It's sitting on a Fancier FT-717AH pan/tilt fluid head and has a Smith Victor BH5 ball head.
I have not had the opportunity to hook up the motor to it yet but have taken some manually tracked 30s shots that look decent. It's a pita to rotate that gear at a constant rate with cold hands & fingers!
I do have a question regarding how the main gear sits. This gear has a blind well nut pressed into the center and the gear sits on the bottom platform. Is this OK? Most of the barn door tracker pictures I have seen have this main gear sitting up off the bottom platform a few mm. I am not sure how they accomplish that. The friction between the gear and wood is low but I am wondering if that could impact the tracking.
I also have to figure out the polar alignment scope. I have it positioned on the end of the top platform but it is not pointing at the same place the hinge pin is. For my trial I just aligned the platform hinge pin with polaris by eye.
