Star Clusters and the like
34 replies to this topic
#1 geoffrey
geoffrey
Posted 18 February 2004 - 09:34 AM
Please could I have some advice.
I have a 4.5 Helios Skyhawk(now Skywatcher) short tube reflector, and I am looking to upgrade. Everything I have read leads me to a 8" Newton/Dob, (even the owner of my scope shop), but I want some portability, and I am only short myself.
Is a maksutov ok for clusters?
Is the etx Meade 90 ok, or is it two 90mm too small?
Is a short tube reflector really only good for Planets?
I accept that a F9 1000m Reflector is perhaps the best, but can you let me know how you all find your Maks/Refectors for Star Clusters.
I am talking about UK £500 max.
Many thanks
Geoffrey
#2 jmoore
jmoore
Posted 18 February 2004 - 11:09 AM
Hey Geoffrey.
To address your various comments....
1. Yes, an 8" Newt (equatorial mounted) is, in my opinion, a great general purpose scope...big enough for nice deep-sky work, good on planets if you keep well-collimated (with tracking being a real plus), not exactly "grab'n'go" on portability, but still pretty easy to setup and break down and transport wherever you want in a vehicle. A nice balance between aperture and portability, and a nice balance between working on planets and DSOs.
2. Yes, a Mak is good on clusters and everything else. There are really only 2 negatives to a Mak...long cooldown time (no big deal if you just remember to put it outside awhile before use), and narrow FOV (just something you have to work with I guess). But as for image quality, a Mak is probably going to give you a better view of just about anything except an APO refractor...for a given aperture of course. However, if you already have a 4.5" scope, why do you want a 4-5" Mak? To me, an upgrade means "bigger". Sure, there are quality/design issues, but I think you'll find the difference between your scope and a Mak won't be THAT different, except maybe on planets (or unless you're talking about a 6-7" Mak).
3. In my opinion, 90mm will be pretty small for deep sky work. If you're interested in star clusters, you'll be better off with your 4.5".
4. You've got it backwards on the Short-tube reflector. Reflectors are better for deep sky than planets. What's the f-ratio on your short-tube? If it has the corrector plate that makes it a f9 or f10, it would, in theory, be better on planets than if it was f5. But, I understand these Barlow-added "short-tube" designs aren't very great in terms of giving them long f-ratio capabilities (e.g., being good for planets). So, an f10 SCT or f12 Mak will be better on planets than your short-tube. Your short-tube will still be better on star clusters than it is on planets.
#3 erik
erik
    telescope surgeon
Posted 18 February 2004 - 11:19 AM
hi geoffrey, i've found maks and SCT's in small apertures to be useful mainly on globs and planets.but i don't care for the super long focal lengths that they have, which creates a very narrow FOV, which i find annoying.they also tend to throw up a dimmer image than newts or refractors of the same aperture, making them less useful on DSO's.a short tube newt like you have is meant more for deep sky than for planets. the longer the focal length is, the better it is on planets. when you crank up the power on a short focal length scope, the image will usually appear soft and blurry unless it has excellent optics, which most 4.5" short tube newts don't. i've found the most versatile f/ratio to be around f/6, because it works well on everything, and in sizes 8 inches and less, it's portable.i don't think the ETX scopes pull in enough light to seriously study globs, it would probably only resolve the stars in the biggest showpieces, like M13 and M22. you should try reading some reviews of scopes here on cloudy nights reviews section or on www.scopereviews.com to get a better idea what would be best for you. good luck.
#4 geoffrey
geoffrey
Posted 18 February 2004 - 12:13 PM
Thanks for replying guys.
jmoore, I forgot to say my 4.5" is F8.9
Your comments are interesting, suggesting that my scope is ok for what I want.
The reason of thinking of changing is because it is a cheap Synta scope, and I am having trouble resolving the Moon with my 9mm e.p.. I bought 3 Super plossls 9mm/25mm and 40mm. The two larger I like alot, especially the 40mm. M45 looked good.
My scope shop, who are very good, suggested that the mirrors might need moving. It is Collumated ok. They said "bring it in next tme you try it on the Moon with the 9mm e.p." I will of course do that.
The only problem is that in NW England I have only seen the sky twice since Christmas, and the Moon once. But that is life here.
Thanks again for your help.
Regards
Geoffrey
#5 lighttrap
lighttrap
Posted 18 February 2004 - 12:15 PM
I've had 4 Maks: (Intes Micro M603 150mm, Intes Micro MN56 Mak-Newt, Astro Rubinar 100mm Mak lens, and Celestron 90mm Mak). None of those provided the good views of my current Hardin DSH-8 200mm f/6 DOB on anything from planets to clusters to nebulas and galaxies.
90mm is really way too small for much enjoyment. And the 90mm Mak will seem even smaller due to a narrow FOV and a fairly restrictive power range.
The other thing about Maks is that it totally depends on where you live and observe as to how much of an issue long cool down times are to you. For instance, lots of folks erroneously assume that cooldown is primarily a winter issue, and that all that is required is an unheated storage space. What I found here in NC, is that it was as much or more of an issue in Summer. If you leave the scope in an unairconditioned space, then it starts out lots higher temp than ambient, and takes all night to cool down. If you leave the scope in an air conditioned house, then it becomes a dew magnet the very instant you take it out into the humid summer air. Either way, I found the cooldown times on the M603 to be such a major issue that I reluctantly traded it. The smaller Maks were sold off with much less reluctance, and frankly I was glad to be rid of them.
If you're in England, you probably are familar with very humid air. The problem with any of the Maks or SCTs is going to be that the front corrector plate tends to collect humidity very quickly, and that totally wrecks the views. You can get heaters to solve for that, but be aware that adds a whole separate layer of complexity in terms of batteries, cables, heater bands, etc.
I would echo others that suggest you consider a 200mm reflector.
Mike Swaim
#6 lighttrap
lighttrap
Posted 18 February 2004 - 12:18 PM
Geoffrey,
You ought to be getting better performance than that out of your 4.5" Definitely, have it checked out before buying anything else.
Mike Swaim
#7 Willy
Willy
Posted 18 February 2004 - 02:42 PM
Hi Geoffrey,
I know what you mean about the dearth of clear skies lately.....I live just south of the Humber.
Now on to telescopes.As you can see from my signature, I have a 4" f9.8 refractor and an 8" f6 newt.The 8" started life as a dob but I removed the altitude bearings and mounted it on a EQ5 gem.I am going to also make a removable box for the tube assembly so I can also use it as a dob.This way I've got the option of a quick set up dob and a more leasurly equatorial.The 8" is a very good telescope both for deep sky and the planets.Saturn is fantastic in this 'scope and Jupiter takes your breath away.
If I'm honest, I have to say the 4" hardly gets used as the views are very disappointing compared to the reflector.
The refractor is a Helios ( synta )and the reflector is a Skywatcher.I would recommend the reflector as your main 'scope and if you really need a quick set up 'scope either do as I have or get yourself something like a short tube 80mm skywatcher.My view is ( and no doubt some will dissagree )Skywatcher makes great reflectors but only mediocre refractors. :waytogo:
#8 geoffrey
geoffrey
Posted 18 February 2004 - 03:06 PM
Thank you Mike and John.
Mike, your post was very helpful giving all those points. I will get mine checked out again.
John, your "two mounts" sounds interesting.
Regards
Geoff
#9 Tom L
Tom L
Posted 18 February 2004 - 03:34 PM
John, would you mind posting this in the ATM forum so we can discuss this further. I have an 8" Hardin Dob that I will be converting to my GEM (using a variation of your pier design!), but I want to retain the ability to use the dob base as well.
Thanks, Tom
#10 Willy
Willy
Posted 18 February 2004 - 04:16 PM
Yep, no problem.
#11 matt
matt
    Vendor (Scopemania)
Posted 18 February 2004 - 05:16 PM
We use to say that aperture rules, and on clusters, aperture just stomps everything else. To see clusters (either open or globulars) you need to see dim stars so aperture is the only way to get there. I know. I'm mostly a cluster guy and have seen about half of the 148 globular clusters in our galaxy.
So the answer is, get the biggest reflector you can afford. You're not getting any younger and you better enjoy those 16 cloudless nights a year. You might want a dobsonian not only for price reasons but also because large GEMs for large scopes are really bulky.
Suggesting a newtonian reflector does not mean that other designs are bad for clusters, but as you go towards large apertures they become the only affordable instruments. SCTs are ok up to the 10" range, then become prohibitively expensive.
So my vote is an 8-10" dobsonian.
A gentleman in England was selling on ukastroads.co.uk a 14" Dob for 400£... you might give it a try!
#12 erik
erik
    telescope surgeon
Posted 18 February 2004 - 08:13 PM
geoffrey, like john, my current 8inch scope started out a dob until i mounted it on a go-to EQ pier. i'm also in the process of making a collapseable base for the tube, except i'm using the original wooden base that came with the scope, and installing wooden dowls that so that it can be taken apart after each viewing session.so if portability is an issue, maybe you should look into doing something like that(or building a truss scope).i would also echo what john said about how he uses his scopes. i have the 8inch newt, as well as a 4.7inch refractor, and i use the 8inch 95% of the time, even though the refractor is way more portable. if you did decide on a refractor, i think you'd need to spend a lot more money than what you'd pay for a mak or a newt. if i were going to buy another refractor, i think i'd plan on spending at least $3500 so that i could get the type of scope that i'd enjoy using as much as my 8inch newt.there's really no substitute for aperture, and the difference between 4.5 inches and 8 inches is HUGE. even 8 inches isn't enough aperture for me, i'm going to get a 16 inch soon, but if portability is the goal, 8 inches is the perfect compromise between ease of use and performance.
#13 geoffrey
geoffrey
Posted 19 February 2004 - 03:19 AM
Good Morning all
Thank you very much for your help. It looks like the 8" Reflector. Will try the mounts in my shop, but will have my 4.5" checked first. Bit of a fag, as first I will have to wait until the moon is visible, and then hope I get some clear skies as well.
Kind regards
Geoffrey
#14 geoffrey
geoffrey
Posted 20 February 2004 - 03:18 PM
Hello folks.
Turn of events!
After all your help etc, I went to my scope shop (I am lucky) it is only 6 miles away, and the biggest supplier in NW England)I was going to buy a Magazine and talk about fixing my scope. However, they had just got a second hand Dob, which they had built a few years ago. (T & L Optics). I t has a David Hinds made Mirror. 6.25"(158mm) F7.6 and a 47.85"(1215mm Tube).
The base is all wood, and I could lift the scope complete
So I part ex'd mine. They had checked it over etc. and used a laser to coll.
What was nice, was they showed me how to coll, whilst there, and they had put a coll dot. on to help me.
I tried it for an hour tonight. Great, I could see stars that were not there before, and the views looked good -despite next doors upstairs windows. What a difference between the two scopes? Carn't wait to use it on a dark site. Found it easy to scan with the 40mm and 25mm e.p's The other scope was like Roy Hudd and the Emu (that's for the UK readers)
Off to my Ast.Soc. obs. now, but might have another looke after midnight.
Might take a photo, if I can work out how to post it
Regards
Geoffrey
#15 Echo
Echo
Posted 20 February 2004 - 04:11 PM
Great news Geoffrey! I'm glad you have a nice scope now and are able to enjoy some quality star time. Definitely post a picture.
#16 Scott Beith
Scott Beith
    SRF
Posted 20 February 2004 - 07:06 PM
That is cool that your Astro store is only a few miles away!!! How lucky can a person be? Definitely post a photo. Congrats Geoffrey!!!
Scott
#17 geoffrey
geoffrey
Posted 20 February 2004 - 07:27 PM
Thanks guys. I have the picture as JEPEG in "my documents", but will have to work out how to post :help: Read the FAQ's, but Double Dutch to me at present. Watch this space!
Regards
Geoffrey
#18 Tom L
Tom L
Posted 20 February 2004 - 07:33 PM
geoffrey, do a reply to this post and when you submit it, you will have the preview. There is a box that will allow you to attach a pciture. Type or browse to the one you want to include...easy as that!
#19 geoffrey
geoffrey
Posted 21 February 2004 - 02:57 AM
Thanks alot Tom -here goes?
Regards
Geoffrey
#20 geoffrey
geoffrey
Posted 21 February 2004 - 03:19 AM
See to have a problem Tom. It told me the file must have a jepg extension, but I thought it did??
Will think about it and try again?
Geoffrey
#21 Victor Kennedy
Victor Kennedy
    Pooh-Bear
Posted 21 February 2004 - 03:25 AM
Geoffrey, it doesn't like .jpeg, change it to .jpg and try again.
#22 geoffrey
geoffrey
Posted 21 February 2004 - 05:13 AM
Take ???
#23 geoffrey
geoffrey
Posted 21 February 2004 - 05:25 AM
Thanks for all your help folks. At least I learn -had to make a phone call to learn how to reduce the image as it was over the max allowed.
Here is the link to my "down the road scope shop"
http://www.telescope...noculars.co.uk/
It might be down the road, but the uk is small compared to accross the pond, and in rush hour it is nearly quicker to walk accross the tops of the cars!!
Went to my Ast. Soc. Obs. last night again only 13 miles away - They have a 14" fixed EQ Reflector. My first view through anything other than my old scope. Wow!! Could see space between the four stars in the Orion Trap. Jupiter was amazing with the four moons like jewels.
Regards to you all
Geoffrey
#24 Willy
Willy
Posted 21 February 2004 - 08:45 AM
Good looking 'scope Geoffery.Now all you need are clear skies.I set my 'scope up yesterday about 5.30 while the sky was clear, went indoors for tea while it cooled down.Went out at 6.30 when it was dark and the clouds had rolled in. :mad:
Ah well. I need the exercise anyway.
You must live near our daughter....she lives about 15 minutes away from SBTC. (Chorelton )
Cheers.John.
#25 geoffrey
geoffrey
Posted 21 February 2004 - 09:15 AM
Hi John
Yes, I am about the same distance South of SBTC as your daughter is in the opposite direction ; just about on the edge of the Peak District, but "attached" to Gtr. Manchester on the other.
Regards
Geoffrey
