlightNights
Robert
Edited by clamchip, 10 January 2019 - 11:45 AM.
  • DreamWeaver, steve t and BillShort like this
