Post a picture of your Cat
1894 replies to this topic
#1576 jgraham
jgraham
Posted 12 October 2018 - 04:16 PM
This my recently refurbed SN8 configured for imaging with a shiny new Moonlite focuser, a Williams Optics 50mm guide scope, a heated Astrozap dew shield, DSI Pro II guide camera, and a ZWO ASI071MC Pro. The Moonlite is a 2-speed tri-knob with the shaft lock. The Moonlite takes all the work out of making fine adjustments to the focus, which is a bonus in the wee hours of the morning when you're not as dexterous as you were earlier in the evening. :)
  • Scott Beith, Starman27, elwaine and 9 others like this
#1577 mumbles
mumbles
  • Loc: Adirondacks
Posted 12 October 2018 - 07:05 PM
Sent from my SM-G950U using Tapatalk
  • Scott Beith, Starman27, elwaine and 6 others like this
#1578 jgraham
jgraham
Posted 13 October 2018 - 04:56 PM
I have been working on this system for quite a while and it has finally come together. This is a Meade 8” Wide Field (f/6.3) LX200GPS that I have configured for specifically for electronic assisted astronomy (EAA). The telescope is an older LX200 EMC reforked onto an LX200GPS mount. The tube sits higher in the fork than the original EMC so I have a padded weight hanging from the handle to balance the scope. This turned out to be a nice configuration as both the padded weight and the camera can swing through the forks. The camera is a Revolution Imager 2 fitted with a 0.5x focal reducer and a Hutech IDAS LPS2 that serves as both a light pollution filter and an IR cut filter. The focal reducer is spaced to bring the original f/6.3 focal ratio all the way down to f/2.4. This gives a reasonable flat field that only shows a tad of vignetting in the corners. With the RI2 operating in a nearly full automatic mode I can reach my photographic sky limit of about Mv 18, meaning that I can literally see all there is to see from my backyard.
  • Scott Beith, Ptarmigan, Starman27 and 7 others like this
#1579 eros312
eros312
  • Loc: Tampa, FL
Posted 16 October 2018 - 01:44 PM
My Pico-6, a 60mm 700mm FL mak. Shown with a 6x30 finder and a 25mm Paradigm eyepiece.
  • Scott Beith, Starman27, Dave Ponder and 15 others like this
#1580 jgraham
jgraham
Posted 04 November 2018 - 02:25 PM
I had a productive day yesterday. I spent about 6 hours converting a beautiful old Celestron 8" f/1.5 Schmidt camera from film to CCD. I previously converted a smaller Celestron 5.5" f/1.65, so this conversion went pretty smoothly. Unfortunately, the first-light images showed that the camera was wacko out of alignment, but it did show that the camera worked (a color Starlight Xpress Superstar guide camera), could be focused, and hinted at how screem'n fast this camera is going to be. This morning I took it apart, and made a small modification to the mirror mount that should fix the alignment problem. A check with a laser and centering mask showed that at least the rough alignment now looks spot-on. I'll know more the next clear night we get, which looks like could be this Wednesday. Once I get the camera aligned and fully tested I'll post a series of pictures of the conversion in the ATM forum.
Fun stuff!
  • Scott Beith, Starman27, elwaine and 11 others like this
#1581 bikerdib
bikerdib
  • Loc: Southeast Texas
Posted 04 November 2018 - 03:13 PM
Here is my Celestron 14" Edge on the CGE PRO mounted on my backyard pier with the Tempest fans getting it acclimated for the night's session.  I have a ridged dew shield but also have a closed cell foam extension that I made and slip onto the ridged shield (not sbown).  That gives me around 30" of dew shield total.  I need every bit of it too with night time humidity that is easily in the mid 80% but sometimes gets all the way up to100% as the night progresses.
  • Scott Beith, Starman27, elwaine and 7 others like this
#1582 bikerdib
bikerdib
Posted 04 November 2018 - 04:16 PM
Would the moderators kindly rotate the image I posted.  Also, would someone please explain why the image was rotated when uploaded from my android tablet so I can avoid it happening in the future.
#1583 Rustler46
Rustler46
  • Loc: Coos Bay, Oregon
Posted 04 November 2018 - 08:35 PM
That's a very nice setup you've got. I have wanted a C-14 for years, but could not see myself lifting the 45 lb. weight of the optical tube. Having a permanent pier like you have, even without a slide-off roof, must make setup easier. I have my C-11 on a similar pier. Here on the Oregon coast the humidity is also quite high, though the temperatures are mild. The last time I observed (a few nights ago) the temperature was around 50° with a 45° dew point. After around 3 hours the temperature dropped to 45° and fog formed (100% relative humidity). So while we have different  observing conditions, the effect with moisture is similar.
I would suggest the use of a DewBuster controller along with two heater strips to control moisture. Your Reflectex covering could also be employed over the dew heaters. While it is not inexpensive the Dewbuster is made with industrial quality. When fog ended my observing session mentioned above, the air was quite thick with moisture and dew covered most exposed surfaces. Yet there was no dew on the corrector plate. So the Dewbuster is quite effective and uses the least possible battery power. I believe Kendrick makes a similar dew heater controller.
The photo shows my C-11 with an AT115EDT triplet APO on top. I usually run two dew heater strips right below the corrector cell. That is the best location for the heaters according to the information of the Dewbuster website. It is much less effective to heat the corrector lens cell like on some heated dew shields. The corrector is well insulated from its cell by cork spacers and air gap.
The DewBuster website has a wealth of useful information about dew control. Ron Keating (the proprietor) knows what he's talking about when it comes to dew problems. Following the instructions he gave I made a dew heater for my Telrad finder. It is powered by one of the medium power outputs on the Dewbuster. I found the commercial dew shields for the Telrad to be useless. But with the home made heater the Telrad window never dews up, even though it is openly exposed to the moist air.
Best Regards,
Russ
#1584 bikerdib
bikerdib
Posted 05 November 2018 - 08:03 AM
Thanks Russ.  I actually had a heated strip and controller but after I made the lightweight extension I no longer needed it and ended up selling it.  The extension seems to create enough dead air infront of the corrector.  Of course if I did a lot of observing at the zenith I may have an issue.
  • Phil Cowell and Rustler46 like this
#1585 Wil2010
Wil2010
  • Loc: Shingletown, CA
Posted 06 November 2018 - 11:53 PM
should have added the pic
Beautiful Set-up!!
Clear skies..
#1586 MalVeauX
MalVeauX
  • Loc: Florida
Posted 17 November 2018 - 08:16 AM
Had this 30+ year old Meade #2120 on the mount last night, looking into some lava lanes and craterlets on our moon.
Very best,
  • Scott Beith, 3 i Guy, Starman27 and 7 others like this
#1587 CCD-Freak
CCD-Freak
  • Loc: Whitesboro,Texas
Posted 17 November 2018 - 01:12 PM
My AT10RC on the AP900 waiting for dark at Ft Griffin SHS.
John Love
CCD-Freak
WD5IKX
  • Scott Beith, Starman27, elwaine and 5 others like this
#1588 mumbles
mumbles
  • Loc: Adirondacks
Posted 08 December 2018 - 01:23 PM
  • Scott Beith, Starman27, Dave Ponder and 16 others like this
#1589 Tyson M
Tyson M
  • Loc: Canada
Posted 16 December 2018 - 05:46 PM
I just picked up one of these.
Its main goal is DSO and planetary nebula viewing.  I want to dabble in planetary nebula imaging with CMOS camera and short exposures.
#1590 MalVeauX
MalVeauX
  • Loc: Florida
Posted 17 December 2018 - 11:01 AM
New to me (can't tell it was used so far)... C8 Edge with Feather Touch focuser. Had it out to clean it and test everything on it this morning. Ordered some Bob's knobs to install. Tried out a Crayford focuser to see if it would fit with the Feather Touch (as this will be used for visual, imaging, etc in many fashions, got it to be a modular "do as much as you can with it" type instrument).
Don't worry, it was on the Twilight I just to test it out and clean it. But that said, the Twilight I surprisingly was able to hold it and dampened in less than a second at 100x magnification without a problem. Surprisingly usable at medium power on this mount for visual. Soon as I get the rest of my equipment, it will live in my observatory on an HEQ5.
Very best,
#1591 kksmith
kksmith
  • Loc: Montana
Posted 18 December 2018 - 12:24 AM
Wooing Wirtanen
2018 1217 19034000
  • Scott Beith, Starman27, elwaine and 2 others like this
#1592 gcardona
gcardona
Posted 18 December 2018 - 12:46 AM
C9.25 Edge HD after a successful night of imaging.
#1593 Hugh Peck
Hugh Peck
  • Loc: NE WI
Posted 18 December 2018 - 05:28 PM
Had forgotten just how small these are.
#1594 doug mc
doug mc
  • Loc: Tamborine Mountain Australia
Posted 18 December 2018 - 08:03 PM
My new GSO classic cassegrain.
#1595 CCD-Freak
CCD-Freak
Posted 18 December 2018 - 09:40 PM
John
CCD-Freak
WD5IKX
#1596 doug mc
doug mc
Posted 19 December 2018 - 10:29 PM
Sky conditions have not been favourible on the two nights I have had
a chance to use it. From what I have seen so far everything looks good. In moments of better seeing, stellar diffraction patterns looked intense and symmetrical. No sign of astigmatism. Collimation good right out of the box. Was hoping to get a chance to view the moon but the clouds rolled in. Summer here in sub tropical Australia. But the best thing so far was no optical dewing problems, even though the tube was getting covered in moisture. Dewing was the reason I sold off my C8. All this scope has to do is to match the C8 without fogging up. I believe it will. With the same mechanicals as the RC version (smooth dual speed Crayford focusing) it's been a pleasure to use .
  • CCD-Freak, eros312 and Colin exraaf like this
#1597 Colin exraaf
Colin exraaf
  • Loc: Australia
Posted 19 December 2018 - 11:40 PM
Santa came this Morning .... Intes MAK -MK65 ....delivered to my Door.
A credit to Lewis ( TAK Tragic ) for restoring this recently..... and Matt ( Canberra ) for letting me buy it.
Col .... ( Down Under )
Edited by Colin exraaf, 19 December 2018 - 11:49 PM.
  • Scott Beith, 3 i Guy, Starman27 and 13 others like this
#1598 Colin exraaf
Colin exraaf
  • Loc: Australia
Posted 19 December 2018 - 11:45 PM
A couple extra .........
Col ....( Down Under )
  • Paul Schroeder, Scott Beith, elwaine and 9 others like this
#1599 Simon B
Simon B
  • Loc: Vancouver, BC
Posted 20 December 2018 - 12:02 AM
Noice
  • Colin exraaf, bbqediguana and gfstallin like this
#1600 Kunama
Kunama
    Aussie at large
  • Loc: Canberra, Australia
Posted 20 December 2018 - 12:23 AM
You're most welcome, hope you enjoy it (or send it back to me if you don't !!!)
  • Colin exraaf likes this
