Silver Spray On Instead of Alumnimizing?
88 replies to this topic
#1 saemark30
saemark30
Posted 22 October 2013 - 02:26 PM
Anyone come across a silvering method that can be sprayed out?
I see it is been used on the 70" scope thread but never heard of such a product.
#2 Ed Jones
Ed Jones
Posted 22 October 2013 - 02:48 PM
Sure chemical silvering can be done with a 2 part spray gun. Peacock Chemicals has or had such a silvering kit.
#3 sopticals
sopticals
Posted 22 October 2013 - 11:19 PM
Spray on my silver using weed spray gun. Angel Gilding for the chemicals. Easy to do, and inexpensive.
Stephen.(45deg.S.)
#4 John Carruthers
John Carruthers
    Skiprat
Posted 23 October 2013 - 05:32 AM
domestic mirrors are sprayed but they are 'back' mirrors, the quality of the surface isn't as critical as a first surface mirror.
Getting the right thickness of deposit to provide reflection, but without distorting the figure would be tricky. I believe the thickness needs to be in the order of 3 or 4 molecules? (ISTBC).
#5 saemark30
saemark30
Posted 23 October 2013 - 11:12 AM
Stephen.(45deg.S.)
Thanks for the tip. It looks like the spray silver concentrate 120mL plus spray silver activator 500mL and spray silver reducer can be gotten for less than $100.
This covers 133 sq ft. Very reasonable for large quantity of small mirrors or a even a few 1m size mirrors.
#6 Qwickdraw
Qwickdraw
Posted 23 October 2013 - 11:22 AM
Note to self, don't buy mirrors from Saemark :grin:
#7 BigC
BigC
Posted 23 October 2013 - 11:29 AM
LOL!!
#8 saemark30
saemark30
Posted 23 October 2013 - 11:33 AM
OK I'm keeping my next 70" mirror for myself!
#9 kfrederick
kfrederick
Posted 23 October 2013 - 12:20 PM
Sasmark have a link for the silver supplies I have some big mirrors that need coated .
#10 Chuck Hards
Chuck Hards
Posted 23 October 2013 - 12:24 PM
Get enough to practice on scrap glass first. 70-inch Mike told me that he had to practice a bit before he nailed his technique.
#11 highfnum
highfnum
Posted 23 October 2013 - 02:53 PM
this is crazyist thing I heard of
I like to see a photo of an example
#12 careysub
careysub
Posted 23 October 2013 - 03:05 PM
Wouldn't you want to practice on a good test mirror (you can strip and recoat repeatedly) so that you verify the coating is performing optically?
#13 DAVIDG
DAVIDG
Posted 23 October 2013 - 03:19 PM
The chemist is exactly the same as what one does when they silver solution coat a mirror in a bath. As Ed stated Peacocks labs has been selling the material for many years http://www.peacockla...om/products.htm At one time they sold the solutions packaged in typical spray paint type cans
- Dave
#14 saemark30
saemark30
Posted 23 October 2013 - 04:55 PM
http://angelgilding....praySilver.html
Why not?
#15 sopticals
sopticals
Posted 23 October 2013 - 06:27 PM
Why not?
Go for it. My mirror works :grin: fine. Fantastic DSO views with 95% :roflmao: reflectivity.
Stephen.(45deg.S.)
#16 ccaissie
ccaissie
Posted 23 October 2013 - 07:22 PM
If one desires a semi reflective coating, say in testing an optic in progress...Ritchey Common test or back surface of mangin, etc., can this process give a uniform reflective surface? Can it be readily controlled to do 50% reflectance, etc?
Does anyone know what standard silvering technique this is similar to?
Rochelle Salts? Brashear?
#17 kfrederick
kfrederick
Posted 23 October 2013 - 07:42 PM
Our 7inch secondary was overcooked and needed re worked in getting coated / so some risk in coating and on a 36 $$ Just the thought of UPS having the glass Ouch
#18 saemark30
saemark30
Posted 24 October 2013 - 01:08 PM
Perhaps there is a spray on antireflection coating as well, that would be really crazy!
#19 DAVIDG
DAVIDG
Posted 24 October 2013 - 03:21 PM
Most AR coating needs to be applied in very precise thickness to work but there are chemical means to "stain" the top layer of the glass and form an anti-reflective coating. Certain glasses can be dipped in acid which removes some of the metal ions on the surface forming an antireflective coating only a few atoms thick
by changing the refractive index of the top surface.
- Dave
#20 highfnum
highfnum
Posted 25 October 2013 - 04:12 AM
Wild learn something new every day
#21 Startraffic
Startraffic
Posted 25 October 2013 - 05:10 PM
LOL, for a second I had pictures of spraying a mirror with the stuff they spray on house trailers. I did that with a roller once....once. :foreheadslap:
Clear Dark Skies
Startraffic
39.138274 -77.168898
#22 Lynnblac
Lynnblac
Posted 25 October 2013 - 05:37 PM
Up until the 1930s all telescope mirror were coated this way. The 100" Hooker telescope that Hubble used to discover the scale of the universe was silvered.
#23 richard7
richard7
    Not Quite
Posted 25 October 2013 - 06:46 PM
This is getting to be a very interesting thread.
#24 highfnum
highfnum
Posted 26 October 2013 - 08:16 AM
I thought mirrors were placed in tub with silver
Solution then after x time taken out
Sprayon seems to crude but what the hell do iknow
Next someone will say youcan use a 5 buck home depot brush
#25 highfnum
highfnum
Posted 26 October 2013 - 08:19 AM
I still would like to see photo of one
Butif davidg says its valid it most likely is
